Question about HP LaserJet 3055 All-In-One Printer
Fax is not working and displaying document loaded
  • HP Master
  • 7,733 Answers
Try Using the HP Network Diagnostic Utility in Windows - HP Customer Care (United States - English).
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 12, 2010
How can I send and receive a fax from Lexmark x4270.?
You can send faxes via the operator panel, the All-In-One Center, or the fax driver.
Using the Operator Panel:
  1. Make sure your All-In-One is switched on.
  2. Load up to 30 sheets of your original document face down in the ADF (Automatic Document Feeder). Note: When you load small paper sizes, place your document in the center of the tray and adjust the paper guides to the edges of the paper.
  3. On the operator panel, press Fax.
Using the keypad you can:
  • Enter the fax number, and then press Black or Color.
  • Press Speed Dial, and then:
- Use the arrow keys to scroll through the list to find the number you want, and then press Black or Color. - Use the keypad to enter a two-digit number (viewable in the upper left of the display), and then press Black or Color.
The All-In-One scans your document and sends your fax to the number you entered.
Using the All-In-One Center:
  1. Make sure your All-In-One is attached to a computer.
  3. From your desktop, double-click the Lexmark 4200 Series All-In-One Center icon. The All-In-One Main Page appears.
  4. Under Productivity Tools, click Fax an image or document.
  5. Follow the instructions on your screen to complete the task.
For a more comprehensive guide on how to send and receive faxes using your Lexmark X4270 printer, please refer to the Lexmark X4270 User's Guide.
Aug 17, 2011 | Lexmark X4270 All-In-One InkJet Printer
Machine reads document jam,checked machine seems ok,cannot sent fax.
Hi there!
The error message that you are getting means there's a jammed paper inside the machine particularly in the feeder. This may also appear if the panel is not closed securely. Try to open the control panel and look for any pieces of jammed paper or debris. Closed the front cover or the control panel, it should display the regular screen date/time. Once you have the regular screen load the document on the feeder, the display should change and should ask you to enter the fax number.
Hope this helps!
Please rate if it worked, Thanks
Mar 30, 2011 | Office Equipment & Supplies
When sending fax on canon pixma MX350 i get a NG error REPORT what does this mean
Hi There!
Comm Error will show on the display if there is an issue with the phone line like an interference or it's not connected directly to the wall jack.
What you can do is check if the machine has a dial tone or try to call the fax # where you need to send the fax, just check if it's ringing. Second before loading the paper make sure that the display shows date & time. Then load the document in the tray the display should show enter fax # & start. Start dialing the # then press start.
Hope this helps.
Vikroks
Mar 29, 2011 | Brother IntelliFAX 560 Plain Paper Fax
Everytime I am sending a fax i get the common error 20 02
Comm Error will show on the display if there is an issue on phoneline that were using.
First please check if the machine has a dial tone or try to call the fax # where you need to send the fax, just check if it's ringing. Second before loading the paper make sure that the display shows date & time. Then load the document in the tray the display should show enter fax # & start. Start dialing the # then hit start.
Hope this helps.
Mar 29, 2011 | Brother IntelliFAX 770 Plain Paper Thermal...
When trying to send a fax a brother 1360 and after dialing the number rings but the document will not scan and displays 'telephone'.
The reason why your mahcine shows telephone because it can't recognize the document that you loaded in.
Try to remove the document from the feeder and make sure that your mach shows date & time. Load the document again in the feeder and the display should show enter fax # & start, that's the time you need to dial the fax # and hit the start key,
Hope this helps,
Mar 28, 2011 | Brother Fax-1360
Can not send fax. The receving fax rings but my machine does not respond and send the fax. I can receive ok.
The document does not feed into the machine.
Be sure the document is not wrinkled, and you are putting it in correctly. Check that the document is the right size and not too thick or too thin. (See document types and sizes on page 43).
You cannot receive faxes automatically. Check if "TEL" appears on the right side of the display. In TEL mode, you
cannot receive a fax automatically. Be sure the handset is seated on the cradle properly.
The machine cannot receive faxes manually. Do not hang up the handset before pressing Start/Enter to receive a
fax.
