Question about Loewe Concept L32 Platinum 32 in. LCD TV
Can you remove speakers from the concept 32? - Loewe Concept L32 Platinum 32 in. LCD TV
I need the service manual of TV LOEWE CONCEPT L32. The image is running horizontally, how do adjust or reset of system software?
I can supply the service manual, but I'm only go to do so when I know that you have returned to FixYa for an answer. I regularly waste time posting all the information for people only to find they never return and I would need to upload this to a filesharing site for you to download. I trust you can understand my reasoning here.
Regards,
BElectric
Jan 29, 2011 | Loewe Concept L32 Platinum 32 in. LCD TV
What cords do i need to up a DVD Player with my Loewe Concept tv?
Check ur DVD player and read ur instructional manual find out if ur DVD player have a HDMI port hub?Tries websites like Amazon.com,Ebay.com to buy a HDMI cable.That the esiest way to hookup a DVD player to a LCD or a Plama tvs.Just one HDMI cable to the DVD player HDMI hub and the other side of the HDMI cable to the tv HDMI hub.
Nov 27, 2010 | Loewe Concept L32 Platinum 32 in. LCD TV
Everytime I turn my on samsung ht-q70 the display screen says protection and the system shuts off. what can i do to get the protection off
The amplifier has a bad channel, or is bad itself. It is trying to either output too much current or is not putting out enough. If you have multiple speakers wired to one channel, you will either have to change the wiring to series(unit positive to first speaker red, first red to second BLACK, second red to unit negative) or remove on speaker. (If this is the case, then you might want to look at this. It is a tip/rick to place and properly/successfully run three subwoofers, but the main concept can be used on all channels.) If all channels are wired to he correct speaker, then the amp is in fact at fault.
Jun 21, 2010 | Samsung HT-Q70 Home Theater System System
I wont to know if i can run 2 2410s concept amps bridged and how to do it thank you .they can run at 2410 watts at 1ohm or 1150watts at 2ohm .iam wanting to hook them up on a rdaudio v2 15 that is duel...
If you only have one of those speakers the lowest load you could present to an amp would be 2 ohms. So 1 ohm is out of the question. I would advise you to get another speaker and use 1 amp per speaker bridged mono @ 2 ohms. Connecting the outputs of power amps together is not advisable.
Dec 18, 2009 | Concept CD-2410 Car Audio Amplifier
Can I bridge channels on my JVC RX-D201S it cuts out when I turn the volume above 30 I want to drive 2 x DALI concept 6 front speakers 2 x concept 1 rears and a concept centre. Do you think I can add the...
putting the extra speakers on wont solve the problem the unit has a max output it might give a better alround sound so it will be clearer a little but pushing to far on standard speakers wont help if you need better go for some active speakers there more exspensive but will give better definition and the volume limit might be higher.
Aug 06, 2009 | Audio Players & Recorders
What speakers
Hello enot99,
The CC-2502 is a bridgeable 2-channel amp. If you want to drive normal speakers in stereo, the best would be a good set of components with separate woofers, tweeters, and crossovers. They are available in many sizes from most car audio manufacturers. I'd begin by finding out what speakers fit the location where you intend to mount them. Then I'd browse the speaker selections in that size at www.crutchfield.com. You can also use the "outfit my car" feature to browse only the products that fit. Then select a pair that has a power range and impedance to match the amp: 250 watts RMS at 4ohms or 450 watts RMS at 2ohms.
If you want to use the amp in bridged mono mode to drive a subwoofer, again Crutchfield has a large selection of subs and some enclosures already fitted with subs (loaded). The amp claims 850 watts RMS into 4ohms bridged, so look for a sub that has a power handling rating of at least 850 watts and it needs to be 4ohms.
Hope this helps.
Aug 02, 2009 | Concept CC-2502 Car Audio Amplifier
Concept mobile dvd
I have a Concept DVP 500 dvd player the audio quit working through speakers, was programmed for a certain station. what could the problem be or solution to fix it
Apr 07, 2008 | Concept Slot Load Half-Din DVD Player Car...
Speaker load
seeing that is a a/b class concept i know it will do 1ohm but if dont have good battery power stay at 2ohms with it and it will do fine
Dec 28, 2007 | Concept 460 Watt 4X60, 1X200 5-Channel...
Loewe Concept L32 Platinum 32 in. LCD TV Logo
35 people viewed this question
Top Loewe Televison & Video Experts
Jerry Umali
Grantec 2000
Level 1 Expert
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
