Question about Rangemaster Range Cookers Kitchener 110 Ceramic Green/Gold Trim Electric Range
Hi, I seem to be having a problem with my electric grill. it won't turn off. The Grill knob will turn it up in temp , but the grill still functions when switched off. This means I have to turn the whole cooker off at the wall, or use the grill every time i cook. Any ideas what may be causing this? many thanks J Mears
  • 13 Answers
THE GRILL SWITCH NEEDS TO BE REPLACED
Posted on Jan 24, 2011
My belling electric grill seems to be over heating when I've only got it on number 2
Electric elements overheat when:
1.) The temp. sensor has failed
2.) The element is improperly grounded/shorted to ground...
3.) The knob is loose and not indicating the actual setting
Jun 25, 2016 | Belling Ovens
Grill temp. too high
Replace the thermostat for the grill
Apr 08, 2013 | New World 70TC Electric Single Oven
NEW WORLD - NW601FP Electric Oven
i believe after buying this oven that the left knob at turning clockwise position 1 is defrost which works by just blowing room temp air around, position 2 is oven on, position 3 is conventional grill must be used with door open and position 4 is fan grill can be used with door closed ,and the knob on the left is for setting oven temp and and turn fully round when using the grill to heat the grill
Jan 17, 2012 | New World Ovens
I have a cooker model venezia FE 8622EX and i dont have a manual for it and cant work out with knob does what as the writing is rubbed off through use...please help!
The 3 knobs each have 6 positions corresponding to clock-face positions 2,4,5,7,8,10 o'clock.
Left - Grill Temperature 1-6. (Note Oven Temp needs to also be turned on before grill will work.)
Centre - Function
1 - Lamp
2 - Defrost (fan only)
3 - Fan Assisted Oven
4 - Grill
5 - Grill with Fan
6 - Fan & Bottom Element
Right - Oven Temp 50,100,150,200,250,Max (celsius)
Sep 12, 2011 | Ovens
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
The temp/flame on my weber grill won't get hotter
Check the excess flow safety device, which is part if the barbeque to cylinder connection, may have activated. To reset the excess flow safety device turn all burner control knobs and the cylinder valve off.
Disconnect the regulator from the cylinder. Turn burner control knobs to high. Wait at least 1 minute . Turn burner control knobs OFF. Reconnect the regulator to the cylinder. turn cylinder valve slowly.
Mar 06, 2009 | Weber Spirit? E-310 Propane Grill
Temp
Not sure on your climate.
But a Holland grill cooks cooler in the coller months and Hotter in the hotter months. This type of grill doesn't reach a very high setting approx: 400 degrees. It might reach higher temperatures in the hotter weather 450-475 degrees.
Also, it has to shut down the same way every time you use your grill.
Here is a Tip to fix a grill that not getting hot:
1. Turn the gas valve knob off. then close LP tank valve knob.
2. Unscrew the plastic hose coupling knob from the LP tank. You may hear a slight "hissing" sound as pressure is released this is normal.
3.Wait a minute then screw the coupling knob back on to LP Tank.
4.With lid open.slowly open LP tank valve.
5.Relight the grill the proper way by turning gas valve knob to ON position while turning the igniter knob at the same time.
6.After you are sure the grill is lit preheat the grill for 30 minutes.
This was called purging the line or releasing the air out of the line.
Another thing your orifice could be clogged with spiders or dirt. If it is LP gas check to make sure your hose is not kinked.
Hollands are known for the slow cooking process and a Healthy way of cooking!
Apr 27, 2008 | Grilling
Rangemaster Range Cookers Kitchener 110 Ceramic Green/Gold Trim Electric Range Logo
229 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
