Question about Archos DVR Station MP3 Player
Need a manual for a "dvr mde1216" -16 port multiplexer i have a surveillance dvr multiplexer, but no idea how to program it.
Hi there I have a multiplex dvr H.264 4 channel. It started beeping earlier and will not record now please has anyone got any ideas.
Check the power supplies to the cameras and if that is not the issue and you unit has a built in hard drive, the hard drive might be bad.
Jul 30, 2016 | Multiplex Home Security
How can I delete data from the hard drive of 'first alert' camera surveillance DVR?
Surveillance DVRs write over the oldest data when the hard drive needs more space.
You do not need to manage that manually. It is all handled automatically by the operating system of the DVR.
Jul 18, 2014 | First Alert Home Security
Can i connect to my laptop with that cctv view where i can see all camera on same screen?
you will need a multiplexer to connect all your cameras into and out to laptop on the front of the multiplexer you can use the buttons to see one or all the cameras you have installed.
May 24, 2014 | Astak Wireless 2.4ghz Night Vision Color...
Default password
If memory serves me correct, most of the GE/Truvision etc. DVRs have to be sent back in for the password to be defaulted. I may be incorrect on this, will double check.
Jan 01, 2014 | GE Security DVMRe-16CT-600 16-CHANNEL...
How can I get the IP address for my system, 4CH H.264 Multiplex DVR?
To check the IP address, press MENU key on the unit and enter password to access OSD setup menu. Select <System Setup>, <Network Setup>, then <LAN Setup> to check the IP.
Jul 22, 2013 | Tsm Dvr8024 W/500gb 4-ch H.264 Digital...
I cannot access my internet viewer
More details are required.
The Samsung 'SmartViewer' program starts up on a computer. You can access it whether you have a recorder or not.
The Samsung 4 channel DVR has a menu to set IP address & ports to use and a netjack to connect to internet. You can access the DVR from any computer connected to the same router as the DVR by inserting the same correct info into 'SmartViewer' as in the the DVR.
Once you open the required ports in your router, port forward the router to the DVR, any incoming requests from the internet to view should connect and with the correct password you can view your security cams.
With minor adjustments..that's it.
What didn't you do?
Dec 25, 2012 | Samsung 4 Channel Dvr
To veiw on the web I have to be home how can I make it operate from whereever I am even out of state?? Thank you Dan Richardson
Setting up DVR to be used from remote location:
  1. Connect your DVR to your router
  2. Use menu on DVR to assign internal IP and gateway and port number.
    This Local IP must be in the same Gateway range as the Router. If you are unsure check the Router and locate the Status section, or goto the command prompt of your windows operating system and type in ipconfig.
    Look for Gateway. If the Gateway is 192.168.1.1, then you can make the DVR's IP anything from 192.168.1.2 - 192.168.1.255.
    Also you will need to use the same SubNet Mask, which is typically 255.255.255.0, and also use the same gateway.
  3. Next find out what port your DVR uses. The easiest way to it is by reading the manual of your DVR. Look for the network section of it.
    Also if it comes with network software, check out if in the connection area the software shows the port number.
    Also check the Server software/Programming (Network section of it) to see if the port is listed.
    In many cases it will be as simple as just Port 80, which is an HTTP port.
  4. Set your router to forward chosen port to internal IP address of DVR.
    To access the Router itself, use the Gateway you just located. If the gateway is 192.168.1.1, then enter that into the location edit box of your browser and then click the Enter button. A username and a password are typically required, but it depends on a router. For Linksys use "admin", "admin". By default DLink doesn't require any username or password (It is highly recommended to change the default password).
    Once you're logged into the Router, in the Applications & Gaming Section / Servers of the Router, you need to add a Server/Application. Enter the port number and select TCP only. Where it says Port 0 to 0 enter the same port number twice. Or if your DVR uses for example, ports 3550, 4550, 5550, 6550, and there is nothing else utilizing these ports in between, then you can actually just enter one line, 3550 - 6550.
    Enter the DVR/Cameras internal IP.
    Enable it.
    Quote: Originally Posted by Example If the port was 1024, and the Local IP is 192.168.1.200, then it would be:
    NAME = Anything you want
    Port = 1024 TO 1024
    TCP/UDP = TCP
    LOCAL IP = 192.168.1.200
    ENABLED = CHECKED
    OR
    Port = 3550 TO 6550
    TCP/UDP = TCP
    ENABLED = CHECKED
  5. Set up additional entries for as many ports the DVR uses, to the same local IP. Check your DVR manual and it's networking section for all additional ports required. Also check the DVR software itself.
    If your router has enough free entries, you can seperate them. Use it like DVR_HTTP for the browser port, DVR_AUDIO for the audio port, etc.
    If you are going to use VNC to a PC DVR, then you would need to set up port 5900, and perhaps call it VNC_DVR, for example.
  6. You have a static IP so you don't need to use sevices like www.dyndns.org . You just enter your static IP and your router forwards packets to your DVR.
This info is from Stream recording found on http://stream-recorder.com/forum/connect-dvr-via-internet-watch-cctv-cameras-t1996.html?s=16e8433689f2d55effb40b16d5588895&amp;
Nov 29, 2009 | Samsung 4 Channel Dvr
Dvr port range
on most dvr 's the port is 80 for the web cam. you also need to set up the network settings and know the ip you are trying to hit and is it static or dynamic if dynamic it will change periodicly. for example if you set the network settings on the dvr to the rang of your local network it would be something like 192.168.1.10 so under your router you would open port 80 to ip 192.168.1.10. make sence. first thing i would do is make sure the network settings in the dvr are set to work within your network. unless you have an extra static ip you can put it right into the dvr. fi you need further help just ask.
Nov 03, 2009 | Home Security
Does the DVR not work with a Mac
It works independently with security cameras/multiplexers/or any video input. the hard drives have to be pc format to workin the unit..the unit takes a new harddrive out of the box and formats it for use.. does this answer your question???
Jan 06, 2009 | Samsung SSC DVR Digital Video Recorder...
Archos DVR Station MP3 Player Logo
146 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
