Question about LG Washing Machines
Our lg washing machine has an OE error message what does this mean
    Scholar:
  • 91 Answers
Hi dear.OE code related to drain problem.Please checked the filter,open it,clean it & check for any obstacle blocking the pump to do it's function.(Impeller of pump should freely turn.)Please also check drain hose for kink & blockage.Please keep in mind,some times pump seems normal but it can malfuntion & needs to be replaced.If you are not sure,please call service centre.I hope that helps.Thanks.
Posted on Nov 12, 2010
What is an "OE" error message on an LG Tromm clothes washer?
OE means Water may not drain properly
This causes:
Your pump is clogged.
Your pump is not connected.
Make sure your pump is repaired, and try again.
Jul 28, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have a problem with my LG Tromm front load washer. It will wash seemingly normally up to the point it gets to the spin cycle. Then a motor comes on and the machine does not spin or drain. The display...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Sep 10, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
MY LG WASHING MACHINE SHOWS AN ERROR MESSAGE (OE)
Nov 23, 2009 | LG WM1814CW Front Load Washer
My lg front load washer stops and give me an error message OE
Jul 27, 2009 | LG WM-2277HW Front Load Washer
Lg washer oe error
On LG washing machines, the OE flashing code means there is a drainage problem. hope that helped.
Please Rate Me
George
Apr 28, 2009 | LG WM-2277HW Front Load Washer
Error Message/OE
sounds like too much water is coming into machine.check water valve,and water sensor.it is bringing in too much water or not enough.
Mar 06, 2009 | LG WM1814CW Front Load Washer
I have lost my washing machine manual and i have an error message of OE on my lg direct drive wm166220fd
OE means you have a drain problem. Check to make sure there is nothing in your drain hose. Next check to see if there is anything lodged in the pump.
Nov 16, 2008 | Washing Machines
Tromm washing machine, front load from LG
Peace,
ngafm at your service!
Lets try this first!
Did you try to open the door when the breaker was off or only when you turned it back on??
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Sep 03, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing machine programme error
Hi, my LG manual for WD1238C says that OE is Drainage Trouble would imagine the Error codes are the same for all LG machines.
Jun 14, 2008 | LG Washing Machines
Washing Machines Logo
95 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
