Question about Sony STR-DE475 Receiver
How can I fix the time delay on my sony str-de475 receiver?
SOURCE: Sony STR DG 510 receiver manual
Hey there, found it on the sony site...
http://esupport.sony.com/CA/perl/model-documents.pl?mdl=STRDG510
Hope that helps.
Posted on Oct 19, 2007
  • 3 Answers
SOURCE: code for sony receiver model str d565 protect mode
If you need support you can log into:
http://esupport.sony.com/US/perl/support-contacts.pl?mdl=STRDG510
for free tech support on sony chat line
Posted on Jun 02, 2008
SOURCE: left channel is out sony STR-D511
Had the same problem but found simple solution. I just reconnected the speakers which were on "A" connections to the "B" set of connectors immediately below - problem solved!
Hope this works for you.
Stuart
Posted on Jan 22, 2009
SOURCE: No sound from rear speakers during test tone usng Sony STR-DE475
I had this problem last night.
To solve it, you can reset the amp by:
1) Put the receiver on stand-by
2) Hold down "MODE" button and press on button
3) "S.F. CLR" appears in the display and surround is back on.
Good luck
Dr Gardner
Posted on Feb 10, 2009
dunnbiker
  • 8546 Answers
SOURCE: STR-DE475 receiver flashes "PROTECT" when turned on
Protection is usually a sign of overheating or something is wrong at the power amplifier's output.
Theory: Protection is a delay and sometimes an internal test to allow the electronics to stabilize during power up before they are allowed to interact with the speakers. The most common cause of it remaining ON is that a speaker cable pair is shorted. Some isolation is required...
1. Turn the Power OFF.
2. Disconnect each set of the speaker wires that are directly attached to the receiver. Mark them so you remember where each one went. pay special attention to which conductor is on "+" or "POS" and which is on "-", "COM" or "Ground". You may elect to disconnect them one pair at a time if your sytem is complex and you don't want to lose track of where things were.
Turn the Power ON. Is the "Protect" indication gone from the display?
If YES, you have a shorted speaker wire or speaker. To isolate the specific cause:
2. Attach ONE speaker wire pair at a time and test it by turning the Receiver ON. When the "Protect" light returns you have isolated at least one of the cause(s). Disconnect the defective speaker cable and continue isolation of all speaker cables. Visually examine the cable at both ends for frayed wires that could touch each other or contact metal on the receiver or other objects.
To isolate further within the cable/speaker pair - disconnect the speaker end of the cable on the failing path. Try another cable that you know works, or at least one that doesn't cause Protection to stay on.
If you're electrically savvy and have a Digital Volt/Ohm Meter you can troubleshoot the short(s) with it.
If NO, there is probably an internal problem.
Is it solid or does it come on after the Receiver has been ON awhile.
It could be overheating.
Is the unit hot to the touch?
Is there a cooling device (fan)?
Is it stopped or clogged with dust?
Is there adequate ventilation around the unit for air to flow?
Clean any ventilation slots on the top and bottom of the unit.
Avoid stacking components that produce heat under an amplifier or receiver. Their heat rises. Also keep them away from other heat sources like like home heating vents and radiators.
Problem solid and NOT related to the speakers or heat: internal malfunction.
Let me know.
Posted on Apr 02, 2009
Helo ! I need to know why the subwoofer is silent when I connect it to my receiver-STR DE 475 . Plus , the sorround does not work . When I push the bottons , I either get the centre with the front...
Have you looked at the manual? There are procedures for adding a sub (which is NOT necessarily assumed to be there) and assigning bass to it.
http://www.retrevo.com/support/Sony-STR-DE475-Receivers-manual/id/387bh949/t/2/
Then there's the unidentified sub's manual and requirements to consider.
Sep 01, 2011 | Sony STR-DE475 Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
That didnt help rsgardener! Maybe some other tips please?
Jul 14, 2009 | Sony STR-DE475 Receiver
I have a sony STR-DE475 and the surround speakers have stopped working.
have you checked ur cables and connectors? check them with the multimeter and confirm
Jul 08, 2009 | Sony STR-DE475 Receiver
Working the Sony STR-DE475 5.1 Channels Receiver
It has a dedicated sub out. you need a phono connection on one end for the amp and the other end must have a compatable connection to your sub.
You will need a phono connection to the amp from your TV. You can utilise a scart lead that has phono outputs however a TV with audio outs (the red and white leads) is the default option.
Mar 31, 2009 | Sony STR-DE475 Receiver
Good luck
Dr Gardner
Jan 21, 2009 | Sony STR-DE475 Receiver
Sony STR-DE475 Receiver Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
