When I connect my nokia 2730 cellphone to pc it won't work
When I plug the cable in the phone it gives me 3 options:
?PC Suite
?Printing and Media
?Data Storage
and when I choose one of these it says "host did not response"
What will I do?..please help me..thanks...
it's two way to make this: connect the cell phone to pc with data cable and install nokia pc suite from the net or activate IR from phone and IR from pc, if you have. the easy way is to conect a data cable and download pc suite from nokia site.
<span><b>Flash/Upgrade your Firmware using PHOENIX</b><br /><b>THIS TUTORIAL WORKS WITH ANY NOKIA CELLPHONE</b></span>
<span><b><br /></b></span>
<span><b>USE WINDOWS XP.<br />NOT 100% COMPATIBLE forWINDOW 7</b></span>
<span><b>Things you need:</b><br /><b>1. Your NOKIA CELLPHONE with FULL BATTERY.<br />2. Compatibe Nokia USB cable.<br />3. Nokia PC Suite (Version 7.1)<br />4. Phoenix Software </b><b><i>(</i><i>CREDITS TO XXIV_19)</i>.<br /></b><b>5. Latest Firmware from Blue Nokia.<br />6. Desktop/Laptop with internet connection. </b></span>
<b><br /></b>
<span><u><b>STEP 1. </b></u><br /><b>1. </b>Download and install Nokia PC Suite Vesion 7.1 --> </span><a href="http://www.mediafire.com/?uixd3jnn5jg">http://www.mediafire.com/?uixd3jnn5jg</a>
<br />
<span><u><b>STEP 2:</b></u><br /><b>1.</b> Turn off your cp --> remove battery --> look where your cp was manufactured --> note also the RM version & the 7 digit product code <br /><i>(Ex. Made in China, RM-346, Product code - 0576672)</i><br /><br /><b>2. </b>Turn on your cp. Check the firmware installed --> dial *#0000#.<br /><br /><b>3.</b> Download & Install your<b> LATEST FIRMWARE</b> ---> DOWNLOAD HERE -> </span><a href="http://www.blue-nokia.com/index02.html">http://www.blue-nokia.com/index02.html</a> --><span>On Blue Nokia website (upper right screen) <b>choose phonetype</b></span><i>(Ex. select <b>E71</b></i><i>)</i>
<span><i><br /></i></span>
<span><b>- Choose APAC</b> for cellphones made in Asia. <b>If APAC is not available, you can use EMEA. </b><br /><b>- Choose EMEA/MEA</b> if it was made in Europe, the Middle East and Africa<b>.</b><br /><i>[Ex. <b>E71</b> --> </i><i>E71 -1 (RM-346) 500.21.009 v10 (APAC)]</i></span><span></span>
<i><br /></i>
<span><u><b>STEP 3<br /></b></u><b>1.</b> Download Phoenix Software(choose 1 any link is available</span><span>.)</span>
<a href="http://www.mediafire.com/?yi3wo0ymx0m">http://www.mediafire.com/?yi3wo0ymx0m</a><br />
<a href="http://www.mediafire.com/?w1e2whxjpgu9i2s">http://www.mediafire.com/?w1e2whxjpgu9i2s</a>
<br />
<span><b>2.</b> Install Phoenix Software <i><b>(follow my screenshots)</b></i></span>
<span><i><b><br /></b></i></span>
<span><i><b><img src="vhin100889.jpg" /><img src="vhin100889_0.jpg" /><br /></b></i></span>
<br />
<span><b><u>NOTE:</u></b> <i>when APPEAR ERROR ON INSTALLATION --> JUST CLICK <u><b>CONTINUE ANYWAY</b></u></i></span>
<span><i><u><b><br /></b></u></i></span>
<span><i><u><b><img src="vhin100889_1.jpg" /><br /></b></u></i></span>
<span><u><b>STEP 4<br /></b></u><b>1.</b> Open Nokia PC Suite.<br /><br /><b>2.</b> Connect your cp using compatible Nokia USB Cable. <b>Connection type: <u>PC Suite </u></b><br /><br /><b>3.</b> Open Phoenix <br /><br /><i><b>(PLEASE FOLLOW MY SCREENSHOTS!!!)</b></i></span>
<span><i><b><img src="vhin100889_2.jpg" /><img src="vhin100889_3.jpg" /><img src="vhin100889_4.jpg" /><img src="vhin100889_5.jpg" /><img src="vhin100889_6.jpg" /><img src="vhin100889_7.jpg" /><img src="vhin100889_8.jpg" /><img src="vhin100889_9.jpg" /><img src="vhin100889_10.jpg" /><img src="vhin100889_11.jpg" /><img src="vhin100889_12.jpg" /><img src="vhin100889_13.jpg" /><img src="vhin100889_14.jpg" /><br /></b></i></span>
<span><u><b>NOTE:</b></u><i> If you want to change your PRODUCT CODE: Click the <b>box w/ 3 small dots</b> on the RIGHT SIDE of PRODUCT CODE BAR</i><br /></span>
<span><i><img src="vhin100889_15.jpg" /><img src="vhin100889_16.jpg" /><img src="vhin100889_17.jpg" /></i></span>
This is general method to install software in cellphone via PC : 1. Install PC Suite driver in your PC 2. Connect your phone to PC via USB cable or via bluetooth 3. If the PC Suite have specific menu to install software (like Nokia PC Suite) you can install your java software instantly 4. If the PC Suite don't have this support, then you must install them manually as describes below. - Copy your java installer files in to your phone memory card - Plug off your phone from your PC - Open data in your phone memory where the files were saved - Click the file and click Option and choose Install the file - Your java software ready to use.
