Question about Compaq Computers & Internet
Install new memory - Compaq Computers & Internet
  • 15 Answers
Take the case off your computer. There are either 2 or 4 slots for memory. Depending on if all of your slots are full, you might need to remove your old memory in order to install the new memory. If all your slots are full, remove all the old memory. There are little switches on both sides of each memory stick. You will need to push the switches over in order to put the memory in the slots. Once you completed the installation, turn on your computer. Windows will automatically reconize the new memory.
Posted on Jun 18, 2008
Instal 8 gb ram toshiba e205 s1904
you need to open the memory door on the bottom of the laptop. remove the old memory by releasing the latches on each side of the memory board. the memory should tilt and then you can remove it. slide the new memory in and press down until the latches catch and the memory is secured. close it up and go into the bios and save the new memory settings. restart normally.
Mar 22, 2013 | Toshiba Satellite E205-S1904 Laptop
I have a Dell XPS 410 that tells me I have some sort of memory issus according to the dx lights and beeps. I purchased the memory directly from Kingston which is the correct memory according to Kingst
the memory for your PC must be installed in pairs and in certain slots. Did you install one memory module or two? HERE is a guide directly from dell on how to correctly install memory for your exact PC.
Apr 06, 2012 | Dell Computers & Internet
Sony dsc-w200 camera works fine until memory stick is installed
Memory sticks now have two types regular and HC. The memory stick is either nor or nand? The new high capacity nand flash cards can not be use in older cameras. Older cameras also have limits on the capacity that it can access. Read your manual to check out the size of memory stick it can use. Most stores sell large capacity memory sticks only good for new digital cameras. you may have to buy older flash cards on ebay.
Feb 09, 2012 | Sony Cameras
I installed two new 1 gigabyte memory sticks into a Dell Inspiron 6000, which previously only had 2 256 megabyte memory sticks installed. When I first installed the 2 gigs of new memory, the laptop turned...
Once you installed the memory, did you enter into the System BIOS Setup screen? Do this and verify that the system recognizes the newly installed 2GB RAM. This should let the system access the new memory once you boot.
Jan 01, 2011 | Dell Inspiron 6000 Notebook
I put a new memory chip in my lartop and the
thus the chip you installed are compatible to your system? did you check the specification, try to remove what you installed and put back the old ones, see if it work
Nov 14, 2009 | Acer Aspire 3680 Laptop
Monitor displays no signal after I installed a new memory chip
remove the memory that you installed...see to it if the memory has the same speed... thanks...
Nov 13, 2009 | Acer 22" X223w LCD Monitor
I need to solvthe problem of my new install memory
According to the specs of this motherboard, it supports DDR 333/400 and DDR2 533/400 memory modules. It does not support DDR2 667 memory modules.
DDR 333/400 memory modules can be installed in the yellow slots, whereas DDR2 533/400 memory modules can be installed in the blue slots.
Only one type of memory modules (either DDR or DDR2) can be used. Mixing of different types of memory modules is not supported.
Jul 11, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
INSTALLING A NEW MEMORY CARD
Ram open the tower with power off you shuld have 2 or 4 slots for memory add your new one then reboot
Jan 25, 2009 | HP Compaq Presario SR1420nx...
P4m800-m7 Rev:3.1 RAM PROBLEM!
the problem is with the new ram.
its phsically damged.
may be little bit that you cant see it.
try checking the other 1GB ram.
Nov 08, 2008 | EliteGroup P4M800-M7 Motherboard
Gateway sb-4100-b won't recognize new memory
Check the owners manual of your computer for the correct installation of 2 sticks of memory, this can be critical on computers with 2 banks of 2 slots, it will also tell you the maximum ram that will work. If you do not have the manual, go to the manufactures website and then go to the support link, and browse for memory installation. BPCS
Dec 28, 2007 | Gateway Sb-4100-A PC Desktop
Computers & Internet Logo
63 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
