Question about Acer Aspire 5500 5570-2609 Laptop
I am using windows 7 but not able to use blue tooth & wi fi can u pls help me
  • 26 Answers
You need it driver
Posted on Nov 12, 2010
Where do I find the pairing code number pls.
No where from the specs of this model it does not have Blue Tooth capabilities. From the user manual there is no Blue Tooth capabilities. Pairing code would be for Blue Tooth.
You could use a 802.11N WI FI ethernet device and connect the TV to it but no blue tooth .
Mar 02, 2015 | Samsung Televison & Video
Activate bluetooth on stealth g2
Hi Ali.. as far as i know and im pretty sure of this.. trio stealth aka Mach etc.. only has wi fi..no blue tooth. Here is a link with more info
for u.
http://youtu.be/mK-AGDPtoNU
Good luck
Chad man
Oct 26, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Bluetooth peripheral device driver
Sai Ch Krishna,
Depending on the system. The bluetooth would have to have been purchased at point of sale. The wireless and the bluetooth are turned on by a wireless switch on the side of the computer. If needed you can reinstall the drivers. Also, make sure bluetooth is turned on in the bios. Below is more information.
Wireless Switch
Wireless Technology The Latitude D630, D631, and D630c system ships with a wireless feature called the wireless switch. It is located on the left side of the system next to the IEEE 1394 connector. When used in combination with the Dell 38482; Quickset utilities, this switch enables or disables the wireless LAN, wireless WAN, and Bluetooth cards in the system or searches for all wireless networks in range.
To scan for a Wi-Fi wireless LAN, slide and hold the switch in the momentary position for a few seconds. The Wi-Fi Catcher network locator works whether the computer is turned on or off, in Hibernate mode, or in Standby mode, as long as the switch is configured through QuickSet or the BIOS to control Wi-Fi network connections.
Because the Wi-Fi Catcher network locator is disabled and not configured for use when the computer is shipped, it must be enabled and configured through the Dell QuickSet utilities to control Wi-Fi network connections.
Wireless Switch LED Settings
The LED on the wireless switch works even if the system is off. A user can activate the switch and have it scan for networks without going through a complete boot process. The switch can be set to detect for only certain wireless signals, such as WLAN only, WWAN only, Bluetooth only, or any combination of these. This is set in the BIOS under the Wireless section.
The LED indicates the presence of a network as follows:
  • Flashing green - The system is searching for a signal.
  • Green - The system has detected a wireless signal and has good strength.
  • Yellow - The system has detected a wireless signal, but it is moderate to weak in strength.
  • Red - The system failed to detect a wireless signal, or the wireless signal is extremely weak.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Aug 27, 2013 | Dell Computers & Internet
How to set up wireless printer on windows 7 net book
I have just bought an epson sx435 wireless printer. I have set it up on my xp desktop with usb cable. How do I set it up to be wireless on xp
and how to I set it up on my Acer Aspire one 522 netbook running windows 7.
Home > Printer Wi-Fi Setup Setting up a Printer Wi-Fi Network Using the Control Panel Using the Wi-Fi Setup Wizard with LCD panel WPS setup You can set up a Wi-Fi network for your printer by using the printer's control panel. Using the Wi-Fi Setup Wizard with LCD panel If your printer has an LCD panel, you can use the Wi-Fi Setup Wizard to simplify manual setup. mark_no.gifNote: This setting is not available for all printers or may not be enabled. Make sure that the Wi-Fi is enabled on your computer in advance. Check the SSID and password for your network as these are required during Wi-Fi setup. If you do not know the SSID and password, check with your network administrator. For step by step information on setting up a Wi-Fi connection using the Wi-Fi Setup Wizard, click the following link. This feature is not available for all printers or may not be enabled.
exlink.gif../p_body/panel/wizard/manual_01.htm
Well to start with xp look at the following.
http://support.epson-europe.com/onlineguides/en/sx430sx435w_nwg/html/index.htm
May 30, 2012 | Computers & Internet
Wi Fi switch on my Aspire 8950 is grey and unresponsive
go t Acer support download the correct drivers
Feb 11, 2012 | Acer Computers & Internet
I have downloaded windows 7 ultimate on my sony vaio vgn-cr353 notebook but mine blue tooth and wi fi is not working what i can do for that
Go to your blue tooth website and wi fi website and download the drivers for windows 7 and if it is 34 bits or 64 bits, this should work.
May 23, 2010 | Computers & Internet
Bluetooth is not found in the control panel of my laptop
goto start and type bluetooth in search...if bluetooth drivers are installed ull get some icons like bluetooth, bluetooth devices etc.....try clickin bluetooth devices.....n u can try to connect with ur mobile.....if it doesnt show anythin u may have to install bluetooth drivers....hope this helps...
Mar 07, 2010 | Lenovo ThinkPad R61i 14 inch widescreen...
Olivetti Any_WAY Wireless with Wi Fi & Blue Tooth Problems with connecting Wi fi
What Wifi are you using?
Remember this only works with WiFi 802 B and G, if you are using A it won't work.
Do you have more information or questions?
The more information you provide to us, the better we can help.
Thanks!
Dec 11, 2007 | Office Equipment & Supplies
Acer Aspire 5500 5570-2609 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
