Question about Toshiba 36HF73 36" TV
We got a power surge last night, now the TV will not come on. The red LED located in front of TV indicates power coming on pressing button but will start blinking monents later.
  • Toshiba Master
  • 17,130 Answers
Possible that the surge had resulted in the SMPS- switch mode power supply - giving a higher output before it would have corrected but had resulted in the failure of some component.
Remove the panel if you can start the work armed with a multimeter, the mains power being put off. wear insulated slippers while probing the circuits specially when the power is switched for voltage checks.
first of all check the main power unit :click for tips on SMPS
If there was no fault noticed visually then check the processor controller section specially the voltage to the processor. If the +5 volt is missing check the regulator or the feed.
If there is power then check if the mP activates the HT circuit, if not the main board had errors to be looked into with a trace of the working voltages, look specially for charred or damaged components.
Posted on Nov 12, 2010
How do I stop tv going on standby
hi Shaun.
How do I get my TV out of standby mode? Press the power button once. If the TV does not turn on, observe the LED indicator, usually located on the TV's lower front panel. If the LED indicator turned off after you pressed the power button once, it is in standby mode. Press the power button once again to exit standby and turn on the TV.31 Mar 2015
How to Troubleshoot a TV in Standby ' Techwalla.com
https://www.techwalla.com/articles/how-to-troubleshoot-a-tv-in-standby Search for: How do I get my TV out of standby mode?
How do stop tv going on standby Google Search
Nov 26, 2017 | Televison & Video
TV WILL NOT TURN ON AND RED STATIS LIGHT IS ON NO CODES ARE SHOWN. WHAT DO I DO?
If the red indicator light on the front of your HDTV is glowing a solid red, you should first unplug the AC cord from the wall power outlet and wait for 60 seconds before reapplying power to the HDTV.
After you turn the TV on, if it doesn't power up, try holding the power button down for at least 8 seconds. That's supposed to force a system reset. If your model has a system reset button, use that instead. Press the reset button for about 20 seconds...release it and press it again for 20 seconds, release it again and the led will blink just for a minute or two. You should now be able to turn the TV on.
If after several attempts, the HDTV has not fully powered on and the LED on the front of the HDTV is still glowing solid red, you may want to reseat the lamp.
If reseating the lamp has not resolved the issue then your next step is to order a replacement lamp. Keep in mind that some off-brand lamps may only last a few weeks, so replacing a relatively new off-brand lamp may unfortunately be necessary.
Apr 04, 2015 | Mitsubishi Televison & Video
Will not turn on
Probably a spontaneous power supply failure.
Jan 07, 2014 | LG 42" 5400 Series LED HDTV - 42LN5400
My television just doesn't turn on. It was working fine last night then it stopped working. The outlet works and the red light doesn't come on.
Tries tv unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting.Now,the tv should be working again,if the tv still getting same result no power LED light indication at all or just flashing power LED light indication.Mean ur tv the power supply board is the causes and the problems.The power supply board,that board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 01, 2011 | Memorex MLT3221 32 in. LCD TV
I bought my son a 19" philips tv model # 19pfl340d/27.in order to turn tv on it must be unplugged for 10-15 minutes.The first one I bought did the same thing and I returned it.this one is exactly the...
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
Nov 11, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
TV Won't Turn On
there is no reset button - the main fuse has probably blown and needs replacing (6.3A 250 V)
Dec 26, 2008 | Panasonic CT-32HX42 32" TV
Pioneer VSX 915 powe off
Had a power surge last night and got the same problem. Unit wont power on and has a blinking blue light on standby button. I found the solution from the service manual for a similar model.
Hold down ENTER and ADVANCED SURROUND buttons.
This resets the DC overvoltage sensor and bingo the unit comes back to life again.
Jun 18, 2008 | Pioneer VSX-915 Receiver
Toshiba 36HF73 36" TV Logo
102 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
