Question about Nikon D1X Digital Camera
"Card" indicator flashes
The "card" indicator and the "rem" indicator are flashing and the rem indicates zero, even wih a new CF card. Sometimes the camera won't shut off when switched to the off position, the illumination goes out, but all the information is still displayed on the control panel.
  • Anonymous Mar 30, 2009
    I have the same problem and when i turn it on I have to take the battery our in order for it to read my cards.
  • Anonymous May 11, 2009
    I've also got the same problem as described previously. I have tried using three different CF cards; (1x 1GB Microdrive card, 2x 32MB CF cards) - still the same. This problem is really beginning to bug me! Does anyone have a possible solution...?
2Gig max limit on memory cards for D1X
Posted on Sep 02, 2008
Hi folks got.a cannon eos 350d the problem I have is the cf button is continually flashing is this normal or have I a problem the cf.card is brand new
The CF access lamp should flash every time you made a picture. As long as it is flashing it is saving the picture you shot. This is what the manual says about the flashing:
If it darts flashing, when inserted, and to does not stop flashing, perhaps it is indicating, it needs a format.
I lost contact with CF cards, since my new camera's do have SDxx cards, bet perhaps the CF card you inserted, is not compatible with your camera. I don't know if the new high capacity CF cards can be accessed by your camera. Thy a 2 Gbyte. If it works, perhaps that is the max you can use?
Jul 20, 2014 | Cameras
How to recover files from a crashed Compact Flash on my Roland SPD-S?
It's possible your CF card is full.
1. Connect the card to your computer as you have done. 2. Copy the files off it and save same them to a folder on your desktop.3. Right click only the Flash drive and navigate to "Properties" or "Get Info" if your a mac user.4. Take not of the file system it is currently using.5. Re-format the card with the same file system using your computer.6. Replace the card into your Roland SPD-S and Re-format using these steps: a. Select patch mode or wave mode. b. Press {SHIFT} and {SETUP} (CARD UTIL) c. Press the PAGE buttons to select "CARD FORMAT" then press {ENTER} d. A"[>] to format." indication appears. Press [>] e. A "format, sure?" indication is displayed. Press {ENTER} to start formatting.
7. Once formatted you can replace the card in your computers card reader and copy the files you backed up earlier onto it.8. Re-place the CF card in your Roland and it should work. If not then you may have a irreparable CF Card.
Oct 26, 2012 | Roland Spd-S Sampling Percussion Pad...
I have a Cannon EOS Digital Rebel Xti. When I try taking a picture, I keep getting an error message indicating there is a problem with the CF Card. I have replaced the card several time but keep getting...
What you require is to format the Compact Flash Card. The CF card should be formatted when new and after every download. Format the card in the camera it is going to be used it. Constantly deleting pictures on the memory card will cause major corruptions and total failure. Formatting cleans the memory and allows the camera to communicate properly with the CF Card.
I going to give you several diagrams on where to go in your camera to format. these diagrams are screen shots right from your manual.
Dec 29, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Program
IF it says downloading program it sounds like it is trying to update the firmware. Did someone stick a compact flash card in the CF card slot. If so removed the CF card and reboot the machine.
Jan 05, 2010 | Kyocera CS-2550 Black and White Copier
I lost my manual ...red light is flashing near compact flash card opening
PDF here.
If that little red light (just below the 4-way control) is flashing it is indication the camera is attempting to communicate with the CF. if it never quits, most commonly the culprit is an unformatted, or corrupt/damaged CF card. Replace the card, and reformat in the camera.
any images on old CF MAY be recoverable with a card reader on your PC, but the camera will not read them. Reformatting will destroy the existing images.
May 16, 2009 | Canon PowerShot S1 IS Digital Camera
HELP 350d still not turning on/screen not working
Hmmm... doesn't sound too good does it? Have you tried another CF card? I know you said it doesn't work even without a card but...
Also one last thing to try is to tkae out both batteries, the main one and the slim watch style backup battery that sits right next to the main one under the cover labelled CR2016. Leave them both out for an hour and see what happens. NOTE this will probably reset your camera to factory defaults and may reset the photo numbering counter back to zero. Worth a try?
Feb 10, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 350d not turning on/screen not working/
Does the camera work properly with the CF card removed? If it does than the CF card is the problem. Try formatting the card with the camera or getting a new one.
Feb 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Can't download pictures to pc
What software are you using to access the pictures. If you don't have the "canon" drivers installed it just won't do it.. You can however go get a card reader for the Flash card and that saves on the camera batteries..
Jan 29, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Nikon D70, displaying error code 'CHA' when memory card inserted. Unable to format or use memory card. Have tried new memory card, still same problem.
CHA errors indicate a communication issue with the CF card. Your card could be going bad, you could have a broken pin, or any number of other problems.
I'm running into this same problem now. If anyone has a good step-by-step to troubleshoot which of the dozen things this error could be, I'd appreciate it.
For myself, I'm planning to start by trying a new CF card.
Sep 02, 2008 | Cameras
Canon Rebel XT unable to access compact flash card
check all the pins in the CF socket in the camera are there, or are not bent, repair is expensive if broken
Jan 17, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Open Questions:
Nikon D1X Digital Camera Logo
460 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
