Question about Toshiba 42H81 42" Rear Projection Television
The picture is "ghosting" or doubled
  • Toshiba Master
  • 8,457 Answers
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost like $300-350 for parts and labors.
Posted on Nov 12, 2010
Am seeing double picture how can I adjust it
Double picture (ghosting) is caused by the convergence circuit failing or a bad antenna connection.
Jan 29, 2016 | Hitachi 61SWX10B 61" Rear Projection...
What if my samsung tv has ghosting images/horizontal
thats a convergence issue I will need the model number of your samsung in order to assist further with the issue.
Mar 19, 2013 | Televison & Video
Ghosting or a 3D image. A yellow and blue ghosting or shadowing image. Looks much like the top picture in the "picture ghosting image" entry. Is this a convergence problem?
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 09, 2011 | Toshiba 50HX70 50" Rear Projection...
Starting last night our tv has had a "ghost" thing
What you have is a very common convergence issue which could either be rather spendy if you take it to a technician like me. It usually costs approximately between $300-$400 if yo bring it to someone who knows what they are doing OR you could go to www.tvrepairkits.com and order the convergence repair kit for about $75-$80. Ed will set you up with the resistors, the integrated circuits, thermal paste, and step by step directions. It would take a novice about an hour and a half to complete the repair and you would save yourself some money. Sorry, there is no scan option to fix it.
Dec 01, 2010 | Sony KP-51HW40 51" Rear Projection...
My zenith sentry tv has a double image on the words that come on screen. The people are clear but all wording has double images
Hello
Double images are technically called Ghosts, occures due to the setting and direction on the antena. You have to reorient your antena, in such a way that Ghosts disappeares from your screen. The reson for this fault is not with the TV, as it gets a direct transmission signal, and a reflected signal of the same, reflected from near or far objects, like tall buldings, hills and so on. The signals, the orginal and the reflected, will be processed by the TVs internal ciiruit, and the first will appear as strong picture, followed by the second, a weak picture, will be seemed as an image of the first one, just on the right side [view point] of your TV.
You just adjust the position and height of your antena, looking the picture, where there is minimum Ghost level is. No other repair should be done to your TV, as it is perfect, and you just give it only direct signal path. OK.
Nov 22, 2010 | ZenithZ2541S 25" TV
Big screen showing double and red ghost color
Go into your service menu and try to adjust the convergence, if it does not adjust, the IC's ( chips) are bad in that circuit. Call a local factory authorized dealer to service your tv. The cost should run around $450.00. Good luck.
Mar 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Double picture
Can you give more details? What do you mean by Double picture? Do you have 2 pictures side by side or One on top of another? Or is it like a shadow behind the main Image? If it is a shadow (Ghosting), check your Antenna - connection, direction, etc.
Sep 05, 2007 | Sony FD Trinitron WEGA KD-27FS170 TV
Toshiba 42H81 42" Rear Projection Television Logo
130 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
