Question about Kitchen Ranges
Hi, Mitutoyo layer thikness gauge: Digi-Derm 2100 179-606 N-21. Question: What are E 11 and E 04 code after turn on?
Mitutoyo 543-256 linear error of 0.028mm over full 12mm stroke. Repeatability is perfect, mechanically is perfect. Is there a re-calibration procedure?
Ensure your testing procedure is perfect. If your testing procedure is proven, then you will need to send it for repair. At that point, either your scale or grid assembly is damaged or requires adjusting.
Canada's Gauge Repair Specialists
Precision Tool Works - www.precisiontoolworks.com
Jan 08, 2015 | Mitutoyo Measuring Tools & Sensors
Getting message "Measuring tool doesn't respond"
Try cleaning contact pins of U-WAVE-T cable with 91% alcohol pads
If possible replaced batteries in gauges and U-WAVE-Ts
User's Manual:
http://www.mitutoyo.co.jp/eng/support/service/manual/pdf/99MAL110B5.pdf
Quick Manual:
http://www.mitutoyo.co.jp/eng/support/service/manual/pdf/99MAL216A7.pdf
Feb 21, 2013 | Mitutoyo 02AZD730D U-wave...
Varied reading being obtained cannot calibrate is the a recommended repair facitlity in Yorkshire England
Hello. There appears to be a facility in Hampshire, I do not know the limits of the services they offer. But I have attached the appropriate page link for you, click on the "services and support" tab or the "about us and contact" tab - I'm certain they will be able to assist you further. If this helps, please rate it a four-thumbs up. Thank You.
http://www.mitutoyo.co.uk/Mit/mws.jsp?home
Apr 04, 2011 | Mitutoyo 0-18"mitutoyo Electrnc Digi-matic...
Reading vary cannot be calibrated
Hello. Here is the link to the height gage page(s) at Mitutoyo, Find the unit you have to verify model/serial number and then access their "contact us" option - they will be able to assist you. Hope this helps, if it does please rate it a four-thumbs up. Thank You.
http://www.mitutoyo.com/ProductTypeResultForm.aspx?type=1262#
Im looking for the instructions manual for Mitutoyo 543-271B
For any manual contact Mitutoyo nearest office , they are professional and will help you.
Feb 13, 2010 | Measuring Tools & Sensors
How to reset Mitutoyo 314-351 "V" anvil micrometer. It should not read "0" when turned all the way in.
In order to reset the zero point for your specific micrometer, you will need to have a standard set of pre-set dimensional pin(s). You can check the attached link (page 71 of the Mitotoyo catalog) for the information you need). I guess you could try to find or make a pin with the same dimensions as those noted on the catalog page, but if you're using this in a manufacturing setting, you might have no choice but to purchase a set of gauges for calibrating your micrometer.
The only other option is to contact the manufacturer for an alternative method, but I doubt they'll be able to provide any alternative, as precision setting of the zero point is required for accurate readings with this specialty micrometer.
http://www.mitutoyo.co.jp/eng/products/micrometer/Micrometer_2.pdf
Jul 28, 2009 | Mitutoyo Measuring Tools & Sensors
How to measure surface finish at the bottom of a deep pocket?
Machinist, Inspector, Tool & Die Maker, for A.B.B Raymond Division, 1987-94
You need a Portable Surface Roughness measuring tool. Mitutoyo
is one maker of these. Be prepared for a $$$$$$$$ shock, as these babies aren't cheap!
SJ-201, SJ-301 and SJ-400, are three examples,
1.http://www.directindustry.com/scripts/IDPHeader.php?s=4906&URL=http%3A%2F%2Fwww.mitutoyo.co.jp%2Feng%2Fproducts%2Fkeijyou_hyomen%2Fhyomen_01.html&IDVisite=293213&MotCle=&RefCat=&IDProduit=12095&IDProdSource=&SourceType=Produit
(If the above link doesn't work for you, then try this one,
http://www.directindustry.com/prod/mitutoyo/roughness-tester-4906-30234.html
Scroll down the page, and click on -> Portable Roughness Tester)
May 05, 2009 | Mitutoyo Measuring Tools & Sensors
After turning height gage the display turn to 8888
Yes I have a parts list. send me a fax nuber and I can send you a copy. Bad news though a lot of the parts are discontinued.
Jan 02, 2009 | Mitutoyo 0-18"mitutoyo Electrnc Digi-matic...
Fluke 8060AA digital multimeter
The fuse has nothing to do with the display.
The contacts of the LCD are probably oxidized because of its age. With the unit out of its care, carefully remove the LCD from its retaining mount. Use rubbing alcohol and a clean q-tip to clean the contacts of the LCD and the small "rubber-like" strips that contact both sides of the LCD. Also, remove the strips and clean the other side and the contact on the main circuit board. Then reassemble.
*Note, if you live in a cold climate, freezing of the LCD could also cause this problem. In that case you must purchase a replacement LCD from Fluke.
Oct 10, 2008 | Mitutoyo 0-18"mitutoyo Electrnc Digi-matic...
Kitchen Ranges Logo
212 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
