Hello..disconected from battery the B9010 navigation radio for a toyota hilux and now the radio is not working.. need a cd to decode..
  • 28 Answers
SOURCE: radio code ford mondeo!
try 4333 this should work
Posted on Jan 18, 2009
  • 31 Answers
SOURCE: need radio code for 1997 chevrolet lumina
try 1234 or 5678 or 0000
Posted on Apr 10, 2010
  • 4869 Answers
SOURCE: Hello I have radio Mercedes Benz CD(Becker)and i
Sorry...this code will only be available from your Main Dealer or a Radio Decoding Service
Posted on Jun 19, 2010
muntejaya
  • 10421 Answers
SOURCE: toyota hilux needs security code
Please get the code here :
www.solware.co.uk/download-products/unlock-car-radio.shtml
Regards, Jay__Oknhv
Posted on Feb 24, 2011
  • 11800 Answers
SOURCE: hello i had a flat
1) To remove the security SEC warning hold down the "TUNE" button and then press "1"
2) Use the numbers 1 2 and 3 to type in the last 3 digits of your VIN number- press them as many times as necessary to display the corresponding code number.
3) Quickly hold down "SCAN" button, the radio will power off, then press the volume button to turn it back on.
Posted on Mar 28, 2011
Toyota hilux vigo 2014 radio and power window not working after removing the battery
I gather that you put the battery back in? You need to check all the fuses and connections and also unhook one of the cables on the battery for a minute and then reconnect to make sure a surge did not lock something in the BCM up.
Aug 18, 2017 | Toyota Cars & Trucks
Theradio/tape/cd no longer works. I confirmed that it has 12 volts to the connector. Is there an anti-theft code that shut it down when the voltage was interrupted during the battery change?
Sounds like it needs the code inputting, mine did the same. Now, what the code is?????
Maybe if you post the make and serial number on here someone may be able to help. It maybe written down in your manual etc.
Apr 19, 2016 | 2003 Toyota Highlander
Stuck CD in JBL 4 disc CD Changer / Navigation
before you press the cd on button keep holding the eject button while you press power on, I know this works for computers etc.
Feb 13, 2016 | 2013 Toyota Highlander
I need a code for my ford ka radio please help serial number m020277
Hello Friend,
According to this site. http://www.pumapeople.com/decode.php Your radio code should be 7779 ..... Please, let me know if this works for you.
Best Regards from Wade
Aug 15, 2014 | Cars & Trucks
Toyota 2007 hilux ute changed battery radio does not work
If you have an aftermarket radio there is probably a wire going directly to the battery and that wire has a fuse. These fuses are very sensitive. Fuse or Wire.
I hope this helps.
Oct 21, 2013 | Car Audio & Video
Where is the fuse for the clock radio cig lighter in a toyota hilux 1993 model
Made a short circuit here radio, cig lighter ,air Con ,clock, windows, indicators are not working but hazards are working it is a toyota hilux
Oct 17, 2012 | 1986 Toyota Hilux 2200
1997 toyota 2.7 petrol hilux.Radio absolutely fine.3 stack CD changer not working,comes up with ERR1 message,does this mean a new cd player or can it be fixed
Hello, it sounds like the laser is faulty in the cd. These can be fixed and shouldnt cost too much. After a while, and sometimes straight away, the lasers go as they are the weakest part of the system. Your technician should have no trouble in getting the parts and repairing it as good as new. Good luck.
Mar 28, 2011 | Audio Players & Recorders
Need master code for radio in a 2000 ml320
Regretfully due to reasons of theft or piracy we do not pass the radio codes here at FixYa. If you contact your local Mercedes-Benz dealer they will give you the 5 digit code. (You must have your registration and know the complete serial number of the radio)
Kelly
May 05, 2010 | 2007 Mercedes-Benz ML320 CDI
How do you enter radio code on 05 Toyota hilux
the battery was disconnected on the 07 hilux and the radio/sat nav just asks for the correct map disk to be inserted but the map disk is in it and it doesnt do anything...
Feb 18, 2010 | Toyota Vehicle Parts & Accessories
Disconected battery and lost the radio code
First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here  for free then the radio will have to be removed from the dashboard (and if you are lucky, someone may have written the code on the casing ) .
If not then
POST ANOTHER QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
Also quote the MAKE of CAR
note: Unfortunately not all radios can be decoded using the Serial Number
If not then try your Main Dealer ...........or take it into a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM). This takes a few minutes and shouldn`t be too expensive
Oct 12, 2009 | Radio Communications
Computers & Internet Logo
201 people viewed this question
David Payne
David Payne
