Question about Mitsubishi WD-52628 52" Projection HDTV
Mitsu wd-52628 green flashing timer/power light
My power/timer light has been flashing green evr since power was restored following a power outage. How do I know if its the DM board, the 4 capacitors, or any other of the caps that need to be replaced. I want to avoid buying a part that wont solve the problem. thanks
  • 927 Answers
Good Day;
Since you have a LED that does not stop blinking after plug in, and you want to verify, do this: Verify the standby supplies, 12-volts at connector KA pin 17, 6- volts at KA pin 18 &the 28-volts at KA pin19, if the supplies are prsent suspect the DM PCB.l THe 680 ufd 16-volt caps are only a small cost maybe $.35 each. If you do this repair make sure you unplug the little plug-in board, on the DM board, while you replace those caps. Then plug little board back.
Good Luck & let me know; big I
Posted on Jun 18, 2008
  • Mitsubishi Master
  • 8,617 Answers
Steady blinking is the DM failing to complete the boot sequence. Your more than likely needing the DM repair kit.
I replaced the lamp in my Mitsubishi WD 52628 and the tv will still not come on and the lamp light still blinks
"Initialize" a "factory reset". Power on the tv, on the original remote, enter "MENU 1,2,3 ENTER". This will get you to the factory reset window. Initialize the default reset and you are fixed. Try this before ditching the set or tearing it apart. Good luck and post your results for everyone here with the blinking green timer light issue. Thanks.
Apr 25, 2012 | Mitsubishi WD-52628 52" Projection HDTV
Wd-52628 flashing blinking light
Using your original remote, power on the tv, enter "menu 1,2,3, enter" to "Initialize" the "factory reset" once the window comes up choose to reset to default. That should fix the blinking green timer light.
Jan 16, 2012 | Mitsubishi WD-52628 52" Projection HDTV
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi TV green flashing timer light after power outage.
You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
http://servicemanuals.vstore.ca/
Aug 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The electrical power in the house was turned off.Now the television will not get a channel.It's a Mitsubishi WD-52628.Can you help?
if the green timer light is flashing you need to replace or have them replaced several capacitors on the power supply board, the FMT board and the DM board. it is a very common problem with these sets you are not alone.
Aug 10, 2009 | Televison & Video
Timer light blinks constantly
Is it Mitsubishi WD-52628 TV? please confirm model number.
Unplug TV from AC outlet for couple of minutes, replug back in, turn power ON and check, still same problem?
Lets read error code in TV, press Device and Menu buttons on front of TV at same time for 6 seconds that will activate error code read process. Led will flash in 2 sequence with half second pause. count it and let me know the error code to proceed.
Thanks.
Jun 29, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi wd-52628 flashing green timer light
If the power/timer led is the one blinking constantly
the most likely problem is two 3300 mfd caps and 1 to 8 1000mfd caps on the power board.
could be the DM board or caps on it as well.
Jun 17, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Flashing green timer light on TV
change the 4 100uf capacitors on the DM board. You will need the service manual to get the set apart as its technical. But with the service manual and take notes you should be able to repair it. But the service manual for that chassis is mandatory or you will never get the chassis out without alot of trouble. Heres a link where you can get the manual emailed to you.
Mar 20, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Flashing green timer light, no image on TV
4 capacitors on the DM board causes this they are 1000uf @35 volts replace these capacitors and that should take care of your problem
Mar 19, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi WD-52628 52" Projection HDTV Logo
368 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
