Question about Microwave Ovens
I have a small rowenta hot tray, and on the back it is marked WP04. I have misplaced the cord. can i purchase nother?
What does e3 mean on a Samsung microwave
Temperature of exhaust air too
High
Let it cool down?
Cause:
The oven cavity gets too hot due to excessive
operation with no load or small load, or due to
some blocking materials around the Air Filter or
Air Exhaust at the back of the oven.
Remedy: • Open the oven door and check if 1) the oven
has been operating with no load or too small
load, 2) the air filter is placed in a wrong
position, or 3) any blocking materials exist
around the Air Exhaust. Cool down the oven (for
approx. 30 min) under the normal temperature.
The oven is back to normal when the error
code "E3" disappears and "ON" appears again
in the display window.
• Unplug the power cord, remove the blocking
materials around the ventilation openings, cool
down the oven (for approx. 30 min) sufficiently,
plug the power cord in again and check if the
error code appears again.
• If the symptom persists even when the oven is
cooled down sufficiently, contact the nearest
service centre
Jun 26, 2014 | Samsung MW1080STA Microwave Oven
I need a replacement cord for a H-134, Series J hot plate, where do I find one
You are in luck because most small appliance cords are pretty generic. You can go on line, do a web search " replacement power. cords small appliances". Also you can go to a local 'old fashion' hardware store. They will probably have it.
Jun 02, 2014 | Salton Microwave Ovens
What would cause the glass tray in the microwave to shatter
  • The glass tray had a hairline crack or stress fracture that was not visible
  • It got a little too hot in one area
  • The expansion from the heat caused the fracture to expand and therefore crack and break
An accidental bumping of the microwave plate on the countertop while going from the microwave to the dishwasher might set up the above situation. The spoon your seven year old left in the mac and cheese might have arced and nicked a small piece of the glass. Whatever the cause, microwave trays break and they break for a lot of reasons.
All foods cooked in the microwave produce heat. Microwaves themselves are not hot, but the foods cooked in a microwave get hot - some much hotter than others.
Even though most microwave glass trays are tempered, they are not designed to hold up under high temperatures. You will see most microwave trays stamped with the words "For microwave oven use only" This is to let us know that it's probably not a good idea to use the trays in a conventional oven.
Any air pockets, cracks or gaps in the glass can enlarge under heat. Since glass isn't very receptive to being stretched, breakage can occur.
for more you can read on this link
http://www.ebay.com/gds/Why-did-the-glass-tray-in-my-microwave-break-/10000000003014864/g.html
Aug 27, 2013 | Goldstar Microwave Ovens
Need replacement cord for Salton food warming tray #H6
You can contact Salton here or here or e-mail consumer_relations@toastmaster.com
Oct 18, 2012 | Microwave Ovens
I have a Foodsaver 3420 and the Tray Full light stays on. I have cleaned the moisture tray several times and it it very clean. I even cleaned the contacts. With the Tray Full light on the sealer will not...
Place a small piece of electrical tape over the contacts on the fluid tray. This will allow the machine to operate but you'll have to manually check the tray for liquids/cleaning.
Jun 24, 2011 | Microwave Ovens
Hello, I have a Rowenta Prelude kettle - the tiny plastic pieces on the lid have broken so the lid cannot flip backwards and forwards. Where can I get a new lid please
Hi Lesley,
It's difficult to be more specific in assisting you as you don't specify which country, town or state you live in.
You should be able to find a local dealer by going to http://www.rowenta.com/rowenta/frame.aspx
& specifying your country in the drop-down list, then specifying your residential area.
Best wishes,
Graemevm
May 03, 2011 | Microwave Ovens
How do I get black marks from the sole plate of my rowenta iron 2600w
Here is a tip that will help you with cleaning the sole plate of your iron...
Cleaning a Steam Iron Soleplate
heatman101
Apr 05, 2011 | Microwave Ovens
I have one of the Cook's Essentials small Steamer/Deep fryer unit that I purchased on QVC. I loaned it to a friend to try and they LOST the cord!!! I am looking for a new cord. Thanks, Jean
this is obvious but did you visit's cook's web to see if you can purchase a new one? if you memorized the socket appearance and/or print out a digital picture of it, you could scrounge thru thrift store electronics boxes to try to find a match. this has worked well for me when my cell chargers have died and needed replacement.
many such cords are universal...good luck
Oct 06, 2010 | Microwave Ovens
Where is the fuse located?
If the model number is correct, there is a small input line filter board with a 125V, 20 AMP line fuse inside the microwave. Its usually mounted on a small input line filter board at the point where the power cord enters the back of the unit. You will need to UNPLUG the microwave oven and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
http://pcappliancerepair.com/model-display.php
The line filter is listed as item 1420. The fuse will be mounted to this board.
You can purchase replacement fuses at any hardware store. You can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Slow Blow fuses are recommended.
If you have any questions, or need assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit.
Apr 24, 2010 | GE JES1290 Convection/Microwave Oven
My Cuisinart Microwave's carousel doesn't turn. The heating function works fine. Can this be repaired?
This could be a very simple repair. The carousel is rotated by a small motor located under the bottom panel of the oven. This small motor has a coupler attached to it, that the glass tray sits on. The motor can be accessed by performing the following steps:
1. Unplug the microwave oven and open the oven door. Remove the glass tray.
2. Remove the small coupler by pulling straight up on it.
3. Close the oven door and locate the bottom panel screws UNDER the microwave oven.
4. Remove the screws and the bottom panel will open (some are hinged from the back).
5. Remove the connector plug and mountuing screws to the motor and that's it.
6. Re-install new motor using the steps provided in reverse order.
NOTE: This repair can be performed with the oven in place if it is mounted above a range. No need to uninstall. Just make sure the power is turned off to the unit before servicing anything inside.
Replacement motors can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
repairclinic.com
All these sites offer great service, with competitive pricing, so shop around for the best deal. If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Aug 18, 2009 | Microwave Ovens
Microwave Ovens Logo
69 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
