Question about Gigabyte Matx Intel G31 775 DDR2-800 Motherboard
On Starting Getting a continuous solid beep. All hardware currently equipped moved from an Asus motherboard. Would not boot formatted drive and reinstalled windows 7. I can now run and work on windows but still have a continuous beep! Have tried installing the motherboard drives did not help
  • hot_sound_gu Nov 12, 2010
    Just to make sure you are suggesting that the speaker or wiring is faulty not any of the other components?
  • 528 Answers
Locate the speaker on the motherboard.
It is a small gadget plugged onto the motherboard.
Hold from the connector (shown on the left side of the picture) and pill to remove it.
Removing the speaker will remove the annoying sound.
Posted on Nov 12, 2010
  • Piyal Perera
    Piyal Perera Nov 15, 2010
    The sound can be due to three reasons
    1. The motherboard may be faulty.
    2. Part of the motherboard may be faulty.
    3. The speaker may have been fixed incorrectly.
    If the computer is working fine and only the noise is the problem, removing the speaker is the best option.
MB keeps beeping 1 long beep no boot.
Hello try to download the manual:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=4&m=CUSI-M&os=&hashedid=n/a
Select windows xp and open the manual folder
Click on global for download.
Unzip the file and you need adobe reader to read the content.
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
This mainboard uses SD ram and it sounds like a ram problem.
If there is room for a ddr ram block you can`t use SD ram and DDR ram simultaneously.
Try to insert the old cpu again and upgrade the bios to support a bigger cpu. Not all cpu is supported.
Good luck
Dec 22, 2012 | ASUS SiS Chipset CUSI-M Motherboard
I have a an Asus P4P800 Motherboard and when I boot up it is giving two short beeps, displays the motherboard screen, goes black, and then does the sequence starting with the two beeps again and...
first make sure the RAM is securely seated
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 17, 2011 | ASUS P4P800-MX Motherboard
Beeps once when starting up then beeps second time once after it runs the memory test then nothing else happens
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
a computer needs its connections to continue its cycle and to have and end to function
obvisously the beeps are windows searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
May 02, 2011 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
I m using asus p5qc motherboard... currently i m having p\booting problem. i m getting 1long 3short beep... then a short beep after a small interval. and i m not able to start my computer....
1 long with 2 short beeps means Either video adapter is bad or is not seated properly.
Also, check to ensure the monitor cable is connected properly.
Open the link below for Award bios beep;
http://www.bioscentral.com/beepcodes/awardbeep.htm
Cheers'
Mike
Aug 10, 2010 | Computers & Internet
When I boot up the computer, the screen has the p5l-vm 1394 logo and at the bottom it says "press delete to run setup, and press tab to display BIOS post message I tried restarting a couple of times and...
The system is currently not able to boot from your hard drive.
press delete key, then on the first screen check to see if the system has found your hard drive. If not, power off and make sure all cables are plugged correctly and hard drive has a power lead attached and retry.
Mar 30, 2010 | ASUS P5L-VM 1394 Motherboard
ASUS P4P2E-X 1 long beep that continue without end
hi,
I think One long beep that continue means RAM problem , Ram Can May be dead or faulty, check on other ram.
I hope that this has been very helpful for you
Nov 14, 2009 | ASUS P4PE2-X Motherboard
Primary Drive Fails
Try to format your hard drive using Maxtor CD not windows XP.
You may have a bad drive, see if you can write zeros to the drive it can fix a lots of problems.
Good luck
N Sabre
Nov 08, 2009 | ASUS P5S800-VM Motherboard
Boot failure Asus P5Q-EM
Disk boot failure. Issue:Disk boot failure.
Cause: This issue could be caused by any of the below possibilities.
  1. Boot options are not set properly in CMOS
  2. Non bootable disc or USB in computer
  3. Remove added hardware /check connections
  4. Hard disk drive is bad
Solution:Boot options are not set properly in CMOS
Verify that the boot options within CMOS are set properly. Below is an example of how we recommend the boot options be set. Additional information about how to enter CMOS can be found on document CH00192.
  1. Floppy drive
  2. CD-ROM drive
  3. Hard Drive
  4. Other / Network
Non-bootable floppy diskette or disc or USB in computer
Verify that there is no floppy diskette or disc in the computer. If the boot options are set improperly the computer could be trying to boot from the disc drive instead of the hard drive.
In addition to verifying there is no disc in the computer make sure that no USB jump drive, external hard disk drive, or memory stick is inside any memory card reader.
If you're wanting to boot from a floppy diskette, CD, DVD, or USB drive and are getting this error message and have verified that your CMOS settings are in the proper order as explained in the above paragraph the diskette or disc you're using is either bad or does not have the proper files on it to make it bootable.
  • Additional information about how to make a boot disk can be found on our boot disk help page.
  • See document CH000669 for information about creating a bootable disc.
Remove added hardware / check connections
If you've recently installed any new hardware it's suggested that it be removed to verify it's not causing this issue. If after the device has been removed the computer works and it was another IDE / EIDE device ensure that the jumpers are properly set on the hard disk drive.
In addition to removing any new hardware it's also suggested if you've recently moved the computer or installed anything inside the computer that the connections for the drive be checked. Usually it's best to simply disconnect the cables from the back of the drive and reconnect them to make sure they're connected properly. While inside also disconnect and reconnect the cable connected to the motherboard as well. While inside your computer make sure you're aware of ESD.
Bad hard disk drive
If you have followed the above steps and you continue to experience the same issue, unfortunately it is likely that the hard disk drive is bad or the controller is bad.
If available, you may want to connect another known good hard disk drive to the computer to determine if it can be detected. If it is able to be detected then replace your hard disk drive. If it is not detected, unfortunately you will need to replace the motherboard or controller as it is bad.
If no additional hard disk drive is available it is recommended that the hard disk drive be replaced first or that the computer be serviced / repaired.
Jul 01, 2009 | ASUS P5QL-EM - Motherboard - micro ATX -...
New ASUS A8V-MX motherboard will not boot to CD or HD with XP
The first thing is to make sure that your CD/DVD drive has the windows disk in it. Also check drive C which is where the windows will be installed. It may require that it is hard formated. Hard formatted means "format x /u" [format-space-drive to be formatted-space-right slash-u]. This will place the drive for "windows xp sp2", all of it, to one pass of zeroes. So, once we have a clean drive C and the installation disc is inserted into the CD/DVD drive, you may proceed to install. You will need to find "install" or "setup" and start it on he "RUN" mode. Any questions or help get back to me. CONSTANTIN (arzconst)
Jun 03, 2009 | ASUS K8V-MX Motherboard
I just put together a new computer using ASUS Motherboard P5Q-E. When I turn it on to boot it up for the first time the Onboard Switches P5Q-E Power on switch and the P5Q-E Reset switch blink. The power...
Re seat your RAM and any other cards that plug into the Mother Board such as PCI cards then try starting the computer again. If that doesn't fix it, then you can uninstall devices and try to boot until you find the culprit, as those beeps you hear sound like hardware error beeps that can be caused by faulty hardware (even keyboards or mice) that plug into your computer. Eliminating all removable hardware should help you determine whether it's an add on component or if the Mother Board itself is bad.
Good luck
Sep 18, 2008 | ASUS Computers & Internet
Gigabyte Matx Intel G31 775 DDR2-800 Motherboard Logo
122 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
