Question about Sony KP-61V90 61" Rear Projection Television
Sony KP-61V90 61 in. Rear... Problem
I have had thi tv since 2002 and have had no probs. Last night my daughter hit the flash button and the center colors areout of focus. have pushed the flash button and tried adjusting colors, but the center of the screen just won't come back into focus. Any help with this would greatly appreiciated.
can contact me at charly_burton@yahoo.com
  • soju4 Aug 30, 2008
    i have the same problems any one have any suggestions.
  • Sony Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and shoSony KP-61V90 61 in. Rear... Problem - 2c07611.pngaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
578ba6c.jpgTV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 28, 2009
My Sony big screen rear projection TV model KP=51HW40 produced 2002 screen flashes red then shuts off. We can turn it back on and it will run for 30-60 minutes and then it repeats red flash. Is this
The Problem you are having is a Cathode to Grid Short in the Red CRT,When it Shorts the screen will Go all Bright Red and shut Down,The Best fix Would Be to Replace the Defective CRT (GUN)
Dec 30, 2011 | Sony Televison & Video
Stand by light flashing, TV will not turn on.
Best take it to the shop,this prob.many boards prob.
Oct 05, 2009 | Sony KP-57WS520 57" Rear Projection...
Sony 61" Projection (KP-61HS10)
Your TV requires Geomatirc Adjustments in proper manner by qualified servcie person.
Jul 19, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony Color Rear Video Projector - KP 57hw40 / Mfg. February 2002
i have the same problem picture is blue/green with blue and green arched horizontal lines
no picture at all only sound then tv shuts off after 5-10 seconds and then a bright blue flash in the center of the screen
have tried adjusting the voltage screws didnt do anything
Jul 13, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony KP-53S75 blue convergence problem...
Good Day, Martin Ping;
Picture won't merge? It sounds like your TV has had a failure in the CONVERGENCE CIRCUIT by replacing those IC's should correct your TV's problem.
Good Night and Luck, big IRISH.
Oct 25, 2007 | Sony KP-53S75 53" Rear Projection...
Sony KP-53S75 Makes Clicking Sound But Wont Turn On HELP!!!
Good Day, menudude;
The Sony your friend gave you is a 2000 Model and cost about $2,000.00 and you don't want to spend $400.00 to get it repaired? GET THE TV REPAIRED FOR THE MONEY.
Good night & Luck, big IRISH.
Oct 01, 2007 | Sony KP-53S75 53" Rear Projection...
Sony KP-48S65 48 in. Rear Projection: fine tune convergence
you will have to go in the service mode. be careful as you could damage the tv if wrong settings are changed. with the tv off push on the remote display 5 vol+ power. now hit the 1 button until you see pje fdis on the upper left. now push the 9 button to enter convergence. you should now have a cursor on the screen. usr the 3 button to switch colors. use the directional pad on remote to move the cursor and the enter button in the center of dir pad to select or deselct a point in the screen. push muting and then enter to save convergence. now restart the tv and all done
Sep 19, 2007 | Sony KP-48S65 48" Rear Projection...
Blue pincushion
Shannon you have a blue convergence failure. this problem can be repaired in home, by a good tv repair guy. John
Sep 11, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-61V90 61" Rear Projection Television Logo
168 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
