Question about GE WBB4500EWW Top Load Washer
GE Top-loader Leaks Water from Vert Tube Behind Tub on X-Large Loads
I actually have a WJXR2080T2WW model GE (3 controls/1 master - 8 Cycle 2 Speed), it's about 12 -13 yrs old. It just recently started leaking some water, mostly on X-Large Water selections, a little on Medium load and I believe it's coming from a Vertical cream opaque tube that's to the rear almost behind the washing tub on the left side. I don't know what this tube is for, it starts somewhere at the top of the machine (can't see it) and runs down to near the bottom of the washer chassis and then has a short 90 degree curve to an opening. No hose is connected to the bottom open end.
When we've had water on the floor after a cycle, this is the only place that there is water dripping from. None under the tub or the water pump. It does seem that the water level is a bit higher than normal on the X-large loads, but I can't be sure, not recalling what it looked like before. Medium loads water level appears normal, and we still get a bit of water on the floor from under the machine.
Would appreciate any educated fix-it experience or clues as to what the problem is and how to fix the problem.
  • 1 more comment
  • ksbrcupofjaz Jun 24, 2008
    Guess you didn't read my initial disclosure of the symptoms close enough. I was very specific about where the water is coming from and only during certain wash cycles - Small and large loads. I appreciate your suggestions, but they don't fit the circumstances that I outlined.
    I believe it has to do with how much water is being metered out (too much) by a mechanism in the washer. As if it's supplying too much water; but not knowing what does what behind the GE front panel or in the belly of the beast, I'm not about to start buying everything to replace. So I need someone knowledgeable specifically on this era and model series washer, and not some generic advice.
    Anyone out there KNOW the WJXR2080T2WW model GE washers and understand this problem? What has gone bad and where do I buy it.
  • porkster89 Nov 08, 2008
    I have same problem exactly. Turns out it is the white plastic triangle thing that houses a small white hose. It is called the hose and water inlet part number wh41x10078- now i just have to figure out how to put it on!
  • handygrrl Feb 16, 2009
    I had this same problem, I have a GE S2100 (top loading). In my case, the problem was a clogged flexible clear tube that runs from the side of the tub to the pressure switch in the electronics area by the dials in the top. The tube was partially clogged with some sort of slimy brownish goo (algae? Slime mold? Does it matter?). Due to this clog, the pressure switch was delayed in shutting off, thereby overfilling the tub. Once the machine started running with too much water, the water was sloshed into the overflow tube, (that white opaque tube from the tub that goes down the back of the tub has a 90 degree bend and then ends) and then out the bottom of the machine and all over the floor.
    All I had to do was disconnect the tube at the pressure switch, disconnect the other end where it attached to the tub and blow into it (with my mouth--into the much cleaner pressure switch end!) to clear the clog (actually, I also used a bobby pin to scoop out the goo). Then I reattached everything and my washer no longer over-filled or over-flowed.
    If you have the same problem and find that the tube isn't blocked, your pressure switch might be bad. Or the tube might be stretched or have a hole allowing air to leak in.These will cause the tub to be overfilled also.
    If you disconnect your air pressure tube, make sure the tub is empty when you reconnect everything. If there's water in the tub, you'll get water in the tube and mess up the air pressure and the switch still won't work right.
  • 525 Answers
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 22, 2008
  • David Emmel
    David Emmel Jun 25, 2008
    Sir,
    Thank you for the very kind rating on my job performance.The information that I provided came from an all-brands service technician guru, who has been very kind and unselfish to provide, at no charge, the parts and information technology, to assist a novice technician. Also, this advice is for all G.E. models, as the design is universal for all models, when it comes to the mechanical designs.
    It appears that your issue is unique and disimilar, as taken from your critique, since the advice did not appropriate your issue. I apologize for not recognizing that you are far more advanced than a novice status technician.
    If you clicked on any of the links provided in the text, it should have taken you to the exact place to find further information on your specific model.
    Fixya.com also, unselfishly, offers the same free advice and information given by volunteer technicians. If you desire guaranteed complete and total satisfaction, we offer a premium 1 on1 service option that will leave no doubt about your particular issue.
    Hopefully you will find someone who has experienced and can resolve the issue that you have so definitively described.
    Sincerely,
    Dave E. (Illeagle)
2 Suggested Answers
mikedurland
  • 481 Answers
SOURCE: GE Top-loader Leaks Water from Vertical Tube Behind Tub on X-Large Loads
it sounds like the basket is not locked when it is agitating, if so the water will climb the wall during the wash cycle and leak out of the overflow (which is the plastic tube you described). if this is the case, it is a transmission brake problem. it can be fixed by a professional, but you might want to look into buying a new machine.
Posted on Jun 27, 2008
What is the purpose of the flood hose? we have a ge wjsr2080t2ww washer. when we use the power wash cycle in super capacity mode as a minute after it starts agitating the water comes flooding out from...
the purpose of that tube so it anywater that comes out of it goes through it and directs the water down the back and away from the motor. Now the bigger issue is why is water coming through that tube.What i suspect the reason of that is that the transmission is defective and the break is that internal to the transmission is slipping so the inner tub turns during the wash cycle force water up the side of the tub into that tube.during the agitate cycle the tub is not suppose to move at all and stay locked into place,but instead its moving where the water is forced up by centrifical force too and out the top of the tub cover,if it leaks with only a small water load it will leak worse with a large water load. if this is what is happening and the tub is rotating on agaitate cycle teh fix for that is to replace transmission which in most cases cost as much as replacing the washer would be
Aug 04, 2011 | GE WDSR2080D Top Load Washer
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
My GE top loader leaks at the spin cycle when it is letting out the water
Sounds like the tub seal under the tub where the transmission goes into the tub. Replace the trans and seal.
