Question about Linksys WAG325N Router (WAG325N-AU)
The lan ports do not work but the wireless works fine.
  • dssdbusiness Nov 12, 2010
    Just to add to this, I opened up my router and found out that 5 caps have bulged. Which shows those needs to be replaced.
    I am going to buy them and give it a try.
    But folks, it is very difficult to solder them to the board. i lucked the caps without soldering iron and will be soldering on top of without tampering the board underneath.
  • 1,719 Answers
I think that the router is just fine.
The issue could be with the LAN card of your PC of perhaps a faulty cable. So, my advice is to check the cable and lan card of your PC. You may use a different/already working cable and a laptop for diagnosis. Note that status of LAN connection is indicated by the LEDs at the front of router and LAN connection of the PC. If the LED indicates connection, then it could be the configuration issue.
Hope this helps!
Let me know if i could be of any further assistance.
Posted on Nov 12, 2010
  • tron07 Mar 22, 2011
    I am having the same problem with this Linksys WAG325N Router.
    The LAN ports are not working, not getting an IP via DHCP for the PC. I try putting IP manually and ping my laptop it doesnt connect (destination host unreachable), but it can detect a IP conflict if put the same IP with the wireless laptop IP. Tested with different cable and laptop NIC as well. Havent open it up to see if the capacitors faulty or not.
  • wildfire2004 Jun 09, 2011
    I had this problem - I found that it can not connect 100 mbps. However if you manuall configure the LAN to 10 mbps it will. I think this a common problem with this router.
My MSI wind U140 not detect my ethernet after installing windows 7 ultimate lite version
Go to the MSI web site & download the LAN drivers.
Which will be under the support tab, then select your make & model of PC.
then select the OS you have installed (in your case windows 7 ultimate)
download & install.
Jan 30, 2012 | Computers & Internet
I have the wireless router WTR54GS. My laptop was working fine and then it won't work. I have also tried to connect a wireless printer and I can't do that either. The wireless card on the laptop has been...
Plug in a utp cable in a lan port (there are 4 ) from the router.
The other plug in the lan port from your laptop.
Open a dos window and type ipconfig.
There you see a set of numbers like 192.168.1.1
Open a webbrowser, and type in the adress http://192.168.1.1 or the adres wich you found.
Now you are in the router webbased configuration. You need your login name and password, usual something like admin and admin.
There you can set all of youre wireless settings.
Mar 22, 2011 | Computers & Internet
LInksys WRK54g-wireless connection works fine, but cannot get LAN
You might have faulty LAN ports on your router or your network cable is bad.
Jan 23, 2010 | Linksys Wireless-G Broadband Router
No wireless on Time-Warner cable. LAN works fine
Yes, from what I understand you need a special router to go wireless with timewarner, just another way coporate America dicks the regular guy.
Dec 18, 2009 | D-Link DIR-615 Wireless Router
Configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
Canon MP600R printer won't work with wireless
You have to make sure the ip address is correct on modem and computer port
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
Jun 15, 2017 | Canon PIXMA MP600 all-In-One InkJet...
D-LINK DI-514 LAN Ports not working
  1. Connect a cable from your PC to one of the four plugs. Not the WAN port.
  2. Setup the wireless the way you want it.
  3. Then give this router a different IP, like 192.168.0.2
  4. Then you have to disable the DHCP server in the router (keep in mind now you have to set your desktop or laptop that is conencted to it to a static IP to still communicate with the router)
  5. Once this is done just plug you existing network into one of the four ports. Not the WAN port.
  6. It will now act as a wirelessa access point.
Althoug this is doable it is not recommended as this router is a pile of **** and the wireless is crappy.
I would suggest a dedicated wireless access point.
Dec 06, 2008 | D-Link DI 514 Wireless Router (DI-514)
LAN ports not working
make sure that the local area connection in the computer is enabled and that the drivers of the ethernet adapter are working properly.
try to reset the router by pressing the reset button for 30 seconds then if the problem still persist then that means the router should be replaced already.
Aug 09, 2008 | NetGear DG834G Router
Belkin Wireless-N Wireless Router with 4-Port Switch F5D8233-4
It will work just fine, I had the same info display when I was w/ Time warner.
Apr 28, 2008 | Computers & Internet
Linksys WAG325N Router (WAG325N-AU) Logo
490 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
