Question about Dryers
Replace thermostat SDE305DAYW - Dryers
  • Anonymous Aug 16, 2008
    My dryer has stopped drying. I cleaned the whole dryer, the lint trap, and vacuumed under the drum on the inside, and changed the dryer hose about 6 months ago. Everything is clean and air flow to the outside is strong. I called an appliance repair center and they will not be able to come for 1 week. The gentleman I spoke with told me it was a heating element. I have had heating elements in other dryers go out, and I do not believe this is the case. I dried a load of cloths and they dried just fine. About six hours later, I went to dry another load of laundry, and the drum turns, but there is not heat. Do these dryers have heating elements?
  • 246 Answers
To replace a thermostat, 1st unplug the unit. Next remove the bottom panel (2 5/16 screws) The part under where your lint screen goes is your is your lint duct. Next to it on the right and back just a little bit is your thermostat. Most people change a thermostat when there are other problems causing long dry times. Check your vent to make sure it's clean and flowing well. Make sure your vent hose behind the dryer is not kinked or bent. Clean your mositure sensors (the silver bars on the inside of your dryer drum) by rubbing them with the abrasive side of a sponge or a smooth sand paper to remove the clear build up from detergents and dryer sheets. Lastly check the area underneath your lint screen. Is there much build up? This can be mostly cleared just by using a long thin vaccume cleaner attachment.
Posted on Jun 18, 2008
My maytag legacy dryer SDE305DAYW has a very loud squeeking noise when I start the dryer. After a minute or 2 it stops making the noise. Is this the belt?
While I would suspect the belt also, it could also be the drum bearing since they both could have the same symptoms. Suggest you try to turn the drum by hand and see if you can hear it then.
Aug 13, 2011 | Dryers
Need to put on a plug to a dryer don't have manual dry model is Maytag sde305dayw 3wire
Hi denn1s200020...
Go to this webpage and you will find the picture you need.
Free answer, Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
May 28, 2011 | Maytag Dryers
In my Maytag dryer model SDE305DAYW the heating element works; however, the tumble drum stopped moving. What's wrong?
This sounds like the drum's drive belt broke. But also ensure there isn't a problem with the drive motor. Do you still hear a motor running when you turn it on? If so, you'll need to replace the drive belt.
I hope this helps! :)
Dec 15, 2010 | Maytag HYE3657A Electric Dryer
Maytag electric dryer - style #SDE305DAYW - loud squeal - is there something I can check on my own - or should I call for repair?
The wheel nearest the vent will get all squeaky because the heat will disipate the lubricant. Open the machine and oil them rollers. Install rigid flex vent pipe as per manufacturers recommendations to prevent over heating that roller. Use hvac approved temp resistant zoomspout turbine oil from ace hardware stores.
Some repair pix
Dec 16, 2009 | Heating & Cooling
The timer on my maytag dryer model# sde305dayw will not advance. i bought a new timer same as old one but it still will not advance ?
Could be you have a bad cycling thermostat or temperature switch.
Let me know if you want to troubleshoot further and I can help you.
Dec 16, 2009 | Dryers
I need help replacing maytag dryer belt model no.sde305dayw . I am having a problem getting around the pulley maytag dryer
The Link below will show you the configuration for all dryers. Choose the one that looks most like yours keeping in mind that some dryers are made under several different names: Good Luck
Belt Configuration
Nov 12, 2009 | Maytag Dryers
I have a Maytag Legacy Dryer SDE305DAYW that is squeeking. How do I change the belt?
the belt is not causing the squeek. either the tub rollers, or the idler pully is squeeking. you must remove the front panels and drum to inspect these parts. usually when a roller or idler pully is squeeking, you need to replace them. if they arnt to worn, you can clean the shaft and grease them to stop the squeek, but i dont recomend that, as it will just be a temporary fix and will start squeeking again. this isnt a easy repair if you've never done it. let me know if you have any further questions. Shane
Jun 19, 2009 | Dryers
Maytag SDE305DAYW
hi thanksfor the question the noise that you hear could be the blower wheel this is a very common problem with maytag the blower is located at the left front
Sep 22, 2008 | Maytag HYE3657A Electric Dryer
Maytag model sde305dayw
Check your fuses or breaker...If you have fuses, replace both 30 amp fuses. If you have breakers, flip breaker to OFF then back to ON, then try your dryer to see if it heats.
Mar 20, 2008 | Maytag HYE3657A Electric Dryer
Dryers Logo
177 people viewed this question
Top Dryers Experts
