Question about Fossil Watches
Trying to shorten the band on a fossil watch. removable links have arrows which point outward on both sides of the link.
  • Hestr Jun 22, 2008
    Solution was right on ! Thanks !
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 4 Answers
You need a small, (smaller than the pin hole) punch to force the pins out of the band. Since the arrows point in both directions you can push from either direction. Push enough of the pin out to be able to grasp it with a pair of small pliers and remove it. Do that on both sides of the link, replace the extra with a small hammer and you're done.
Sarvadrk
Posted on Jun 19, 2008
I need instructions on removing links from a Fossil Stella watch
you will need some sort of tool for a pin pusher to actually remove the pin from watch . It can be a strong needle of some sorts but I suggest getting an actual pin pusher to prevent from damaging the watch or hurting yourself.
if you look inside the watch band itself you will see on the links an arrow pointing one direction. That is the direction you need to push the pin since the pin head is larger and cannot be pushed the opposite direction .
On the side of the watch links you will see a small circle endented with a pin head. That is the link pin. Place your pin pusher or other similar sized object and with a small or jeweler hammer slowly and lightly hit the pin pusher down until pin comes out of opposite side , you can use tweezers or needle nose pliers to pull pin all the way out
There are some pin removers that screw also or just push down to pop pin .
Once out repeat process until you have removed enough links that watch fits comfortably. Then slide pins with head of pin entering the side where the arrow on back of link is pointing to. Once all the way in gently hammer rest of pin till flush with link .
Oct 17, 2010 | Fossil FS2919 Wrist Watch
Have a watch band with slot and arrow on one side need to shorten
The arrows indicate the direction that the pins punch out. Its possible that it has tiny little sleeves that put pressure on the band which hold the pin in. Take it to a reputable watch repair shop...they can assist you with your adjustment! :-)
Jan 17, 2010 | Kenneth Cole KC3289 Wrist Watch
Fossil AM4200 shorten band
Depending on the age of the watch you will see indicators of pin direction on the inside of the band. Little arrows that point the direction the pins should come out. If there are no arrows you can look at the edge of the band. You are looking for a split in the pin that makes it look like a screw. The opposite side will be solid. You want to push on the side that is solid so the side that looked split comes out. This is a cotter pin and the split side is bigger and needs to come out first. Use a small punch to push the pins out. Make sure you take links from the band evenly on either side.
Jun 09, 2009 | Fossil AM 3688 Wrist Watch
Trying to remove links on a fossil watch w/arrrows pointing out
Are you pushing the links in the same direction as the arrow is pointing? If so, are you using a tool specifically made for removing watch links? If the answer to both of the above is "yes" then look closely at your watch. The pin will look different on both sides. One side will look like the head of a "screw" and the other will look rounded and just come to a point. You always want to use the watch link remover tool on the ROUNDED end and push the "screw" looking end out. It could be that your watch was assembled w/the pin facing the wrong direction.
If you appreciate me solving this for you then please rank this solution as "fixya" or at least "helpful", thanks!
Jan 08, 2009 | Fossil AM3726 Wrist Watch
Trouble sizing Fossil Watch CH-2506
Those arrows inside of the watch band are showing direction for pins or clips to come out. If you have two arrows in opposite directions on one link, that means there are two pins or clips and each one must be extracted from arrow pointing side.
If there is only one arrow on the link- there is only one clip or pin and must be extracted the arrow pointing way.
Some watch bands are held together by very specificly made clips or pins. In this case you will need a special tool to extract them.
Jan 02, 2009 | Fossil Chronograph Urban White Dial CH2506...
Purchased fossil ladies watch am4183 at Macy's, stainless steel band is too big, is this band adjustable, if so how.
Check the sides of watch band and you will see the pin ends. They are holding all links together. If there are arrows inside the watch band, they are pointing the way the pins must come out.
To shorten the band you have to:
Extract the pins.
Take link(s) off.
Join the rest of band together and drive pins back.
Jan 01, 2009 | Fossil JR8096 Wrist Watch
I bought 2 Fossil watches today and need to shorten the wrist band by a link. Both watches have indicators which link can be taken out, yet the arrows show inwards.....
The pins on these watches can be taken out either way, you don't have to worry about if your taking or putting the pins in the wrong way. If you have anymore problems PLEASE let me know. Good Luck!!
Aug 09, 2008 | Fossil Watches
Fossil jr9339
I can only give a general guide.
Usually, watch bands can be shortened by removing links. These links are commonly held together by small pins. These need to be removed with a very fine punch. Looking at the ends of the pins, one end commonly appears "split", the other end may look quite smooth. The pin needs to be driven out from the "split" end. 2 will need to be removed to remove 1 link, then 1 replaced to rejoin.
Links should be removed equally, so gar as possible, from each side of the band. Your choice which side if 1 only is to be removed.
Sometimes the ending links are different to the others. It is only the ones that are identical that can be removed.
May 31, 2008 | Fossil Watches
I just bought a fossil watch ch2331 and need to remove a link. how do i do it?
Some of the links are removable on this watch & some are not. Look inside the band you should see some tiny arrows on the removeable links. You need to push the pin through in the direction of the arrows & remove the link. Then to put the band back together you need push the pin through in the opposite direction of the arrow. Make sure the widest part to the pin goes in last or it won't fit.
Mar 09, 2008 | Fossil CH2331 Wrist Watch
Shorten watchband
I have a similar watch and removing the links are not easy. There are pins in certain links that have arrows on the inside of the band. I used a push pin to remove the pins in the direction of the arrows. Snip the end of the push pin with a wire cutter or pliers so that it fits into the hole and tap the top of the push pin with a small hammer until the other end of the pin is exposed enough to extract it with a set of needle nosed pliers. Repeat for other side of link. When the pin is extracted, twist the link inward and it should snap out.
Remove the link and reverse the procedure, placing the pin in the opposite direction as it was extracted. You may have to tap it gently with the push pin and hammer to get it to go into the holes flush.
It takes a little while and some patience, but if you can get someone to hold the band for you while you tap the pin, it will be easier. Also, if you remove the spring loaded pin from the band fastener so the band can be laid out straight, it will also be easier. Good luck!
Mar 30, 2007 | Timex Outdoor Casual Expedition®...
Watches Logo
3,510 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
