Question about Yamaha P-7000 2-Channel Amplifier
My yamaha P7000S is dead no power to filters caps.....thanks
3 Suggested Answers
tech240
  • 169 Answers
SOURCE: need schematic diagram of YAMAHA P7000S
Best find your local dealer as cd are not usually supplied to end users.
Posted on Sep 20, 2009
  • 76 Answers
SOURCE: yamaha p7000s diagram
Yamaha P7000S service manual. It includes the schematic diagram. Click Get Manual.
Posted on Oct 17, 2011
How to connect a yamaha p7000s amp to an adcom gfp-555 preamp
Use "Main Out Norm" from the gfp-555 pre-amp and connect to Canon connectors of the Yamaha. This requires a standard RCA to Canon cable for correct connection. Start with this first, if that works OK than try the "Lab" output of your pre-amp, but I am not sure if the Yamaha can handle this or the results of sound quality. Your choice.
Feb 17, 2016 | Yamaha Audio Players & Recorders
I need diagram yamaha p7000 change power supply using a transformer
I'm sorry. I have no idea what you're asking, but if you need a service manual, you'll have to go to the Yamaha website.
Dec 18, 2014 | Yamaha P7000S 2Channel Amplifier
How to connect a wharfedale mp2800 amp to a yamaha p7000s amp?
You may feed the signal from one source ,cd player,tv,etc.into both amplifiers separately;but you can not connect the amplifiers together.Let them each drive separate speakers.
Aug 16, 2014 | Audio Players & Recorders
Can i plug my phone into my p7000s yamaha amp I've bought. It has not been delivered yet. Also what is the option for speaker choice as I don't have a lot money spare. thanks.
This is a brilliant and hugely powerful amp. If you wanted you can take a 'y' cable out of your phone, mini jack into left and right 1/4inch jacks, to plug in directly. However, it would be better to invest in a small mixer, 5 channel maybe, around 40-60 pounds, with one mic channel and 2x stereo channels. This would allow you to keep the amp on full volume, for best results and control, while having a proper control unit with knobs or faders on a table top with the sound source. Far, far better than plugging in direct. Otherwise you would have to keep adjusting the controls on the amp, separate channels, which is a pain!
Take care over choosing speakers because if they are not powerful enough you will blow them up in your excitement! I'd go for a pair of 8ohm 400-600 watts rms. full range cabs - 12inch or 15inch driver with horns.
Sep 10, 2013 | Yamaha P7000S 2Channel Amplifier
Yamaha p7000s diagram
Oct 17, 2011 | Yamaha P-7000 2-Channel Amplifier
Put wrong power adapter into a Yamaha DTXPRESS IV
You should immediately quarantine what you plugged in and compare it to the correct one.
IF you put too low aq voltage of the CORRECT polarity nothing should have happened.
If you put backwards polarity of any voltage the regulator is probably fried internally and possibly an input bypass cap. Also if you put an AC adapter and it wants a DC the same destruction could happen.
if you put too high a voltage, possibly the power input cap may be bad.
It appears that the correct supply is the PA3C which is a 12 volt, 700ma with positive on the center pin.
Mar 29, 2010 | Yamaha Music
The screen of my SPX-90 yamaha reverb is showing weird symbols and the unit does not operate anymore. Any idee od the problem? Thank-you
Check the power supply voltages. Likely the 5 volts is low or out of tolerance. You MAY need to check that it is pure DC as bad filter caps can cause it to ripple out of operating range BUT still show OK on a meter.
Nov 26, 2009 | Yamaha Music
Need schematic diagram of YAMAHA P7000S
Sep 17, 2009 | Yamaha P-7000 2-Channel Amplifier
No power to filter capacitors. have power thru on/off switch to relay down to fuse, but no power to big caps / filter caps. i am suspect to a capacitor mkp61 (is this a switch?). i have voltage on the...
After switch through relay then down to fuse you should come to a full wave rectifier (solid state vs. tube?). The output of the rectifier goes to the filter caps. example: +30vdc, -30vdc with respect to ground. Best of luck.
Jul 05, 2009 | Yamaha Audio Players & Recorders
Yamaha P-7000 2-Channel Amplifier Logo
125 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
