Hi. I am using a Amoi LCD TV LC20D5S. When I turned on the television, the screen shows Amoi with a background blue screen. Next, the screen shows wavy colourful lines. The coloured screen just remains that way. I tried re-plugging the wires but the problem still persist. May anyone please help my ASAP? Is my TV spoiled or is there a way to fix it. Thank you.
techman
  • 3130 Answers
SOURCE: Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Posted on Dec 27, 2006
Benimur
  • 6966 Answers
SOURCE: no colour on television
Hi, It is possible that the reason for the black & white as well as lines across the screen is weak, defective or wrong oriented antenna. If you are hooked up to cable, then it should not be a problem as you can call for service; if on the other hand you are using aerial antenna, you can try to: reorient or adjust the direction to where the antenna is pointed until the reception improves, check the lead in wire (cable or flat) for any breaks or shorts or loose connection, check/clean the connection of the antenna elements to the cable/flat wire, replace your aerial/cable as may be deemed fit and needed. A couple of questions pls if the above does not solve your problem: when receiving from aerial, is the picture full vertically? are you also having problem with sound? If yes, where was the TV bought and where is it being used now? If no, is the image snowy and some channels/stations are better than the others? Good luck and pls post back how things turn up or further information. kind regards.
Posted on Aug 12, 2007
Siliconchip
  • 52 Answers
SOURCE: LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Posted on Jan 05, 2008
  • 92 Answers
SOURCE: westinghouse LCD TV - broad vertical green and blue lines
try to go to the factory reset and see if that helps. If not, you can then check your connection. if you use component (red, green and blue for video and red and white for audio), make sure all the color matches when you plug it in. if everything have been checked then you need to replace the main board and it should correct the problem.
Posted on Jun 22, 2009
gopakumarg43
  • 74251 Answers
SOURCE: although tv is showing picture the colours only
Hello
Your TVs red colour output section has the trouble. There is no red output at the red cathode of the picture tube. The red, green, and blue output sections are on the picture tube base board. In some Philips model, these will be consists of transistors, and some has an IC or Tree ICs for three colour output used. You just open your TV, measure the voltages at these three cahodes. There will be markings on the printed circuit board for these cathodes marked as [Rk,Bk and Gk].
In your TVs case the voltage at the Rk marked pin will be higher that the other two cathodes. This can be caused by an open drive transistor or an Ic whichever may ysed there. If it is transistor, just replace it with a same type and number, as in the ace of ICs the related Ic, must be replaced. If only one Ic is uded for red, green and blue outputs, that Ic must be replaced.
If you need any more assistance, feel free to get me through Fixya. Ok.
Posted on Dec 01, 2010
Testimonial: "Thank You"
How to open service Mode for Amoi lc20d5s
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Service mode entry, adjust and exit procedure to many popular brand TVs are given.
Feb 24, 2014 | RCA Televison & Video
Hi i have a Zenith z20la7r lcd tv.Leave it on overnight next day i notice a white appearance in the background of the screen and some color stream at the top. can this problem fix?. is it the board or
I doubt you will damage it unless black or bright blue on screen which could burn the image.
Before trouble shooting I would call Zenith (they are LG) and inquire if this is a known issue in this model and also if any software upgrades exist for this model.
Mar 21, 2012 | Zenith Z20LA7R 20 in. EDTV-Ready LCD...
Philips 42pfl7762D-lcd blue screen, remote control
Hi! I have the probably same problem (since today) - all I know is that it is because the TV is set to digital instead of analogue, and it won't allow me to put it back into analogue mode - when I try that, i get the cross you mentioned. The strange thing is, that there are no menus visible at all. But the volume and screen output format buttons are workijng and show on the TV. Otherwise the screen is blue. Any solutions?
May 15, 2010 | Philips 42PFL5332D 42 in. LCD Television
Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
May 13, 2010 | Hisense TL1700 17 in. LCD Television
For about 6 months there has been a faint gray/black verticle line running down the middle of the screen . is worse on blue/green backgrounds, and is almost not noticable on white backgrounds. I know that...
I've seen a similar looking problem and it is a bad LCD panel. It will show even on a non-used input, and will show through the menu screen and the screen saver, also. Sharp's LCD panels are very expensive,too. Over 4000 at encompassparts.
May 03, 2010 | Sharp AQUOS LC-45D40U 45 in. LCD...
TV screen doesn't light up for 20 minutes
sounds like caps in the powersupply are bad they take a long time to value up
Mar 01, 2010 | Sansui HDLCD-2600 26 in. LCD Television
Mitsubishi WS-55857 with a flickering blue edge.
The vertical IC needs to be replaced. You can get new Vertical output ICs at www.tvrepairworld.com and they will also help explain where its located.
Nov 27, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Green purple and blue bars rolling through screen
It is probably the main total assy needs to be replaced.
Jun 26, 2009 | Samsung LN32A550 32 in. LCD TV
48" haier tv is only showing a blue screen when i turn on tv
I have two haier LED LCD televisions with all the screens broken. they are 39'' and 32''. I would like to ask where I can get the screens to buy in order to fix them. Thank you.
Jun 15, 2009 | Haier HTF20R21 20" TV
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
