Question about Dishwashers
I have a blanco dishwasher BFDWC65, when I put the cycle on it seems to be struck one one cycle, is there a way to reset the unit or is there something wrong with the electronics
  • Janet Paterson Nov 27, 2012
    Has anyone found out what this problem is and/or how to fix it? I have the same problem.
I have the same problem and am interested if you solved this?
Posted on Nov 22, 2010
  • GnM1 Jun 11, 2011
    Hi, I am interested in what the solution was as I have the same problem.
  • jarrodvetesi Aug 05, 2011
    any ideas I have the same problem???? help please??
Our newish Blanco dishwasher BDW3458X sometimes doesn't drain all the water out either... it has H23 flashing but can't find any manual to tell me what this means. I appreciate all the answers others
I struck this problem recently and it may have been caused by someone leaning all over the buttons while it was running. I got around it by holding in the start/pause button for a couple of seconds. The timer went to zero and it whirred away for a few seconds. After this it was reset and has worked ok since.
wsr
Dec 29, 2014 | Dishwashers
Blanco dishwasher
Dishwashers do not usually complete the cycle if the water temperature is not adequate for the wash program selected. This could be due to inlet hot water not at correct temperature if dishwasher uses hot water or the heater or thermostat within dishwasher being faulty and not able to heat the inlet cold water to the right temperature. Try to run the dishwasher with the rinse or quick wash (low temperature) setting and see if it completes. Might help if you post the Model number in the comments field.
Apr 22, 2014 | Dishwashers
I have inherited a Blanco Bfdw 650s Dishwasher and there seems to be a manual dial as opposed to automatic ones which is what I'm used to...does this mean I have to stay home to help the machine perform...
No! Set the cycle you want first (A/B/C) THEN turn it on. It will just run through. I've just found my PDF instructions and trying to work out a way to upload them.
Nov 08, 2012 | Dishwashers
How do i install a motor on a blanco dishwasher bfdwc65
Hi.
The parts' arrangement is similar to several Whirlpool model. The pump motor is located under the bottom place and it is accessed removing the front kick panel (in front at the bottom).
Here a movie showing the procedure on a Whirlpool similar to your Blanco. I also tried to describe the procedure below. Check also the parts diagram for your model at the end of this comment. Sometimes it is not necessary to lean the appliance on one side, depending on how you can reach pump motor and hoses. See movie and description.
To remove the old motor you need to:
  1. Disconnect power.
  2. Move appliance forward.
  3. Disconnect drain and inlet hoses and remove water from tub (if any).
  4. Remove baskets or anything else from inside the machine.
  5. Remove spray arms and remove the assembly at the bottom of the machine.
  6. Put some clothes or towels on floor and lean the machine on one side.Water will leak out, the clothes will help here.
  7. Take the kick panel in front off.
  8. Undo the screws that hold the pump to the machine cabinet.
  9. Use a flat screwdriver to loose the clip holding the hoses. Loose the clip but do not open it completely (it will help later).
  10. Pull off the two hoses.
  11. Disconnect the electrical connector to the pump
  12. Lift the pump motor and pull it out from cabinet.
To put in new pump.
  1. Insert the two hoses on new pump.
  2. Set the clips.
  3. Put the pump motor in place inside the cabinet.
  4. Arrange hose and pump motor correctly and put screws back.
  5. Reconnect the wiring connector.
  6. Lift up the appliance.
  7. Put back spray arms and internal assembly.
Before putting on the front panel:
  1. Connect power and test for leaks.
  2. Disconnect power and fix any leak present (adjust hoses).
  3. If there is no leak put panel back.
  4. Set back the appliance and connect power.
Always observe strictly health and safety prescription. Disconnect power before performing any maintenance. Beware of panel's sharp edges, particularly when removing kick panel and accessing parts in the tight space under the bottom of the tub.
Here diagrams showing all parts:Exploded view.
Regards.
Ginko
Sep 07, 2011 | Dishwashers
I have a brand new Blanco dishwasher but im unsure if it is a DWF6XP, DWF4X or DWIN7 model. It does not have a salt dispenser if that helps. Last night when running for the first time i had a plumbing...
Unplug it and wait 5 minutes. Plug it back in. This will reset the machine. Put it on full cycle and allow it to do a full cycle. It should work just fine.
Nov 16, 2010 | Dishwashers
When i turn my blanco bfdwc65 on, i can hear a motor running for a period of time and no water comes. sounds like the motor is burning out if i leave it running
is this a wadshing machine or a microwave oven? Please list under the correct catregory othyerwise the techs in the correct area dont see it
Aug 04, 2010 | Microwave Ovens
I have a Blanco Dishwasher
Try unplugging it from the wall socket and leaving off for about 1 min then plug in and turn back on
Aug 14, 2009 | Dishwashers
I have a Blanco Dishwasher and the water will not drain away from the machine after it has completed a cycle, how do I get it to drain?
hi, there are 2 pumps on a dishwasher, it sounds like the drain pump on your unit is not working, it may need to be replaced. . if it is in warranty contact the manufacturer, if not contact a local appliance repair company. in the mean time you can use a wet/dry vac to get the remaining water out of the unit.
Mar 21, 2008 | Dishwashers
Dishwashers Logo
1,194 people viewed this question
Top Dishwashers Experts
