Question about Dishwashers
Frigidaire dishwasher impeller melted! Can't find replacement part!
I have a Frigidaire 18" dishwasher model #FDR252RBS2. The plastic impeller attached to the top of the motor has melted where it attaches to the drive shaft of the motor. In the manufacturer's diagram this impeller does not have a corresponding number to reference it to a part number. I would like to know if it is possible to buy just the plastic impeller? Or do I have to actually buy a new motor (assuming the impeller comes with the motor)? The impeller itself is 3 3/8" wide, flat on the top, and has 1/4" deep fins on the bottom. I really hope you can help me! Thank you!!!
I have the same problem and after talking to a local service center and doing some online research (remember: Google is your friend) I have discovered this is considered a non-serviceable part and you must buy the entire motor. The impeller comes with the motor. This is probably not the answer you were hoping but is what you have to do. With that said, I plan to JB Weld the ****** back on the motor shaft!
Posted on Feb 11, 2009
Lower spray arm dislodged during wash cycle
Hello Megan Quintas,
I have had the bottoms of the Frigidaire DISHWASHER rotted out AND their center-shaft NEVER LOST IT'S vertical alignment...
So my personal opinion...
You are good once you replace your defective spray arm..
Put your model+make+spray+arm
or better yet the ORIGINAL PART NUMBER to get three estimates...
Good luck, happy hunting!!
- Some example parts houses:
Sears (priciest... but improving)
appliancepartspros.com
partsselect.com
Water Filters Lawn Garden Appliance Parts
Search Over 2 1 Million Appliance Parts
PartSelect Appliance Parts and Repair Help
May 12, 2016 | Frigidaire Dishwashers
How to fix Frigidaire FDR252RBS2 Dishwasher leaving standing water at end of cycle?
Check drain line is not bend or blockage. Can be bad inlet water valve. Replace you ll be fine.
Mar 03, 2014 | Dishwashers
I have a Frigidaire Gallery dishwasher with model # GLDB958JB0 and it started to make a screeching noise only after a few mins into the wash cycle. I took out the filter and made sure there was noting...
Hello & Welcome to FixYa
The problem is with the impeller or the chopper assembly that is causing this screeching noise. You can take apart the bottom front access panel and clean the drain pump assembly completely and check for any broken parts inside that need replacement. If the problem returns then replacing the impeller/drain pump-motor assembly is recommended repair. Please get back to me if you have any other questions.
Kevin
May 12, 2011 | Frigidaire Dishwashers
The Plastic Dishwasher Flatware Baskets Being ''Eaten/Melted''
Check to see if the electricity supplied to the drying elements is connected at the back of the dishwasher. If so, this would be the hottest spot in the dishwasher during the dry cycle. Most dishwashers have the flatware baskets located on the sides; not the front because of conflict with the detergent holder, or the back because of higher heat or (on newer models) a power scrubbing feature. See if you can put the flatware baskets on the sides. This should help.
In any case, the baskets should not be melting wherever they are located. This could be fire hazard.
Oct 24, 2017 | Kenmore Dishwashers
My Frigidaire dishwasher gets so hot inside it melts plastic cups. What can I do?
We have the same problem one morning we got up and everything was melted even the sprayer arms. we had an extended warranty they're going to replace the control board and the melted parts. it also warped the tub.
Mar 23, 2010 | Frigidaire PLD4555RFC Dishwasher
18" frigidaire dishwasher wont drain
sears have a site to see all of the parts and get part # and price. the site is sears parts direct. let me know if this is helpful.
Feb 26, 2010 | Frigidaire 18 in. FDR252RB Built-in...
Not Draining
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer/control board
Replace if defective (note: uncommon problem).
Sep 15, 2009 | Frigidaire 18 in. FDR252RB Built-in...
Burning Frigidaire dishwasher
After you turn off the power to your dishwasher, you can inspect the dishwasher with a flashlight to find where the melting happened. If it is near the circle that is the heating element, you can suspect the timer froze during the drying cycle.
But also open things up and look for shorted/melted wires (in the door panel and under the dishwasher.)
No matter what you find, if you have proof of purchase for your dishwasher, I would press for repair/replacement from the manufacturer.
Good Luck!
May 02, 2009 | Frigidaire FDB1502RG Built-in Dishwasher
Dishwasher had a burning smell and smoke was coming out
If the smoke was coming from inside the dishwasher... A common problem is a plastic item , utensil etc has fallen down onto the heating element. During the drying cycle this could possibly melt the plastic and generate some smoke.
Jan 04, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Dishwashers Logo
427 people viewed this question
Top Dishwashers Experts
