Question about Candy Washing Machines
Candy CIN 100 T The machine fills with water then stops dead on all cycles except rapid wash. Any advice would be appriciated.
ginko
  • 19396 Answers
SOURCE: Washing machine fills in the water but does not start the wash cycle
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Posted on Sep 01, 2008
    • 135 Answers
    SOURCE: Hi, I have a Candy
    Check filter behind kick plate on bottom front of machine. Drain water out first by lowering drain hose into bowl or bucket.
    Plz come back if further help required.
    Posted on Dec 02, 2008
    dblred
    • 68 Answers
    SOURCE: Washing machine stops mid-cycle, water doesn't drain
    Sounds like you have a bad lid switch, or the plastic plunger on the lid that engages the lid switch is broke. if the plunger is broke, it is cheap, and only 2 screws to remove and put new one on. if that is not broke, check the lid switch. This model is a lid switch, and lid lock in one. You can test it before replacing it if you have a meter. you need to hinge the lid up to check and replace the lid switch. use a putty knife, on each side between the top and top of the front panel. slide the putty knife in one side, it will hit a bracket if your in the right spot. press in, and lift on that side of the top. do the same on other side, just don't let go of the first side or it will latch again. then swing the top back, the back side is on hinges. the lid switch is on the right side attached to the top. unplug washer, remove the 2 wires on the switch and check continuity. there should be continuity, or "open" when the lid is closed, and no continuity, or "closed" when you open the lid. if it is "closed" even when lid is closed, replace the lid switch. let me know if you have any further questions, shane.
    Posted on Sep 12, 2009
    jumptrout51
    • 3361 Answers
    SOURCE: kenmore 80 series washing machine - won't stop
    Your air pressure tube going to the water level switch is pinched or stopped up,OR, the water level switch is going bad.
    Use this manual to access these parts and diagnose which is bad.
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb?OpenDocument
    Posted on Jan 16, 2010
    SOURCE: Maytag washing machine stopped working mid wash cycle
    http://appliancejunk.com/forums/index.php?topic=2946.0
    Go to the above link, get a suitable service manual, and follow the troubleshooting procedures
    Washing Machine FAQ
    Appliance Repair Guide: How To Fix Appliances - ACME HOW TO.com
    DIY help site.
    Posted on May 02, 2010
    When I turn on machine with a selected cycle, it starts to fill with water, and then stops dead, I think the drum is not turning, as usually it fills a bit with water, turns around, fills a bit more with...
    hi there, it sounds as if your drive belt is loose or broken. when you put you ear to the machine can you hear the motor running, if the motor runs but nothing else happens its a sure sign that the belt is gone. whilst you might look silly doing this, it may prevent you opening the machine up to replace the belt if you not have to.
    thanks iain
    May 03, 2011 | Candy AQUA1000T Front Load
    Moffatt washer is washing and draining but not spinning out the clothes
    All content © 2000 © 2009 Washerhelp
    > Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
    Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
    Dec 03, 2009 | Washing Machines
    Washer stop in middle of rinse cycle
    Dec 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    I have a Frig. Gallery washer and it will fill up and drain but not spin. What could be wrong and how can I fix it??
    Dec 02, 2009 | Frigidaire Affinity ATF7000E Front Load...
    I have a candy AQ 1200, it fills with water then drum turns and s
    sounds like m/c is waiting to heat up water but heating element is not working or timer switch not going on to next cycle.
    Aug 21, 2009 | Candy Washing Machines
    Candy Nova CN126T - No hot water
    hi This control panel switch regulates the temperature of the water in the tub. It also plays a role in controlling the fill cycle. If you suspect this switch is faulty, remove it and take it to a professional service person for testing (the test takes special equipment). Or, hook a test wire across the switch terminals; if water flows, the switch is faulty. If the switch is faulty, replace it with a new one of the same type. Connect the new switch the same way the old one was connected.
    If there's a problem with both water temperature and tub filling cycles, both the temperature switch and the timer may be faulty. Test both components and replace them as necessary. Procedures for testing the timer can be found below.
    Sep 13, 2008 | Candy CN126 Front Load Washer
    Stops mid way
    i found the information on washer help
    Jul 06, 2008 | Candy Washing Machines
    Candy aquaviva 1000 es
    Are you sure that this not is the cooldown phase of the mainwash? Most frontloaders have this feature.
    Nov 28, 2007 | Candy AQUA1000T Front Load
    Candy a8001 dishwasher
    It sound that the problem is cause the water level switch. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you will find it easily. Clear tube first from any obstruction, In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it doesn't react, you should replace it. Good luck !
    Jan 27, 2007 | Candy 24 in. CD622 Free-standing...
    Washing Machines Logo
    74 people viewed this question
    Top Candy Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Kolbrun...
    Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
