Question about Bugaboo Bee Umbrella Stroller
My bugaboo bee won't fold down - the catch is stuck and won't slide up even whent he button is pushed in. the problem is just with this side, the other side works fine
macnutz
  • 541 Answers
SOURCE: Bugaboo bee pram won't fold - the white button has jammed. How do I releas it?
Not an easy fix the handle unit is all closed in with pop rivets so you need a drill and pop rivet gun just to open it. Try spraying silicon spay in to the inside of the handle where ever can then pull up ******* the release buttons while flexing the joint back and forth.
Posted on Jan 02, 2012
  • 419 Answers
SOURCE: Are the instructions for fitting the footmuff for
Pretty much the same yes. All you need to do is to make sure that the footmuff is hooked over the back of the seat unit (easier to pop off the hood first). Then just loop the harness through the holes and this should fit fine.
I hope this helps.
Posted on Oct 18, 2009
  • 274 Answers
SOURCE: Bugaboo Bee Handles broken
You must take it back to the shop and get them to ask bugaboo to send you a free replacement you have a 2 year warranty if you pushchair is over just over the warranty some shop will still send it back for you. Also check out www.buggypitstop.co.uk they do repairs on Bugaboo and they have a very good service.
Posted on Feb 12, 2010
  • 17 Answers
SOURCE: the white push buttons on either side of my
You need to replace them, you can get them easily enough I bought a pair on e bay last week for 5 euro. Very easy to change just one screw.
Posted on Jul 18, 2010
macnutz
  • 541 Answers
SOURCE: I cant fold my bugaboo cameleon chasis. how can i
I answered a similar question only yesterday. The sliver cap is a Capped Starlock do a google to find out more. They are a one use item and trying to remove them for reuse will mark the plastic hubs and make a weak repair. Here's my How to fix a Bugaboo Handle instructions
If you are not a handyperson type, take these instructions to you local Bicycle Mechanic or Small engineering shop.
The bugaboo handle fault is caused either by two small plastic pins shearing of a plastic disk that actuates two metal locking rods or a broken locking rod. Why bugaboo uses plastic for the disk and aluminum for the locking rods is beyond me! They are critical components with a history of failing!
1/. Remove the capped star lock washer. This is the hardest part of the job. Most people try to leaver this off in the hope of re using. First problem with this is you will mark or damage the surrounding plastic second is star locks are not intended for reuse and will never hold as well as when first used, so best find a new replacement. A hardware store should be able to source some for you. Quickest way to remove a capped washer is to carefully cut a slot in the dome with an angle grinder and then use a large screwdriver to carefully prize one side up so you can fit a screwdriver. Note the walls of the aluminum hub axel are thin and easily distorted, make sure you only lever the capped star lock and not hub axel. Use one screwdriver as a support and another to lift off the capped star lock.
Note it is best to open and repair one side at a time, so your moving and flexing one side of the handle does not dislodge parts in the other side. The hub and disks are mirrors of each other and not interchangeable. The side with the brake lever is left The Bugaboo parts will have an "L" after their serial numbers.
2/. The lock mechanism is very simple; a wire rod rotates a plastic disk. Check the hubs for ware. If too badly worn or damaged you will have too much movement in the locked position. The Frog and Chameleon use the same plastic hub find another frame to salvage hubs from. They are held in by a single aluminum rivet.
The disk has two plastic pins that move the locking rods in and out of the inner hub into and out of the outer hub. You need to either repair the disk by drilling out the pin stumps and finding a replacement metal screw you can fit / glue in. Or (my preferred choice) have a new metal disk fabricated that will last a lifetime.
3/. Reassemble handle locking hub and check operation. If wire rods seem to be in the incorrect position, loosen the top plastic fittings where the handle extends from by removing the small self-tapping screws and wiggle things into alignment. (I use a small amount of the grease used for taps to give a smooth action) If all is working well fit the new capped star lock on the hub shaft and tap home. To protect the dome finish I use a large socket from my socket set and an old rubber washer from a toilet cistern. Repeat operation on the other side
I have parts available laser cut metal disks with stainless steel pins, replacement locking rods in stainless steel and capped star lock washers you can contact me at macnutz@xnet.co.nz
Regards
Steve
Posted on Nov 23, 2010
My bugaboo bee won't recline, the mechanism seems stuck, when I push the release to lie it back the mechanism gets stuck in the up position and nothing happens. The two white buttons on the side
Hi, When the stroller is open, make sure that both of the green indicators either side of the frame are visible. If not, put your foot on the brake and pull the handle firmly with both hands until the green appears. This will enable you to get access to the seat. If the seat doesn't move still, check at the bottom (where the small of babies back is) to see if the excess seat fabric has become stuck inside. This is usually the main reason for the seat recline not functioning. Hope this helps.
Feb 07, 2013 | Bugaboo Bee Stroller
Jan 01, 2012 | Bugaboo 192 Cuddy Cabin ORDER TOD Baby...
Pram won't fold
Silicon Spray, Brute Force and Black Magic
Jan 01, 2012 | Bugaboo Bee Red Standard Stroller
The backrest adjustment lock (white handle) is stuck and cannot be moved up or down in order to adjust the backrest. now the bugaboo bee plus cannot be folded as its stuck on one position which is...
I had the same problem. The stroller was not fully unfolded. Verify if the you have heard the clicks on both sides and the green spots on top of the handlebars are completely visible.
Jan 05, 2011 | Bugaboo Bee Stroller
The stroller is not folding
All strollers like a bit a lubricant and Silicon spray is the best (Bugaboo put a can in their maintenance kits for a reason) Buy a can and spray the handle release then work the release buttons back and fourth. Wipe off any excess with paper towels.
Dec 21, 2010 | Bugaboo Bee Stroller
I've been having intermittent problems with my Bugaboo Cameleon's chassis. When folded up and trying to unfold, one side often became stuck and took patience and gentle coaxing to finally open both sides...
BUGABBO BEE HANDLE PROBLEM!
I've problem with my bee !
The handle just slide down without cliping The locks SO IT'S IMPOSIBLE TO PUSH THE BEE AS THE HANDLE is moving all the time????what can do?please help
Sep 08, 2010 | Bugaboo Cameleon Jogger
How do i put the chassis up and down
Push in the little white button on the frame handle and pull the 2 buttons on either side of the handle - if the frame doesnt fold doew gently move the handle a bit untul you hear a click then should fold
Jun 18, 2010 | Bugaboo Frog - Black Stroller
My bugaboo frog frame will not fold down
CONTACT WWW.BUGGYPITSTOP.CO.UK THEY DO REPAIRS TO ALL BRANDS OF PUSHCHAIRS AND CAN GIVE YOU GOOD ADVISE
Jan 03, 2010 | Bugaboo Frog Stroller
Bugaboo Bee Umbrella Stroller Logo
1,289 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