The machine does not send anything. Check that the document is loaded face down. Send should show up
in the display after it dials. Check if the machine to which you are sending can receive your fax.
Dec 22, 2010 | HP 1010 Plain Paper Thermal Fax
How to fax
Load an original in the automatic document feeder (ADF)
You can copy, scan, or fax a single or multiple-page A4, letter, or legal-size document by
placing it in the document feeder tray.
The document feeder tray holds a maximum of 20 sheets of letter or A4-size paper or 15
sheets of legal-size paper.
To send a basic fax from the control panel
1.
Load your originals. For additional information, see Load originals.
2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed
dial button to select a speed dial, or press Redial/Pause to redial the last number
dialed.
TIP: To add a pause in the fax number you are entering, press Redial/Pause,
or press the Symbols (*) button repeatedly, until a dash (-) appears on the display.
3. Press START FAX Black.
If the device detects an original loaded in the automatic document feeder, it
sends the document to the number you entered.
TIP: If the recipient reports issues with the quality of the fax you sent, you can
try changing the resolution or contrast of your fax.
for further refernce check out the online manual
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
Mar 29, 2010 | HP Officejet J3680 Multifunction Printer...
Faxing to several numbers
Sending Broadcasting Faxes:
Using the BROADCASTING BUTTON on the control panel you can use the broadcasting fax feature. 1. Load the document(s) face down into the ADF. 2. Adjust the document resolution to suit your fax needs.Press BROADCASTING on the control panel.4. Enter the number of the remote machine using the number keypad. 5. Press enter to confirm the number.The display ask you to enter another fax number to send the document. 6. To enter more fax numbers, press 1 to select "YES" and repeat steps 4 and 5. You can add up to 10 destinations. NOTE: You cannot use group dial numbers for another fax number. 7. When you finish entering fax numbers, press 2 to select "NO" at a "ANOTHER NO" prompt.
The document is scanned into memory before transmission. The display shows the memory capacity and the number of pages being stored in the memory.
The machine begins sending the document in order of the numbers you entered..Hope this helps
Oct 08, 2008 | Samsung SF-560 Plain Paper Laser Fax
HP Office Jet 6110 All in One faxing
This document covers the basic fax functions of the HP Officejet 6100 series. The HP Officejet 6100 series can perform the following functions:
  • Send and receive paper faxes.
  • Send and receive color faxes. Color faxes can be sent only to color fax capable machines. If a color fax is sent to a black-and-white only fax machine, the HP Officejet sends the fax in black and white.
See Figure 1 below to identify the buttons in the Fax area of the front panel. Figure 1: Identifying the fax area of the front panel c00259777.gif 1- Turns Auto Answer on or off 2- Scrolls through speed-dial entries 3- Redials the most recently dialed number 4- Dials fax numbers, enters text, and specifies menu items. 5- Starts a fax 6- Changes the fax resolution 7- Dials one-touch speed-dial numbers Fax settings Most fax settings are configured during installation through the Fax Setup Wizard. These settings, and some additional options, can be accessed through the front panel menu (see Figure 2). Figure 2: Changing fax settings from the front panel menu
1. Menu: enters the menu system.
2. Right and left arrows: navigate the submenus and options.
3. Enter: selects a submenu or option.
4. Cancel: exits from the menu. c00259778.gif Sending a fax To ensure the best quality when sending faxes in color, use a color original instead of a color copy. Follow these steps to send a fax:
  1. Load the original. Load originals directly on the glass or in ADF. For multi-page faxes, you must use the automatic document feeder (ADF). Loading original on the glass Place the original, print-side down, on the front-right corner of the glass. Loading original on the glass c00259779.gif Loading original in the ADF Place the original, print-side up, in the ADF. Adjust the paper-width guide to fit the original. Loading original in the ADF c00259780.gif
  2. Enter the fax number using the keypad. Dial the number just as you would from a telephone (dialing 1 before an area code, etc.)
  3. Press Start Fax Black or Color.
  4. If there is no original in the ADF, the display will read, "Send from Glass? Press 1 for Yes or 2 for No"
    • Press 1 to scan the document from the glass.
    • Press 2 to load the document in the ADF. The display will read, Load original, then press Enter .
Apr 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP LaserJet 3055 All-In-One Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
