Question about Samsung SyncMaster 172N 17" LCD Monitor
Screen doesn't light up ! Green led is on for a few seconds and then gone ... ? Thanks for help .
  • 516 Answers
When you turning on your computer and when you heard a 1 beep that means your computer is functioning, but 1 beep with no display that means you need to check you monitor or try to transfer your lcd monitor to other computer to check if your monitor is working.
Posted on Nov 12, 2010
Testimonial: "Thanks, is there a fuse in the monitor ? or what is typical "problem" with these screens ? "
  • Carlo Barzo
    Carlo Barzo Nov 19, 2010
    If its not displaying any colors or images, probably your electronic parts inside of your monitor had blown out. If you have time, try opening your monitor and check for the electronic parts that deformed. Most of the time, capacitor is always blown out due to heat. Change it with the same electronic value example 1000 microfarad and same voltage or not to much higher voltage example 6.3Volts to 10Volts.
  • geramot Nov 22, 2010
    Thanks Cygers,
    inside looks like "overheated" but nothing " blew-up " , I should find an electric wire-plan to find more details ...
    Have a nice day ,
    Ciao
LG 55LX6500 55 inch LED TV display gone, but sound works.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
Jan 02, 2016 | LG Televison & Video
My nokia e7 screen has gone to a black and green glitch back ground
Have you tried a reset by holding the power key down for 10 seconds?If that doesn't work you can try removing the battery for a few seconds.
I had a similar problem with my E7, it was dead and wouldn't respond even when I plugged it into my PC. But once I had removed and replaced the battery it was working fine and its not gone wrong since. Here's a good guide on removing and replacing the battery
Dec 28, 2011 | Nokia E7 (16 GB) Smartphone
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
The screen is black and green LED lights up - what
the battery is probably to low. very common problem with these and many other models...hook it up to your computer via the usb cable for a few hours to get a good charge on it. then press and hold the power button for up to ten seconds.
if that fails, let me know and we can try something else, but this usually works 99% of the time
bill
Nov 10, 2009 | Tomtom GO 920 GPS Receiver
Samsung 191T Blank
You need a fluorescent back light and inverter kit. Available on eBay.
Jun 10, 2009 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Sharp 52" Aquos LCD Will Not Turn ON-Blinking LEDs
I had a similar problem. Fleeting video, then audio only for few seconds and then nothing except the green power LED blinking on and off.
I changed the power inverter board, backlight inverter boards and power supply board but still the problem is not gone.
Just 18 month old TV and out of warranty.
Jun 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Screen picture & LED green light keep flashing on and off
no it is a few bad capacitors on the vga board internal thes need tobe replaced or you can return the monitor if it is less than a year old
Dec 03, 2008 | Microsoft MNTR TYRIS|LCD 19' 8MS DVI...
Green led light flashing on 700p proview flat panel and no picture
I have a similar problem.
Switching the screen off (front panel button) and on again after waiting a few seconds fixes it.
This is a recent problem, so I'm expecting it to get worse and worse until one day!!!!!!
Oct 03, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Samsung SyncMaster 172N 17" LCD Monitor Logo
371 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
