I have lost the installation CD for my HP Officejet J4580 All-in-one. Is there anywhere I can download the software for the solution centre / control panel? (that gives you control over the machine and lets you scan documents not only pictures)
it's sure that the hp j4580 entries are still existing in the computer
if the installation was done with the cd-rom then please do the following steps:
insert the cd-rom into the computer
do not auto-run the cd
go to the hp cd icon in my computer
right click on cd icon
then click on open
then look for folder named util
under util right click and open folder ccc
then under ccc you will look for a file l3 uninstall or uninstall.l3
right click on it and click on open
then disconnect the usb cable from the printer(in case it is a wired installation)
go on selecting the files that the uninstaller will show
then do not restart
then go to the control panel
go to add or remove programs
remove the hp softwares if exists(hp j4580 required software,hp solution centre,hp imaging device,hp customer participation program,shop for hp supplies,etc.. )
then go the start icon
go to the run option
enter "regedit"
then registry opens up
click on h-key local machine
select software
then select hp printer entires that are highlighted
then delete them from the registry
restart the computer
then download the fresh version of j4580 from hp.com
then install the software
the issue will be resolved
for a software download install:
go to the folder where the downloaded version is saved
then right click on the software and click on `run
then close the folder
then go the temp folder
by writing the command in the run box
%temp%
then look for a folder that starts with the name"7z........."
open that folder then look for util folder
then the steps mentioned above will be done
please try this and the issue will be resolved
if the issue remains unresolved
please revert back
If you are not getting scan options, make sure you have installed the scanning software along with your drivers.
Check in Control Panel / Scanners and Cameras and try to scan from there.
Thanks,
Pat
You may need to have the "full-featured" software installed on your computer in order to perform scanning operations. If you do not, you may download this software for your HP model here:
For documentation click on Manuals. For the driver and other software click on Software & Driver Downloads. Then click on your operating system for available software.
Try reinstalling the printer software driver.
It is probably found on a CD that came with the unit or you can download the entire package from the HP support website.
Start Installation and then when Setup asks to connect the USB cable Plugin to your system.
Make sure the Printer is connected and Powered ON during the initial setup.
i think this shall resolve ur problem
Follow these steps to remove any installed or partly installed software, and then reinstall the software for the product.
Step one: Uninstall the software
Disconnect the USB cable from the computer.
Click Start , and then click Control Panel .
Click Add or Remove Programs .
Remove all items that are related to HP software. To do this, use the following steps:
Make sure that the option Change or Remove Programs is selected.
Click the HP software to uninstall, and then click Remove .
Restart the computer
In case you have McAfee anti Virus software install please make sure that it is not blocking the HP setup EXE files.
Uninstall the printer and software.
Download the updated softweware and the driver for your current OS,
Reinstall the new downloaded driver when installing the printer via windows control panel.
