Question about Canon PIXMA MP210 Photo All-In-One Printer
Paper is not loading properly - goes in at an angle when the feeder starts - doesn't print properly and the out of paper sign flahes up
  • Canon Master
  • 17,130 Answers
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
The advice/tip given is with the belief that you are competent. You must attempt to do it yourself only if you are technically/logically able, especially when dealing with delicate devices, damaging while trying to open, Probing electrical/electronic circuits with high voltage or delicate components. Since the advice given by me is with the inputs provided and not based on a visual inspection, there can be further reviews required in some cases.
Posted on Nov 12, 2010
KONICA BIZHUB C250 DOCUMENT FEEDER PRINTING ON ANGLE
Clean the feeder paper feed,separator roller with cloth and alcohol.
Feb 01, 2013 | Konica Minolta bizhub Office Equipment &...
"Load paper"
hey not a big problem. its usually encountered by many users.
i too get this many times.
this happens when you keep papers freshly.
it needs to sense the papers kept.
now what you do is just keep more papers or try re-aligning the papers kept inside
Dec 27, 2007 | Ricoh Aficio CL2000N Laser Printer
How do i fix my LEXMARK X3430?
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
If that doesn't help, try to re-seat the cartridges by removing and re-inserting them into the printer. Make sure they are properly seated and secured.
I hope this helps.
Feb 17, 2012 | Lexmark X Office Equipment & Supplies
The sheet feeder of the canon IP880 doesn't work properly
Hi all of you,
Clean carefully the ruber feed roler. use brush, water and detergent .
thanks
Hamedo
Nov 17, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
How do you load paper into the printing calculator?
Cut paper at a 45 degree angle and load into back slot with angle (apex) of paper to the right of machine when facing it. Be sure to push it thru when loading. You should see tip next to calculator number wheel. Hit the additon sign several times to advance. You may need tweezers to pull paper thru if it doesn't advance by itself.
Oct 10, 2008 | Canon P23-DHV Calculator
Loading paper
Cut paper at an angle and insert and push into back slot with tip of angle (apex) to the right of machine when facing it. It should engage number wheel when you hit addition sign, You may need tweezers to pull it thru if it doesn't advance.
Jun 20, 2008 | Canon P23-DHV Calculator
Unable to print properly keeps printing on one line
Sounds like there is something jammed in the paper feeder, or maby its the paper feeder itself. Check to see if the path the paper follows through the feeder is completely clear. Sometimes paper is left in the feeder from previous paper jams.
Aug 07, 2007 | Lexmark X73 All-In-One InkJet Printer
Reply to question
It sounds like it may be a part of your paper feeder. Hope it is under warranty. The fact that the printer only started to grind and bang when it appeared to feed the paper at an odd angle points to this to but... Is the part the same colour as the inner printer workings you can see down where the paper loads. Do you have a 2 year old in the house as they like to feed things down holes!!! It may have been a foreign part from another toy!!! Believe me this happened to a friend of mine. They had to replace the paper feeder.
Feb 13, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP210 Photo All-In-One Printer Logo
60 people viewed this question
old marine
old marine
