Question about Reliance Water Heaters
Water pouring from overflow pipe into kitchen. We have Reliance Water heater TPR 15 (5254-c) model
  • 3,640 Answers
The pressure valve is bad where over flow pipe hooks to. go to a place where they sell heater parts, and buy a new relief valve!! good-luck!!
Posted on Nov 18, 2010
Reliance 501hot water runs for just a minutes then runs out
http://waterheatertimer.org/How-to-fix-water-heater.html
Identify type of water heater
http://waterheatertimer.org/Crossover.html
Check for crossover
http://waterheatertimer.org/Leaking-water-heater.html
Broken pipe leaking all the hot out of tank? Turn off all water and put ear against pipe.
Gene
Jun 25, 2014 | Reliance Water Heaters
Reliance 501 electric water heater
Reliance-Rheem may have changed away from generic parts so you have to buy special order parts from them.
I have not heard of this before for elements... but Rheem does that for other parts.
Avoid Rheem products.
Rheem also makes a 1-3/4" element to fit Marathon water heaters, instead of standard 1-1/2"
Actual thread size for standard water heater is same as 1" pipe, except straight thread instead tapered pipe thread.
See if 1" pipe will thread into water heater element opening.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Gene Haynes
Feb 15, 2014 | Water Heaters
Water is leaking from the pipe on the top of the tank (Reliance 606 electric) where the hot water comes out and goes into the house. Likely causes?
If tank is rusted out, then that is caused by depleted anode rod, or tank that is not electrically grounded on hot side pipe.
If pipe nipple is rusted out, then that can be caused by improper connection between copper and galvanized pipes, and caused by non-grounded hot water pipes.
If tank is leaking, replace it.
If nipple is leaking, remove with pipe wrench, apply teflon tape or joint compound on threads, and install new nipple. Replace anode rod if possible. Correct copper-galvanized connections. Add ground wire between hot and cold pipes.
http://waterheatertimer.org/Replace-anode-rod.html
Aug 25, 2011 | RELIANCE ELECTRIC WATER HEATER
I have a reliant 606 electric water heater and I noticed that i wasn't getting any hot water. I shut the water off and look to see if i could see any problems. I cut the water on and notice that wate...
Problem is not clear:
Sounds like you have two different problems, but overheated water heater can cause both problems:
Before calling service technician, open following links for full do-it-yourself troubleshoot.
ADD A COMMENT for more details after looking at information below.
1) No hot water could be bad thermostat, or bad element, or circuit breaker is tripped.
Open following link to troubleshoot electrical problem with electric water heater:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
2) Leaking water heater.
Open following link to identify problem with illustrations and troubleshoot leaking water heater:
Look carefully at illustrations on page:
If drain valve is leaking, then put a garden hose cap on it.
If TP overflow pipe is leaking, do NOT cap that pipe
Jun 27, 2011 | RELIANCE ELECTRIC WATER HEATER
Water leaking from overflow.
This is not an "overflow". It is a Temperature/pressure relief valve. Sometimes they leak with age or build up solids in valve preventing them from closing completely. This is the single most important safety device on your water heater. If one of the thermostats is malfunctioning, the TPR valve will relieve. If the pressure rises too high, it will also relieve. You can replace the valve, but be sure it is the same temperature and pressure rating. You will need to turn the water off and drain some of the water prior to removing the valve. Don't forget to reinstall the down pipe that directs floor to floor or drain. If a new one leaks also, suspect your temperature control. Water heaters can be bombs if the safeties are not working properly
Oct 02, 2010 | RELIANCE ELECTRIC WATER HEATER
We have a Reliance 501 Electric Water Heater. We get only very hot water in bathtub in one bathroom but not the other bathroom. Could the problem be the water heater?
No, the problem is not in the water heater. It could be the plumbing pipes were installed incorrectly.
A common problem with hot water is also found in the settings of anti-scald and pressure balance tub and/shower valves. You may only need to reset the temperature control on each faucet. Every faucet brand has a slightly different adjusting system. Hopefully you can find the faucet's brand name, and then visit their website to find the owner's instruction manual for your model.
A cross connection in the water piping system is rare, but it does happen from time to time. It would allow cold water to mix with the hot. You would need a plumber or leak detection company to locate every water pipe connection in and/or under your home to confirm and correct the issue.
Sep 05, 2010 | RELIANCE ELECTRIC WATER HEATER
Water Heaer Problems
Although rare the pipes may both me hotter near the heater and the cold water line will get colder the farther back you go from the heater. Now I would do yourself a favor and hire another plumber to do the work on your water heater because from what your telling me these guys don't know anything about water heaters and I suspect they may have bumped your TPR valve (although if you ask them I'm almost positive they'll deny it). Here's what happens. From not be being used all the time the TPR valve gets buildup in it from your water lines, and as soon as the lever is pushed the TPR valve will constantly leak water until it is replaced. I would try replacing that first. To replace it simply unscrews with a wrench, just be sure to turn your water heater off and drain it halfway before replacing. That is the least expensive option. Next I would try putting in an Amtrol Expansion tank. Your local home store can get you the right one. It expands when there is excess pressure in the line. A plumber would have to install this and if you already have one make sure it is working properly. These are the only two things that would make a TPR valve leak. So while the two are not linked, I still don't think it is a coincidence.
Jun 26, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Hot water coming out of overflow pipe on my vulcan everhot water
Assuming you are talking about the temperatur/pressure relief valve, it is stuck open.
1. Turn off gas or electric to water heater
2. Close water supply to water heater
3. open hot water faucet on nearest fixture to depressurize hot water system.
4. close tpr valve (you may have to push in on the center spine. It may be resistant to closing from sediment. If so, opening and closing several times may solve that issue.
Once you get the tpr valve closed, close the faucet and open the supply valve. If the tpr stays closed, go ahead and turn on the gas/electric and re-light pilot and turn on control etc.
If the TPR blows again, you will need to replace it. YOu can buy a new one at any plumbing supply store. Shut down the heater again, drain a bit of water out using the valve on the bottom of the tank. there is probably copper pipe connected to the TPR valve which you may have to cut or maybe can just unscrew. The TPR threads out of the tank, install the new valve (make sure to use pipe dope or teflon tape.
Jan 04, 2009 | Water Heaters
Water Heaters Logo
172 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
