Question about Exercise & Fitness
J need manual for TCM 236676 - Exercise & Fitness
Transmission module
automatic transmission, right?
dont shift , impliese but fails to say, by whom.???
on mine a 5speed manual stick, it can't shift by many a way.
ill take a wild guess and its an A/T
Don't shift.
ok, now I scratched head, do you mean
it stuck in 1st gear.
or did you mean its slipping , and feels like in neutral at all times.
or skips gears?
during these early transitional years, they had 2 transmissions
the newer one is electrically shifted.
and going farther we need to know what trans is really truely there.
we are blind here and cant see what you have.
if your car is a TCM shifted tranny (TCM is tranny brain,puter)
it has scan codes. so dump the tcm error codes.
http://geometroforum.com/topic/5011680/1/#new
or log into alldata.com and read the TCM page.
its not a secret , all metro FSM cover this.
fsm means , the Factory service manual. get one.
or log in.
Mar 24, 2014 | 1992 Geo Metro
TCM-P07250 / TCM-P 2733-00 / TCM-P 08960
Verify the fluid level is full (not overfilled!) and the color and smell of the fluid. It should be light red color (usually) and not smell burnt @ all.
GL,
Td
Mar 14, 2014 | Volvo Cars & Trucks
TCM or shift solenoid
SCAN IT.
WHAT CODE?
on 96 cars some can only flash codes.
so read the manual FSM>
or login to alldata.com and read how to scan your TCM.
on about 1997 most cars the PCM gets all TCM codes side loaded.
prior to that , its a jumper wire, to the TCM and OD blinks some tranny lamp blinks.
RTM
Feb 09, 2014 | 1996 Toyota Camry
New 30rh transmission was installed in my 97 4.0l jeep wrangler and it shifts in all gears except for 3rd! even when it downshifts it goes through all gears but 3rd? please help
why not ask installer that.
btw , the TCM can fail and do that.
that is either a separate module or part of the PCM.
The TCM does all shifting. electronic, shifting it is.
the TCM has scan code errors, did you scan it and the PCM for errors.
if not , why not.????
2>3 shift failure.
even a loose or corroded , trans wired connector can fail.
or the tranny ground strap is missing.
saw a guy replace a tranny 3 times. and all 3 times failed.
he never knew the trans must be grounded perfectly .
his was missing, others simply broken, others rotted away.
what we do is make sure the TCM is sending the correct
voltage single 0v.12v, etc. to the transmission solenoids.
if not, the TCM is bad, or is in limphome. or inputs wrong.
TCM have what is called limphome that can skip gears.
my 4speed skips 2nd , in limp, by DESIGN !
all this is covered in the FSM, why not read it.
or look at alldata.com it's there too.
i also have a switch box, i made., that attaches to the tranny
allowing me to make a manual transmission,
if that works the tranny is good.
the TCM will in fact mess up if its inputs are wrong
just like all computers do.
inputs are, TPS, VSS1 , VSS2, engine heat. shift selector switch PRNDL , and others.
The TCM shifts by the state of inputs. period
one cool thing, some cars pre 98, or so
the TCM is separate box. and with it unplugged
the shifter is now a manual transmission car. (for test or?)
have friends driving like this for 3 years.
Aug 04, 2013 | Jeep Cars & Trucks
06 mazda 6 battery was crossed polarized, however the TCM fuse blew and we were able to start the car. Now the car shifts hard and will not shift out of third it seems. Any suggestions,? is the TCM fried?
Sounds like you may have fried the tcm I would go to car-parts.com and get a good used one. You could check and see if there is any fuses that you blew out that control the tcm if you have a manual for the car you can look at a wiring diagram and find out what fuses are associated with the tcm if not check them all.
Nov 30, 2010 | 2006 Mazda 3
Batteries on my Terraillon TCM Nuance keep going
contact the manufacture and they will send you the file via PDF (email)
Apr 27, 2010 | Terraillon TCM Nuance Memory Bath Scale...
I need opersation manual
http://esupport.sony.com/US/perl/model-documents.pl?mdl=TCM900DV&LOC=3
Nov 13, 2009 | Sony TCM-900DV Handheld Cassette Voice...
I need a manual in English Sony TCM-150 Cassette Recorder
i find user manual for your recorder, download manual from the link>>
http://www.usersmanualguide.com/sony/voice_recorders/tcm-150
please do not forget to rate this solution.
Thanks for using FixYa.
Jan 28, 2009 | Sony TCM-150 Handheld Cassette Voice...
Exercise & Fitness Logo
101 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