Mar 15, 2011 | GE WBSR3140DW Top Load Washer
Hotpoint washing machine model vbxr1090b2ww leaking from bottom of unit
Here are some solutions.
Hope this helps you...Jim...Please leave a comment...Thanks!
LEAKS ALL THE TIME Is your GE washer leaking all the time, even when not in use? If so the problem is the fill hoses or the valve. Look behind the washer to see if water is coming from the hoses. If not, take the cover off to the control panel. Once off, you should see if the water valve and if there is leakage - it needs replacing (if it is leaking). This is the most popular water valve for GE top-loading washers made after 1995 and the part number is WH13X86 Order Here. show?id=6bjnatppuce&bids=92089.1&type=10. Note that some models have a water valve with more than two coils. In this case, you will need to order the valve by model number at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 Buy Fill Hoses Here. show?id=6bjnatppuce&bids=92089.1&type=10
LEAKS DURING FILL CYCLE Is your GE washer leaking during the fill cycle? If so the problem may be in the valve. Follow instructions above, only this time start the fill cycle before looking at the valve.
If your washer overflows with water during fill cycle your problem is the water level control or the water valve. If you must cut the water off from the house plumbing to stop the water then there is no need for testing, just replace the water valve. First, you need to turn on the washer. The washer should start to fill with water, now cut the washer off and on repeatedly (note to yourself whether the water turned off every time). If it does cut off every time you cut the washer off, then it's most likely in the water level control. If it keeps running after you cut the washer off then, the water valve is bad and needs replacing. (Note that the valve can stick intermittently so it still may be bad if it passed the test) Water valves can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0
If the water valve doesn't stick in the first test then you need to check the water level control. First, remove the front of washer (insert butter knife between the top and the front pushing on the clips) then look on the side of the tub and you should see a tube attached to a box. Remove the tube (make sure all the water is out of the tub) look in the tube to see if is stopped up. Often it will stop up near the end. If it is, you can clean it out with a toothpick. Once it's clean, reinstall it and your washer is fixed. If the tube is not stopped up reinstall the tube. Now set the water level control on the lowest setting and start filling the washer with water. If the water stops when the tub is approximately half full (this varies with every model) turn it up to the next level (you may have to reset it). Repeat until the tub is full. If at any the water level gets above the last row of holes in the tub, unplug the washer. If the water stops running when you unplug the washer, replace the water level control. If the water doesn't stop, turn the water off at the wall then replace water valve. Water level contorls and water valves can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 . LEAKS DURING WASH Is your GE washer leaking during wash? If so the problem is the tub seal (seals around the transmission where it goes through the tub), drain hoses (including the tub to pump hose) or the pump. First take the front off the washer (insert butter knife between the top and the front, pushing on the clips) then start the fill cycle. Now start watching until you see a leak. If the leak is coming from the tub seal, the transmission needs to be replaced (note that changing the transmission is expensive and takes special tools, so you may consider replacing the washer). If the leak is coming from the drain hose or the pump you need to replace it. If you don't see it leak at all, your soap may be the problem. To check this fill the washer with water and the amount of soap you normally would use. Then start the washer and watch the tube coming from the left back of the tub (the overflow pipe). If soapsuds come out of the overflow pipe then try cutting down on your soap or switch to another brand. This may fix your problem. These parts can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0
LEAKS DURING PUMP OUT Is your GE washer leaking during pump out? If so the first thing you should look at is the drainpipe (to your house plumbing). Fill the washer with water, and then turn it to spin and start it. Now while it's pumping, look at your drainpipe if water backs out (it may not back unless you have soap in the tub), then the problem is in your plumbing. If it doesn't, follow the same steps as above in "leaks during wash." Only this time watch for leaks during pump out as well.
Feb 13, 2011 | Hotpoint VBXR1090B Top Load Washer
Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Feb 03, 2010 | Speed Queen ATS90AWN Front Load Washer
Washer leaks now when doing large loads.
pop the front panel you can do this with a putty knife. where the top is 2 inches down you will see a creas use a flash light you will see the 2 clips push in on the clips and pull out you will be able to access where the tub is to see where the leak is comeing from
Jan 04, 2009 | GE WBXR3100B Top Load Washer
Removal of Spin Tube in Washing Machine
I doubt the ring could get over the tub top. If you want to remove the agitator, lift the bottom edge then atthe same time hit the top the opposit direction, pulling up. good luck
Dec 23, 2008 | Washing Machines
GE WJXR2080T2WW Washer Fills with water - then stops
older machine would have been easier to fix ..remove front ck small hose to tub left side remove hose and clean crud from end as much as possible if still overflowing replace water level control..new machine may be timer or lid switch not closing properly remove front to acess lid switch on right side
Jul 22, 2008 | Washing Machines
Jun 18, 2008 | GE WHRE5260E Top Load Washer
Maytag discharge into wastepipe backs up, floods laundry room.
best approach is be sure to clean drain pipe build up over the years may have created partial blockage
Apr 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
GE WBB4500EWW Top Load Washer Logo
755 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
