Question about Fisher Refrigerators
We had an error code F13 coming up on our fisher and paykel fridge, we've changed the circuit board and now it beeps and the beeps get closer and closer together
SOURCE: Error code F32 for fisher
All you need to do is, take out 3lt of water from the tab on the fridge without stoping . This will take all the air out from the water tank at theback of the fridge (This will also stop leakage)
Posted on Oct 04, 2008
SOURCE: Fisher Paykel Fridge Freezer
I have a Fisher and Paykel E442B upside down, which is a very similar model, and I just fixed the same problem (temperature was around -4C even though I set the fridge temperature as warm as possible).
The cause of my problem was excessive ice build up on the side of the evaporator coil (which is in the back of the freezer compartment behind the rear plastic panel). I had the same problem around a year or so ago, so I expect it to be a regular occurence. To defrost the coil, I removed all the drawers in the freezer, and the plastic insert by pulling out the bottom of the panel out and rotating it upwards until it released at the top. There are a couple of snap-in tabs holding the panel in, so with a bit of pulling they released. The tabs are either side of the slot at the bottom of the panel.
I then supported the panel horizontally on the top shelf so that I didn't have to disconnect the thermostat wire and the circulating fan wire.
52de81a.jpg With a small fan heater set on low, aimed roughly at the ice buildup on the left hand side of the evaporator coil, I defrosted the ice built up. This took around 2 hours or so. Then put it all back together and it worked fine.
I'm not sure why the ice build up on the side caused the problem, but presumably it interferes with the proper flow of cold air to the fridge compartment.
If you don't seem to have ice build up like I did, then it could be a thermostat problem, or a fan problem (a symptom of which would be fridge being colder at the bottom than at the top).
Got the same error here, called Fisher Paykel and the said it's an error related to the water line. They recommended running 3 L of water and see if code disappeared. If not, call service, they gave me a local company. Error code has disappeared, for now.
Posted on Nov 09, 2008
SOURCE: E249T Fisher and Paykel Beeps when door opened
Disconnect the Fridge for 5 mins. After that, should be ok.
Posted on Apr 12, 2009
SOURCE: Fisher & Paykel Fridge Freezer E402B beeping when door closed
see http://www.fixya.com/support/t675116-refrig_e402bre
Posted on Oct 06, 2009
Opening fridge door and it beeps
perhaps the reed switch (the magnetic switch to tell the PCB the door is open/closed).
With F&P fridges, the amount of beeps will indicate the error code which relates to which component is faulty.
Sep 14, 2016 | Fisher and Paykel Active Smart E522B...
What is a error 50 on a GW709NZ fisher and paykel washing machine
Error 50 Hot water inlet valve fault. Control board monitors the circuit through the valve back to the board. If it gets a bad reading it flags that error. Error 49 for the cold valve. It can be caused by a bad valve. Bad wiring connection (corrosion on plug) or fault on the control board. Most times unfortunately it is the control board that is faulty. You need someone to come & test & find which part needs replacing.
Apr 12, 2016 | Fisher and Paykel Washing Machines
Fisher paykel fridge E442b Blows fuse on circuit board Changed power point no change
probably a fault in the compressor
have an fridge mechanic call and check out the capacitor for the compressor and what else that could be blowing the fuse
Nov 18, 2015 | Fisher Washing Machines
Why does my fisher and paykel active smart fridge/freezer keeps beeping when I open fridge? As if the fridge has been open for a long time?
Does the beeping start immediately or does it follow the designed timing as stated on page 12 of the manual? You would have to check with the manufacturer to see if the feature can be disabled. Page 12 of Fisher Paykel Refrigeration User Guide ManualsOnline com
Mar 08, 2015 | Fisher and Paykel Refrigerators
The door alarm of my fisher and Paykel E372B fridge goes off when the door hasnt been opened for a number of hours. How can I stop this.
You would notice that when it beeps, there are a series of beeps, which relate to an error code - also, the temperature panel would be most likely flashing the same amount of times the beeping occurs. The code relates to a component failure that the active smart system is having problems with.
For example, 17 beeps would be error code 17 - which relates to the freezer fan is drawing less current than is expected. Either the wiring is open circuit or the fan is faulty.
Feb 18, 2015 | Fisher and Paykel Refrigerators
Faults fisher paykel
that is a communications error between the display board and the motor control board, unfortunately this can be caused by 3 things the first is the drain pump which needs to be tested with a multi meter before proceeding, then it will be a matter of plugging in a display board and/or a MC board, you only need one but they cannot be tested the only way to find out is to change them one at a time
Sep 01, 2014 | Fisher and Paykel Washing Machines
Fisher and Paykel E402B beeping, freezing symbol flashing, crisper bins freezing.
sounds like a sensor faulty will need a tech to recify the problem.
Nov 29, 2012 | Fisher and Paykel Refrigerators
Error code 47
I have the fault description paper tucked under my instrument panel on my washer. Error 47 says Basket Disengage Fault, and under that it says: The floating basket has not engaged even though the pressure sensor indicates that the tub is empty. Check that the clutch or the pressure tube is not blocked or crushed.
That's all I've got, sorry I'm no repair tech.
Jan 17, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
Error code F32 for fisher paykel fridge F32 and a spanner is appearing in the display of our new Fisher Paykel fridge model # RF610ADUX. What does this mean ?
Aug 24, 2008 | Refrigerators
Refrigerators Logo
149 people viewed this question
Top Fisher Refrigerators Experts
John Tripp
John Tripp
Joseph Hoffmann
Brian Coughlan
Are you a Fisher Refrigerator Expert? Answer questions, earn points and help others
