Question about Kenwood Dishwashers
Despite an engineer checking this twice it i not washing the bottom half and very poor onthe top only about year and a half old KDW243A
  • maureen anderson Nov 15, 2010
    IN that it gave me an instruction manual yes all other avenues suggested I had already tried
  • Kenwood Master
  • 19,396 Answers
Hi.
If a technician has checked the appliance, then I assume that we can exclude major faults. I also assume that you are not using half-washing option, from control panel, or the symptoms may be normal. Half washing is used only for light loads.
Ensure that you are not using any of the options: Soak, Rinse, Rapid, Light economy. This options are all for lightly soiled loads. If dishes are dirty they won't work properly. Ensure that you use Intensive or Normal program.
If the dishwasher is not cleaning properly, possible causes are:
1Poor water inlet.
Ensure that there is enough water at the bottom of the tub. Check level at mid cycle.
If water inlet is poor, then inlet hose and water level device must be checked.
2 Water not getting hot enough.
Interrupt the cycle in the mid, and check water temp. Using Intensive or Normal program, the temperature must be about 60/70 C (140/160F). If water is cold and there is a fault, then it is either inlet or heating system (depending if dual inlet), or thermostat.
3 Incorrect detergent or detergent drawer releasing too late.
Ensure that you use the right detergent (check manual). Detergent for full cycle is 22 gr. Ensure that detergent has been released and dissolved, or you have a problem with drawer opening.
4 No pressure in spray from arms orifices.
Check spray arms attachments and ensure that there are no big leaks. Clogged orifices in a one-year old machine is pretty unlikely. Ensure that spray arms are free to rotate.
If there is no other problem, then the pump should be checked for obstruction in the pump hose.
If problem is stains from hard water, then load new salt into reservoir, and regulate the reservoir cap to release more salt (see page 4 in manual).
Use liquid rinse aid and adjust dispenser release quantity if dishes are also wet apart than dirty (see page 5).
Ensure ishes are placed correctly (see page 6), or the water won't reach all the dishes in load.
Clean the drain well and filter regularly, or pump recirculating water will spray dirty water on dishes. Also clean spray arms every six months (see page 7-9)
Most common reasons for dirty dishes are improper cycle (too weak), improper detergent, or improper plates position in rack. Follow all my hints above and have a look.
Here an online manual.
Regards.
Ginko.
Posted on Nov 12, 2010
Panasonic TC-P50VT25 Plasma
I think the screen itself is defective, don't waste anymore time and money on this, new LCD flats are very cheap.
Jan 25, 2017 | Televison & Video
F20 error
If you remove the bottom panel, there is a drain plug and that would allow it to be opened. There is lots of water there though
Jan 05, 2014 | Whirlpool duet Washing Machines
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
Smell comes from between the drums
I have this problem with my Siemens machine, it is due to mainly running low temp washes and bateria building up in the hoses etc. (more prevalent if the machine is connected directly to the sink and not on a stand pipe). I run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) I buy stores own as it is cheaper than miltons. The first time I did mine I ran the cycle twice to be sure it was cleared out. My machine is six years old and the first smelly signs were when it was about a year old, I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months. Hope this helps. Roni. (ps don't be tempted to use bleach as it foams up and can cause more problems!!)
Feb 25, 2010 | Admiral AW22 Top Load Washer
I have a Hotpoint, model # Hsm25gfre sa, that is cooling and freezing unevenly. Everything onthe bottom half of the freezer is frozen and the top half is thawing. Also, the water in the ice maker is not...
Make sure that the freezer fan is working and circulating the cold air. Then check the damper assembly to make sure that cold air is being circulated into the refrigerator. And lastly make sure that the self defroster is working - if not the evaporator will freeze up, freezer temps go up, and ice maker will not work if freezer temps are 10 degrees or higher. A digital refrigerator thermometer will confirm freezer temps being high.
Aug 26, 2017 | Hotpoint HSM25GFRSA
Kenmore 80 Series - water wont fill to full load
remove edge decore trims from left and right side front of control panel8b608f8.jpg
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on right/underside of water level control body where it touches metal mount plate
rotate water level control body 45deg anti clockwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Incidentally, the cause is a VERY small wire spring inside the control body that is not really up to the task, and stretches over years.
Its a common occurrence, and I make this repair, on callouts, no parts required, couple times a month you may have to flip the switch to reset to get the water to restart filling
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Drain problem
Pull out the washer and check the drain hose for clogs.
Aug 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
Kenmore Top Load Washer Series 70
NO,your transmission is probably ok!! Inside your top end of agitator are these 4 plastic parts called "dogs" they need to be replaced.To be 100% sure ,do this first,Fill upthe machine on small load and while its washing look to see if the bottom end of agitator is moving back and forth ,if it is replace the dogs.In some machines you have to change the upper part of agitator.If the agitator is not turning at the bottom than,remove the top of agitator cover so you can get a extended half inch socket in to it and pull the agitator up and check the transmission splines.If they are smooth and cannot grab the agitator than your trans, is bad.
May 15, 2008 | Kenmore 22422 Top Load Washer
Toshiba 3160 copier
Would you say that the bottom half is Ghosting? if so then the fuser hot roller teflon has worn and will need replacing.
If not please check the optical mirrors (Do not remove them only remove the top glass) for dust.
Sorry cannot be anymore help as you may possibly need a engineer call out.
Thanks J
Jan 16, 2008 | Toshiba 1360 Black and White Copier
Dishwashers Logo
168 people viewed this question
Top Kenwood Dishwashers Experts
Oloyede Monsuru
ray gallant
Are you a Kenwood Dishwasher Expert? Answer questions, earn points and help others
