Question about Bernina BERNETTE 65 Mechanical Sewing Machine
How to thread a bernina 1130 - Bernina BERNETTE 65 Mechanical Sewing Machine
  • Bernina Master
  • 9,285 Answers
You can probably use the Bernina 1031 instructions. Download a manual here:
BERNINA Support Machine and Accessories Finders and Software Support...
Posted on Jun 08, 2015
4 Suggested Answers
SOURCE: Bernina 1130 not catching bobbin thread
there will be a adjustment in that you should select the stiching mode and in that give the straight mode the problem will be solved
Posted on Jun 05, 2008
RickE1
  • 202 Answers
SOURCE: Cards for 1130 bernina
Yes, I beleive so, you would need to call a Bernina dealership.
Posted on Feb 11, 2009
Australian S
  • 46 Answers
SOURCE: I have a Bernina 1130.
Make sure you have the correct needle and it is in with the long groove pointing towards you. If the hook shuttle is rotating and you feel a tight spot when turning the machine by hand it means one of the nylon gears has cracked. If a needle has been broken it is possible the needle bar has been knocked up a little, try dropping your needle down about 3mm and turn the machine over by hand to see if it picks up the thread.
Failing that the timing is out, remove the top cober on the arm and loosen the clamp on the hook drive shaft, when the machine is turned over and the needle is at bottom dead centre the point of the shuttle hook should be about 3mm to the left of the needle.
Posted on Jul 02, 2009
Jun 05, 2008 | Sewing Machines
How do I make a buttonhole on a Bernina 1130 s
First of all, pull the bobbin thread thru the bobbin case finger before starting. There is a good explanation in the manual, p. 42-45. Use either the 3 or 3A Buttonhole foot. If you don't have a manual, go to http://danreetz.com/bernina/Bernina_1130_User_Manual.pdf and download and/or read.
Jan 30, 2015 | Bernina Sewing Machines
Bernina 1130 backstitch is not working
then you need to call the shop that serviced the machine & tell them
about the problem that the machine won't backstitch & see what they
say
Apr 29, 2012 | Bernina Sewing Machines
Need free! copy of bernina sewing machine #1130
Try this web site:
Bernina 1130 User Manual and Service Manual PDF
You can probably use the Bernina 1031 manual for most of your purposes. The 1130 is a bit newer and has more buttons.
Jan 27, 2010 | Sewing Machines
Bernina 1130 feed dogs won't feed fabric
On a Bernina 1130 the power on-off knob and the feed dog raise and lower knob look similar and are next to each other on the end of the machine, making it easy to lower the dog assembly entirely, without realizing it. Make sure you didn't accidentally lower the entire feed dog assembly by turning the feed dog knob: you can tell as you turn it if the dogs are up or down. On the Bernina 1130 the knob, like the power should be in the horizontal position to be working both feed and power.
Apr 10, 2009 | Bernina 1008
Feb 07, 2009 | Bernina Artista 180
Bernina Buttonhole foot #3A
Hi, you must have an 1130S which means it could also be a circuitboard issue. If the LED/LCD light for the buttonholer does not flash you either need a new RET-Print (circuitboard) or a new buttonhole foot. Sorry to say that you DO more than likely need a new buttonhole foot according to my manual on this machine. No way to repair the foot that I know of.
You should bring the machine in and try it first.
Guess not all news is good news. Sorry.
Rick (Bernina tech)
Aug 18, 2008 | Bernina Virtuosa 160
Bernina BERNETTE 65 Mechanical Sewing Machine Logo
278 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
