Hi. This is a Emagic logic music software query. I am trying to use logic 7 on a Apple G5 power pc, but when I put my XSkey in and open logic, I get a !message saying 'XSkey driver too old! The XSkey needs the driver 'EmagicXSkey.kext in version 1.2 to be installed in the folder /System/Library/Extensions/. Please install the driver with the installer. Could you please tell me where I can download this driver? Thanks Jack Pinter
SOURCE: update my psp slim
It will not work if it was the Official firmware. If you have custom firmware then there is probably a problem (Bug) which will be fxed in time.
Posted on Jul 04, 2008
sandrew
  • 2961 Answers
SOURCE: Install Realtek Audio in ACER 4720Z
Realtek HD audio driver is only for Vista, not XP, you need the ac97 realtek audio driver
Posted on Aug 15, 2008
drifterK
  • 4924 Answers
SOURCE: driver blocked due to incompatibility in windoes 7
usually windows seven it takes most drivers automatically ...so go to device manager and choose one by one any drivers that you find in yellow ..and click on automatic update ( update driver ) it will search with an wizard auto...if the driver for any device is not present it will inform about ..and you have the choice either to try with the same driver from Vista ...(usually works) or disable if you do not need the device...
Posted on Dec 21, 2009
pcs365
  • 128 Answers
SOURCE: error R6002 floating point not loaded
Causes of Runtime Error R6002
Several causes exist behind this error. One of the most prominent ones is a broken link. This link apart from causing the run time error 06002 can also produce other errors like the computer not responding to any instruction at times. If a software has not been properly installed it can also produce such errors. Apart from that, use of internet without any anti-virus software can make your computer applications get infected with spyware and viruses. Such viruses can produce missing links inside your registry causing such errors.
Why are these errors caused? Many computer users are just not aware of the reasons resulting in these errors and what are the solutions to get rid of these errors. Remember, these errors can be solved very simply, and they are not going to cost you money. Usually many people exercise the option of getting professional technicians to resolve these problems. But this is not necessary. Through following the simple procedures suggested below you will be able to eliminate the error r6002.
If you take time and start noticing, you will find that the runtime errors are due to corrupted or damaged registry. You must know that the registry is the most importance place which is a storehouse of all the data, about both the software and hardware installed in the PC. When you uninstall software or remove a device there may be some traces of such actions left in the registry and manually it will be impossible to remove them. You should be having knowledge of computers to do this, since it is not advisable to access the registry without this knowledge and manually delete these files. A wrong move can result in damaging the PC irreversibly.
Therefore the only method to fix the runtime error r6002, along with many other errors, you should use the registry cleaner. With a registry cleaner you can repair the runtime error r6002 all by yourself, without seeking help of technician. This way you can save money and time, and you will also know the action to be taken next time when you encounter such errors.
Using the registry cleaner should be optimized with the antivirus cleaner, and if you program in such a manner that both the virus scanning and registry cleaner can take place simultaneously, for which purpose you should schedule these activities on the computer, and ensure that at that particular time the computer is switched on, without your botheration of checking them, they will do their job on their own, leaving you to attend to your work.
http://www.registryfix.com/?hop=reviewb
Posted on Jun 04, 2010
technical114
  • 1851 Answers
SOURCE: I installed a Windows 98
Try to create a folder at the root of the c: drive. This means that the folder has to be not at any desktop or at any other folder but just in the c: drive.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Jan 01, 2011
Emagic audio card is not wroking my mac
not sure if i can help but....
that's a pretty old card? if its a newer mac then maybe the card is no longer supported. I know emagic was bought out by apple many years ago. Logic Pro, etc.
It could just require a reinstall, or updating drivers if available.
Feb 14, 2014 | Computers & Internet
I have a 17" imac g5 that will no power up. no
Check for blown capacitors on the logic board and power supply. If you have signs of blown capacitors you will have to replace logic board or power supply.
The trick is getting the computer open. Stick a credit card in the back vent at the top of the display. Their are two tabs one and each side of the vent push forward unscrew the screws at the bottom. sit it up facing you and pull the top to you. be careful of the isight cable at the top. you will need to unscrew the LDC from the housing be careful of connected cables and check under for the blown caps.
Jan 24, 2011 | Apple iMac G5 Desktop
System will boot to the white screen with apple logo then freeze on the blue screen. boots into login on safe mode, entered password for the only profile than gets stuck with spinning pinwheel.
I am Sorry to Hear this Problem. This is a Common issue on G5 Mac Desktops. You could Google ' G5 Freezes ' and you would see many People facing the same Problem.
This is more often a Bad Faulty Logic Board. There we Certain Recalls for the same. You need to Contact Apple to check whether your Machine would be Covered under Warranty or not.
If you have the Installation Disc, You could try to Reinstall OS first. If you can't boot a CD, it would more likely Confirm Faulty Logic Board.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Apr 05, 2010 | Apple Power Macintosh G5 Mac Desktop
Apple mac G5 freezes when booting up.
Try unplugging all Firewire/USB devices. Also, unplug the power cord from the computer. This resets the logic board. If that doesn't isolate the problem, put your Original system CD that came with the computer and hold down the C key. Boot up and run Disk Utility. Run the repair disk and then repair disk permissions. Reboot and try booting your system again.
Jan 03, 2010 | Apple PowerMac G5 Dual Mac Desktop
What exactly IS this A 6 2m?
Its a audio midi interface drive for an emagic audio midi.
Aug 02, 2009 | Emagic EMI 6|2m External Sound System
Hi i need new drivers and soft ware for emagic a 62 m sound card
Well, I can help you with the driver and manuals. I am not sure if you can get the software to interface with the unit here though. It may be bundled with the driver download.
http://download.info.apple.com/Apple_Support_Area/emagic/
You didn't say whether you have a Mac or PC, but this page has links to both.
Jun 18, 2009 | Emagic EMI 6|2m External Sound System
How to replace the power supply on a powermac G5
I would be very cautious doing this, if you are not an Apple tech. You can damage the connector for the G5 Processors, and render the machine un-usable.
You have to remove the RAM and Processor, then remove the two power connectors that connect from the power supply to the logic board. On the bottom, underside of the chassis, there are four screws. Remove them, then you can tilt the power supply out of the bottom of the unit.
Replacement, is just the reverse.
Apr 17, 2009 | Apple Power Mac G5
No audio
Emagic is no longer supported by Apple, you can still get drivers for it, though. Here are the details listed by Apple:
http://www.apple.com/support/emagic/
To get the drivers go here:
Feb 11, 2009 | Emagic EMI 6|2m External Sound System
ES1 - emagic synthesiser
contact me:  crocotone@gmx.de
fibbo
Sep 18, 2008 | Emagic Logic Express 6 (t9164ll/a) for Mac
No driver
Aug 14, 2008 | Emagic EMI 6|2m External Sound System
Computers & Internet Logo
David Payne
David Payne
