Question about Intel D865GRH (KD865GRHLKPAK10) Motherboard
My computer have no volume controler and do not voice
  • 242 Answers
Search for newer drivers
Posted on Nov 12, 2010
I have a toshiba equium tryin to set up microphone but no matter which option i use it wont recognize my voice
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 23, 2011 | Toshiba (P000257700) Microphone
People can not hear my voice but I can here them
You need to enable your microphone
Click VOICE
That should be it.
Feb 22, 2011 | Logitech USB Desktop Consumer Microphone
New microphone will not record...please advise.
There are two separate settings in control panel for record and playback - see below
Click VOICE
That should be it.
Feb 20, 2011 | Dynex Voice-Certified PC Desktop...
My microphone on my laptop does not work i checked everything test it nd cnt hear my voice..?
Click VOICE
That should be it.
Feb 16, 2011 | Toshiba (P000257700) Microphone
I just installed my vestax typhoon and the drivers. everything seems to be running fine but i can only listen through the headphones plugged into the controller. no sound comes through my laptop speakers....
Make sure the Windows computer has the audio output selected to use the computers output hardware.
In the control panel, under "sounds and devices" pane, VOICE tab, that the Voice playback window shows your COMPUTER's audio system AND then check the volume is turned up by clicking the Volume button right under that same window. Now do the same under the AUDIO tab at the sounds and devices pane.
Feb 11, 2011 | Vestax Typhoon USB DJ MIDI Controller with...
Why i cant talk in headphone i can hear the voice in computer. i installed nymgo talking internationally i can herta the voice but i cant speak the speaker placed in my mouth does not have voice
Click on start->control panel->sounds and audio devices->audio tab->under sound recording click on volume tab and uncheck mute all and anyother mute.
Oct 03, 2009 | Audio Players & Recorders
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
Microphone
  • START
  • Control panel
  • Sounds and audio devices
  • Advanced (Under "Device Volume")
  • Options
  • Check Advanced controls
  • On same drop down menu click Properties
  • Under "Show following volume controls" check Microphone
  • Microphone volume control should appear
  • Uncheck "Mute" below mic volume control
  • Move slider up
Now also do this:
  • START
  • Control Panel
  • Audio
  • Under "Sound recording" select device in which you've plugged in your microphone
  • Voice
  • Under "Voice recording" select device in which you've plugged in your microphone
  • *If you're not sure in what you've plugged in your mic than select "Test Hardware" under "Voice recording".*
  • Click Apply, click OK
May 10, 2008 | Plantronics Audio™ 350 Headset
Unable to hear own voice via microphone, I can hear sound
For you to comunicate through Skype, you don't normally need to hear your voice when you talk. But if you want to you can.
Try to double click your speaker icon from the lower right side of your screen ( where you can find the system clock). A window will open and will show you several volume controls. From that window click the File and go to properties. From there put a check on the box beside the microphone. click Apply and Ok. Click the File menu again and this time put click Advance Controls. A clickable Advance menu will come out at the bottom of your Mic Volume control. Click it and enable the Mic Boost. Click Ok and then uncheck the mute box from the Mixer Window. You should be able to hear your voice or a strong feedback from your speakers.
Hope this Helps.
If it does, Please vote. Thanks!
Apr 19, 2008 | Computers & Internet
Intel D865GRH (KD865GRHLKPAK10) Motherboard Logo
27 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
