My car amp is stuck in protection mode? how do i get it off
  • 96 Answers
Http://www.mp3car.com/wiki/index.php/Amplifier#Power_.28wattage.29
Kindly read this site, put switch so that you can turn it off and on you amp. Visit the shop nearest to you.
Posted on Jun 18, 2008
It is stuck in protect and wont come out
bro...i had problem like that before and i found out that the load(speakers) was high thats why the fuse always blow...or...check the wire to the speakers if they are sorted or touched.gud luck
Oct 26, 2012 | Rockford Fosgate T1000-1bd - 1000W...
Stuck in protection mode tried everything voltage good wires good ground good open/close button dosen,t help me at all love amp please help
everything you've tryed is useless(with respect) because amp has shorted output transistors one or more and amp is in protection mode to protect your amp from further damage.take it to repair shop or try to locate blown transistor yourself.good luck
Dec 10, 2010 | Kenwood KAC-X401M Car Audio Amplifier
Autotek XS-900.4 stuck in protect mode
Hi.
The amp does not go on protection only because of wiring or power source problem , but also and mainly when there is an internal fault.
Protection is started whenever an out-of range voltage value is detected from the controller circuit.
Protection can be triggered from a burnt final IC or from a speaker wiring problem.
Since you have ruled out speake, wiring and power source problems, then this Amp is probably defective
If the Amp works fine on a different vehicle, then protection mode may start either because speakers impedance is not within Amp specs, or because the amp has a too big power draw. In this last case the problem is fixed installing a capacitor on the Amp 12V line.
Regards.
Ginko.
Jun 06, 2010 | Autotek XS-900.4 Car Audio Amplifier
My amp is stuck in protection mode, what are some solutions to this
That indicates a short. Either inside the amp or the speaker wires or the speaker themselves are short. Remove the speaker connection if it is still in protection mode then you have an internal short. You can reset these they are there to prevent electrical fire. The only solution is to find the short and fix it.
May 13, 2010 | AudioBahn A8002T Car Audio Amplifier
Amp stuck in protect mode.
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections. Good Luck.A thumbs up would be greatly appreciated if this answer is helpful to you. Worth fixing.
Nov 22, 2009 | Power Acoustik Car Audio & Video
Protection mood
Hello john_hart,
Check the speaker wiring too. If one of the speaker wires is shorted or grounded, the amp will go into protection mode.
Hope this helps.
May 20, 2009 | Kicker KX600.1 Car Audio Amplifier
DUB 2502 550WATT
check you rca in put into the am with out spkr wire connect to amp if protection light still on amp is damage
May 25, 2008 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Kicker amp
if you amp is in the PROTECTION MODE its means that there some defective part , like for example the main ICs or TRANSISTORS output might be defective , and thats why its on the PROTECTION MODE , needs to be taken to a expert technician for repair.
Apr 16, 2008 | Kicker DX350 Car Audio Amplifier
First disconnect the subwoofer wires from the amp, turn the car off and back on...is the amp on? If so your subs are shorting it out, either from a frayed wire, or blown subs.
If it is still in protection mode, check the fuses in the side of the amp.
Mar 21, 2008 | Kenwood KAC-7251 Car Audio Amplifier
70 people viewed this question
 Grubhead
Grubhead