Dont worry all you need to is follow the following steps :
1.turn on the bluetooth in your cellphone or if you are using a USB cable so insert the CD for the cellphone
2.install the software for the cellphone in your computer as for NOKIA its NOKIA PC SUITE
3.turn on the wireless in your computer or connect the USB cable
4.for bluetooth connection only(go to bluetooth devices)
select add a wireless device
5.select your device
6.go with the Addition process and close the window
FOR USB CABLE CONNECTION
connect your phone to the PC and start working
1. Install the Nokia PC Suite to your PC.
2. Connect your N95 to the PC via a USB. Allow the PC to detect it and load its drivers.
Also use the connection option of PC Suite.
3. At this stage you will find an additional icon in your MY Computer - Nokia Phone Browser.
4. Either use this NPB or the PC Suite to transfer files from and to Phone.
1.
You can use the USB data cable to transfer data between
the device and a compatible PC or a printer supporting
PictBridge. You can also use the USB data cable with
Nokia PC Suite.
To activate the device for data transfer or image
printing, connect the data cable. Confirm "USB data
cable connected. Select mode." and select from the
following options:
• Nokia mode — to use the device for PC Suite
• Printing & media — to use the device with a
PictBridge compatible printer or with your
compatible PC
• Data storage — to connect to a PC that does not
have Nokia software and use the device as a data
storage device
To change the USB mode, select Menu > Settings >
Connectivity > USB data cable and the desired USB
mode.
2.
Set up a Bluetooth connection
Select Menu > Settings > Connectivity >
Bluetooth and from the following options:
• Bluetooth — Select On to activate the Bluetooth
function. indicates that Bluetooth is activated.
• My phone's visibility — to define how your device
is shown to other Bluetooth devices
• Search for audio enhancements — to search for
compatible Bluetooth audio devices. Select the
device that you want to connect to the phone.
• Active devices — to check which Bluetooth
connection is currently active
• Paired devices — to search for any Bluetooth device
in range. Select New to list any Bluetooth device in
range. Select a device and Pair. Enter an agreed
Bluetooth passcode of the device (up to 16
characters) to pair the device to your device. You
must only give this passcode when you connect to
the device for the first time. Your device connects to
the other device, and you can start data transfer.
• My phone's name — to set the device name for
Bluetooth connections
3. Take off you microSC memory card then read directly to your computer
hi mate.download and install nokia pc suite.this might help u.also when u plug phone via usb u have 3 options to choose-nokia mode,printing and media,data storage.
pick data storage if u want transfer music,photos etc..
good luck
Yes
I have experienced this problem. What you need to do is plug the usb cable into the computer before switching the computer. Make sure you don't plug the other end into the mobile phone yet.
Once the machine boots up. If you've installed nokia pc suite. It an icon will appear in the taskbar. Click on it can't remember whether its right or left click, but you need to select manage connections. Now if you are using a genuine nokia data cable you shouldn't have problems but if it isn't then you need to uncheck the usb options and check the option called 'serial'. Once you've done this a button called properties or settings or configure which is greyed out should become active. Then from the drop down box you will have various options eg. com1, com2, com3. What normally happens is when you don't have the cable plugged into the usb port only com1 will be displayed. But when the usb cable is plugged in com 3 or com 4 will appear. So you select com 3 or com 4, then OK. Wait for a few seconds then connect you other end of the usb cable to your mobile and it should recognise it after a few seconds.
