Question about Morphy Richards 43072 Cordless Electric Kettle
How do I remove limescale from inside an elecric kettle?
    New Friend:
  • 81 Answers
Removal of limescale from inside an electric kettle is very easy one simply needs to use hot water for it. Simply pour it there and keep it for half an hour, then you will see that the limescale is scrapping off and Voila your problem is solved. For more details, please click here:
Top 5 Best Electric Kettle
Posted on Jul 23, 2015
    Genius:
  • 1,672 Answers
You could buy in any grocery shop and in the net any brand of KETTLE and THERMOS DESCALER! Just put it in ur electric kettle and leave it for a day, it will disslove those lime scales! Taah!
Posted on Nov 12, 2010
Filter replacement
Remove limescale with vinegar. A thorough job will clean filter too!
Feb 17, 2014 | Morphy Richards Accents 43836 Jug Kettle,...
Tip
How to clean out your stovetop kettle
I've been using the same kettle on my stove for about a year and I hadn't cleaned it even once until last week.
A while ago I started noticing these weird white chucks that would come out with the water but I just figured that it was because I get a lot of use of out my kettle.
It turns out that the white chunks are actually limescale.
I did some research on it and thankfully limescale is not harmful to ingest. However, it's pretty gross to look at and I certainly wouldn't want to serve a cup of tea to a guest that is filled with strange white flakes.
So I figured out how to clean my kettle with stuff I have at home.
All you need is some regular cooking vinegar to do the descaling for you.
There is no need to buy expensive chemicals that you wouldn't feel safe using on a cooking product anyway.
Start by rinsing out your kettle with warm water.
Then, fill half of it with water and the other half with vinegar.
Place it on your stove and let it come to a rolling boil.
Then, just leave it there over night.
When you wake up in the morning, dump out the water and vinegar solution.
Take a long scrubbing brush and scrub the inside of the kettle to remove whatever limescale is left.
If there is still some caked on, you can repeat the steps over again.
If your kettle is clear of the grime, simply rinse out a number of times with soap to get rid of the vinegar taste/smell.
Voila! Your stovetop kettle is clean and no more unidentified chunks in your tea!
on Jan 06, 2014 | Home
How do you clean the inside of your metal kettles
if you wish to remove limescale, then you can use limescale remover either liquid or powder.
follow directions on the product of choice.
alterativly use vinager, just pour undiluted vinegar into the kettle and let it rest for a while until it no longer produces bubbles. then rince well.
if there is still limescale then repeat the process.
Note
do not let the kettle boil with vinegar or limescale remover in it. they may cause a fault and some
very bad smells.
I hope this was useful..
May 23, 2011 | Morphy Richards 43691 Cordless Electric...
What is the best way to clean this kettle - particularly the rim in the top where the limescale has built up and the resin base
Fill it with vinegar and leave to soak overnight/for two nights if really bad.
Any parts which are impossible to fill with vinegar - lids/spouts, soak a cloth or tissue in vinegar and wrap/wedge into....and leave to soak overnight.
Dec 06, 2010 | Alessi MG32 Cordless Electric Kettle
I have an Edinburgh (I think) kettle which I have been very happy with, but now the switch will not stay down, occasionally I make connection. What can be done?
The switch is operated on what is called a thermocouple - the most lightly problem is lime scale. Get some limescale remover from your local hardware. or you can use spirit vinegar and boil the kettle a couple of times. Give it a really good clean afterward or your coffee will taste awful! Good luck.
Aug 11, 2010 | Russell Hobbs RHOK3123 Cordless Electric...
Where can I get a new filter disc for my alessi bird kettle
Dec 07, 2009 | Alessi 9093 Cordless Electric Kettle
Smell and taste from water after it has been boiled in kettle. Water from tap, or boiled in a pot has no taste or smell. We are ina soft water area and have no limescale. anyone else complained?
It must be the kettle causing the problem from what you say. If th e kettle is new the problem should reduce with use but if it is old it will get worse (possibbly due to rubber washers/seals perishing)
Oct 17, 2008 | Le Creuset Kone Electric Kettle
Kettle
Here is a link to instructions for a commercial kettle.
It tells how to clean and maintain.
I hope it helps.
http://www.blodgett.com/Literature/Manuals/Steam/KLS-E%20&%20KPS-E-man.pdf
Feb 08, 2008 | Market Forge Electric Table Top Kettle - 4...
Siemens porsche kettle om switch problem
Some switches are called momentary and others are the click on and click off type.
It could be a problem with the switch if is is the click on type.
It could be a relay that "seals in" when you press the on off switch to on.
By "seal in" I mean, the kettle is wired so that when the relay coil energizes, it closes a contact when it is electrified and becomes an electric magnet and the energy that was going through the on off button, is now going through the closed contact on the relay.
If you don't here a clicking sound like you used to, it could be a fuse inside inside of the electrical box on or by the kettle.
I don't know by the information, if this is a household small appliance or commercial?
Even if household, it should have the same basic setup.
This may be of some help to you
What About The Kettle?
Despite being metal the kettle is cool touch (a tough special grade plastic interior). A good safety feature is that the kettle will only switch on when the lid is closed, there is a special lid release button. The kettle also has automatic overheat protection. Of course the kettle is cordless and has cord storage in its base. Water quality? Well, it's better if you use filtered water, but with this kettle it is even better - it has a removable stainless steel limescale filter in the spout!
Feb 04, 2008 | Kitchen Appliances - Others
Morphy Richards 43072 Cordless Electric Kettle Logo
389 people viewed this question
Top Morphy Richards Kitchen Appliances - Others Experts
Oloyede Monsuru
Mike
Are you a Morphy Richards Kitchen Appliances - Other Expert? Answer questions, earn points and help others
