Question about SanDisk 2GB microSD Memory Card
My memory card is blocked and i do not know that how to unlock it
    Problem Solver:
  • 3 Answers
If you are not able to write anything to the sd card, you might have activated the write protect.There is a lock key(a tiny slider) which you can move to make it read-write.
Posted on Nov 13, 2010
My camera says the my memory card is locked.?? i dont no how to unlock it My Ixus 70 says my card is locked, but the card is NOT locked (button on the side of the card is in unlock position). The came
Oops. The little latch on the side in the unlock position, should engage a switch in the camera, indicating the memory card is not writ protected. It is not an electrical switch doing something in the memory card. But is the switch in the camera is defect, you get the same result. If someone once tried to press in a memory card, the wrong way around, this could have been the cause of a damaged switch. Just check the memory card slot, of nothing is in the cardholder, blocking the little switch from working correct. Sure the switch is in the up position, like in the picture? 25288825-qj532vtjsqner5bmetfl14fj-5-0.png
Nov 18, 2014 | Sony Cyber-Shot DSC-W530 Digital Camera
Tip
Unlocking SD Memory Card of Nokia 2690
Nokia 2690 is a mobile phone made by Nokia Corporation. Nokia 2690 have 25 MB internal memory, microSD memory card slot with hot swapable. Many user faces problem in unlocking the password of SD memory card. As the SD memory card contains valuable data like songs,images, files, etc. To protect the SD memory card from the unauthorize use, its is protected by secure password or lock code. Some time the password gets forgotten or it gets blocked technically resulting in faliure to unlock the SD memory card. To unlock the SD memory card password you need the utility called FE Explorer. After installing the FE Explorer in the phone, insert the card in to the phone but do not access it. After running the FE Explorer open the path C:system. There is a file called mmcstore. Rename the mmcstore file to mmcstore.txt. Transfer the mmcstore.txt to the pc or laptop and open it in notepad. After opening the file there is a password to unlock the SD memory card of Nokia 2690. Using FE Explorer we can remove the password of other micro SD memory card like Kingston, SanDisk, Verbatim.
Please download the software from the link provided below :
http://fexplorer.en.softonic.com/download/25347
Also visit the help link provided below :
http://www.mobiclue.com/recover-memory-card-password-from.html
on Jun 14, 2011 | SanDisk 2GB microSD Memory Card
Unlock memory card
to can put the micro card into a adapter card that you use to put your phone info onto your computer and there is a switch on the left side of the adapter put it into the unlocked position which I believe is up and then take out ur micro card it should be unlocked. I know Kodak SD cards have this feature with the adapter I unlocked my micro card this way
Jul 27, 2013 | Nokia C2-01 3G Mobile Phone Bluetooth...
Memory card blocked
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Memory Sticks have a slide switch on the back, near the contacts. Slide the switch away from the "LOCK" position.
Jul 08, 2012 | Sony Cybershot W330 Digital Camera
I cannot unlock my block memory card 4 5130 xpress music
The steps to unlock a password protected memory card of your mobile phone, is described below. Please follow the steps:
1. To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer, http://fexplorer.en.softonic.com/symbian/download#pathbar
2. After finished downloading, install it to your mobile phone.
3. Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
4. Run FExplorer and open the following location C:\system.
5. From the location C:\System, you will see a file named as mmcstore. Rename this file as mmcstore.txt.
6. Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
7. When you finished the above steps, you will find the password of that file
Rate me if this is helpful. Good Luck :)
Jun 02, 2010 | Nokia 5130 Cellular Phone
Memory card was blocked
if it says that the card it is blocked it does not need formating but see that it has a button at the side that will unlock it ..or if yo want to format it after unlocking ..insert in a device and choose format from the menu
or in a computer in a card reader..right click on the removable device ..and format ..
Apr 08, 2010 | Canon PowerShot SD890 IS Digital Camera
Insert the memory card via memory stick into your computer and right click on it. Click on "Explore", did it open. If it did not open then you can try it some other computer. I guess there's no problem with the memory card.
It sure would work if inserted into another PC.
Hope this helped.
Sep 27, 2009 | Nokia 5200 Cellular Phone
To find security code and memory card password
It is impossible to find out the security code as the phone gets blocked try taking it to a nokia costomer care on a free day thy'll reset your password.in the case of memory card belive me theres no software to unlock it try all possible combinations as it does not get blocked if not a 1gb card just costs around rs150.
Jun 23, 2009 | Nokia 3110 Cellular Phone
Memory card lock pbm
hi
sir if you dont make the password then you have to make a format memory card and mobile as well because this is the virus that make you memory blocked
thanks
your friend from fixya!
Sep 10, 2008 | Nokia 7610
Unlock 1 GB micro sd memory card of Kingston Made
my memory card is locked .i use a nokia 3110c model. please give me the solution
Jul 15, 2008 | Nokia 3110 Cellular Phone
SanDisk 2GB microSD Memory Card Logo
63 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
