Need a manual for a Daewoo front loader washing machine DWD F1221 please Have just got a 2nd hand one and there was no manual and i have never used a front loader i am use to top loaders
  • sparkleendc Nov 12, 2010
    thank you for your help, it was much appreciated , is great to see that there are people out there that can get the information that you need. Well done and i will pass this site onto others so that they can get help if needed. Andrea
    It was great as i was unable to get a manual for my front loader and now that i have one it will make it so much easier.
    President:
  • 1,554 Answers
My front loader fills with water but then does nothing. The drum doesn't turn. Can hear clicking sound from the control panel as though it's moving through the cycle. Checked the belt and is in good c
Does it spin if you turn to spin cycle?
Try this:
Jam lid switch with something plastic or wood.
Put on spin cycle.
Spin the tub by hand.
If the bowl then starts spinning properly, your problem is the motor starting capacitor.
May 21, 2014 | Daewoo Washing Machines
E9 message and machine stops
Jayshree, E9 error, pressure sensor error/water sensor error.
Replace water level sensor. The error display disappears if power button is turned off and on.This is what the service manual states.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Daewoo DWD M103 Service Manual Page 15 of 16
Daewoo CV701PC Service Manual Page 26 of 52
Daewoo Washing Machine Error Fault Codes
Washing Machine pressure switch
Apr 20, 2014 | Daewoo DWD M1031
Hi i have a 6.5 dwd f1221 and the drum has droped down a bit and is makeing a hell of a sound. Can you help
sounds like it slipped off it's mount, STOP USING IT. take the front cover off the machine, usually there will be 2 or 3 clips, use a flathead screwdriver to lift the clips while pulling the cover forward. Be careful not to damage the enamel. use pry bars or an auto scissorjack with some pieces of 2x4 tolift drum and set back on centre.
Apr 13, 2012 | Daewoo Washing Machines
Where is daewoo's company in cairo, egypt? I have any problem with my washing machine.
I have DAEWOO Washing machine DWD F1011. Whithin few years water started leaking through the drive shaft and ball bearing damaged. I need service manual for how to change the ball bearing or is there any repairer in Heliopolis, Cairo area?
How many year the machine is guaranteed??
Thanks lot.
Panchal
Aug 19, 2010 | Washing Machines
Daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Nov 16, 2009 | Daewoo Washing Machines
Wire from wifes bra came out during wash and went through holes in drum on Daewoo Air Power DWD 1212S. Moving drum even by hand and the wire can be heard making scraping sound
If a front loader, put washer on a bench to allow proper viewing. If you cant apply tweezers to the b.c.spring from inside the drum, then you need to find the heating element. 90% of the time, the B.C.spring will be lodged against the element structure Remove element them carefully rotate the drum while looking inside the element hole. If you see it, devise a tool to remove it. Reassemble it and back to normal.
Sep 16, 2009 | Washing Machines
Error code E8
Most likely a control or motor issue. Probably should call service.
Sep 15, 2017 | Daewoo Washing Machines
Daewoo Washing machine Problem
If it is new then it is under warrty plz call the dealer you bought iy from for service
Aug 02, 2008 | Daewoo Washing Machines
Washing Machines Logo
248 people viewed this question
Top Washing Machines Experts
