Question about Briggs & Stratton Garden
My mower tends to surge when running - Briggs & Stratton Garden
    President:
  • Briggs & Str... Master
  • 1,545 Answers
Sometimes, this is caused by the governor needing adjusting, but most of the time it is that the carburetor needs a good internal cleaning. Try adding about 1 ounce of Berryman Chem Tool to a gallon of gas that you use and letting it run through it. This is the "lazy" way to clean the carb without removing it. Sea Foam brand cleaner and Lucas will also benefit this problem.
Posted on Nov 14, 2010
Lawn Mower Surges
Check valves. Vacuum from the engine draws the fuel in...sounds like vacuum is surging. Also it may have a "fuel pump" that may be bad
Aug 24, 2016 | Briggs & Stratton Garden
What could be the issue?
Most electrical appliances are fitted with a device to prevent them emitting radio frequency interference. Some such devices do not age well or resist spikes or surges in the supply.
The problem could be with that device. I notice they tend to produce white smoke when they fail, whereas wiring and motors, switches and suchlike tend to produce an altogether darker and more acrid smoke.
May 21, 2016 | Garden
I just bought a new toro mower. the engine surges in speed about 1/sec. how can i get it to run smoothly?
If this is a brand new mower you could take it to the shop where you purchased it. I will say that newer units are set to run pretty lean to meet emission standards and may surge a bit when not under a load. You could take a look at the carb and see if there are any adjustment screws visible. A minor turn with a screwdriver may solve your problem, probably turn the screw out about 1/4 turn or so, just until the surging stops. Many of the new machines today do not have any owner adjustable parts. If you don't feel comfortable trying this, please supply a model number off the mower and more info might be available.
Oct 30, 2009 | Toro Lawn Mower With Toro Power Tools
Engine speed surges
Surging engines in lawn mowers are usually related to a lean fuel/air mixture. With today's environmental concerns, the carburetors on these engines are set with a very lean mixture (to reduce air pollution). Furthermore, they usually put limiter caps on the carburetors where you cannot easily adjust the mix to get the engine to run better.
If there are adjustment screws on the carburetor, try turning the high speed adjustment screw a bit counter-clockwise (if the limiter cap will allow it). This will enrich the fuel/air mix a bit and might help the engine run a bit better.
Oct 11, 2009 | Garden
Describe your Poulan "" Push
Please change your are filter,or clean it, I hope this helps you and thank you
Sep 10, 2009 | Poulan "" Push Mower
Engine on riding lawn mower surging
Dirty air cleaner.
Clogged fuel filter.
Replace or clean both...
May 29, 2009 | Garden
Toro 6.5 hp 9 year old mower. Starts Ok; surges
Sounds like your carburetor needs to be cleaned out. The surging is usually a sign of running to lean (not getting enough gas) because of possible water, rust, gum, varnish or trash in your carb. Hope that helps.....
May 17, 2009 | Toro Lawn Mower With Toro Power Tools
2 1/2 Briggs......doesn't run smoothly....surges at all speeds.
Hi, Check that you have the correct spark plug fitted or fit a new one as it sounds like your plug is getting hot then shorting out.
Sometimes the magnito can do this as well. but I would start with the plug.
Nov 26, 2008 | Garden
Garden Logo
213 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
