We have install httpd-devel : giving floing error see below Finished Dependency Resolution httpd-devel-2.2.3-43.el5.centos.3.i386 from updates has depsolving problems --> Missing Dependency: httpd = 2.2.3-43.el5.centos.3 is needed by package httpd-devel-2.2.3-43.el5.centos.3.i386 (updates) Error: Missing Dependency: httpd = 2.2.3-43.el5.centos.3 is needed by package httpd-devel-2.2.3-43.el5.centos.3.i386 (updates) You could try using --skip-broken to work around the problem You could try running: package-cleanup --problems package-cleanup --dupes rpm -Va --nofiles --nodigest The program package-cleanup is found in the yum-utils package
Problem with starting apache httpserver 2.4
It looks like your operating system libraries are out of date or one is missing. Install the latest updates and try again.
Feb 26, 2015 | Computers & Internet
Lexmarkx2670
You don't say which version of Linux you're using. Make sure you have CUPS 1.2 installed and then search for either:
lexmark-inkjet-08-driver-1.0-1.i386.rpm.sh for RPM based systems (RedHat, CentOS)
or
lexmark-inkjet-08-driver-1.0-1.i386.deb.sh for Debian package type systems.
Nov 29, 2013 | Canonical Ltd. Ubuntu
Sir, Please tell me How to install vlc player in redhat 5.0 linux. Thanks
How about:
Download the vlc-0.9.9a-7.el5.rf.i386.rpm RPM from http://apt.sw.be/redhat/el5/en/i386/dag/RPMS/
And then install it via the command:
yum localinstall vlc-0.9.9a-7.el5.rf.i386.rpm from the loaction you downloaded it to.
You may, also, need some other RPMs if there are unmet dependencies with your installed sofware.
Dec 31, 2010 | Computers & Internet
I got red hat 5 kernel 2.6.18-53.el5 while installining realtek lan drivers r8168-8.015.00.tar.bz2 it gives error 2 it is not locating r8168.ko file
i think that the software that you are trying to install is for the linux platform .please try to select software for the desired operating system
Dec 31, 2009 | Red Hat Enterprise Linux ES 3 Standard...
How to download and install apache on linux5
Hi Follow the below procedures.
How to install and start the Apache or httpd service under Linux
by Milind
Q. How do I install and start the Apache or httpd web server under Fedora core or Cent OS?
A. Apache HTTP Server is a free software/open source web server for Unix-like systems and other oses.
Apache features configurable error messages, DBMS-based authentication databases, and content negotiation. It is also supported by several graphical user interfaces (GUIs) which permit easier, more intuitive configuration of the server.
Use rpm command to install Apache under Linux. You can also use up2date or yum command to install the same.
Task: Install Apache/httpd under Fedroa Core/Cent OS Linux
Type the following command if you are using Fedora or Cent OS Linux:
# yum install httpd
Now, start the Apache/httpd
# chkconfig httpd on
# /etc/init.d/httpd start
Task: Install Apache/httpd under Red Hat Enterprise Linux
# up2date httpd
Start the Apache/httpd
Task: Debian Linux httpd/Apache installation
Use apt-get command:
# apt-get install apache2
# /etc/init.d/apache2 start
Task: Verify that port 80 is open
# netstat -tulpn | grep :80
You can also install httpd from CDROM with rpm command:
# rpm -ivh httpd*
Configuration
Your server is started but you need to configure and use Apache as per your requirement. /etc/httpd/conf/httpd.conf (RHEL/Cent OS/Fedora Core Linux) or /etc/apache2/httpd.conf (Debian / Ubuntu Linux) configuration file. Use text editor such as vi to edit file. This file is very well documented or read official Apache configuration documentation for more information.
Dec 30, 2009 | Red Hat Enterprise Linux ES 3 Standard...
I want to know the source code of pidgin
It is the name given to the language that a country speaks. A Country called Papua New Guinea. It is the closest country to Australia. 10x
Jun 05, 2009 | Gentoo Linux Operatimg System
On linux centos it doesn work
The CT4170 SoundBlaster "Vibra" cards are old 16-bit ISA PnP cards, and were not detected at install by Linux kernels 2.16.15-27. You need to get the "isapnptools" package from the Fedora or CentOS sites, and do the following:
2. Install isapnptools using dpkg -i path-to-downloaded file .
3. Create and edit file /etc/isapnp.conf and put the following contents in it:
(READPORT 0x0273)
(ISOLATE PRESERVE)
(IDENTIFY *)
(VERBOSITY 2)
(CONFLICT (IO FATAL)(IRQ FATAL)(DMA FATAL)(MEM FATAL)) # or WARNING (CONFIGURE CTL00f4/-1 (LD 0
(INT 0 (IRQ 5 (MODE +E)))
(DMA 0 (CHANNEL 0))
(DMA 1 (CHANNEL 1))
(IO 0 (SIZE 16) (BASE 0x0240))
(IO 1 (SIZE 2) (BASE 0x0300))
(IO 2 (SIZE 4) (BASE 0x0388))
(NAME "CTL00f4/-1[0]{Audio }")
(ACT Y)
(WAITFORKEY)
4. Run "isapnp /etc/isapnp.conf". If it reports errors, you must change configuration above (it is suited to my setup). Try "pnpdump -c" and put its output in /etc/isapnp.conf file. If it does not help, you must find the correct configuration manually, for example change port to 0x220. For full list of possible values run pnpdump. Note that if you change the configuration, you must change options for modprobe below.
5. Create and edit file /etc/modprobe.d/sbvibra and put the following options in it:
alias snd-card-0 snd_sb16
options snd_sb16 port=0x240 irq=5 dma8=0 dma16=1 isapnp=0
6. Run "update-modules"
7. Run "modprobe snd-card-0". If it works OK (check if "ls -l /dev/dsp" shows that file is present), perform the steps below to make setup permanent:
8. Append following line to /etc/modules:
snd-card-0
8. Go to system configuration (in GUI) and choose "Services". Enable "isapnp" service and tick option to start it at boot.
Hope this helps :)
Ted
May 23, 2009 | Creative Labs CT4170 Sound Card
Sound driver
when you install linux then default install sound driver if you dont't select music option then you one packet install name is sound-juicer-2.16.0.3.el5.i386.rpm
Jan 08, 2009 | Computers & Internet
Firewall is not configered is linux centos
try and go for it..all d best...
Use yum command as follows:
# yum install squid
Output:
Loading "installonlyn" plugin Setting up Install Process Setting up repositories Reading repository metadata in from local files Parsing package install arguments Resolving Dependencies --> Populating transaction set with selected packages. Please wait. ---> Package squid.i386 7:2.6.STABLE6-4.el5 set to be updated --> Running transaction check Dependencies Resolved ============================================================================= Package Arch Version Repository Size ============================================================================= Installing: squid i386 7:2.6.STABLE6-4.el5 updates 1.2 M Transaction Summary ============================================================================= Install 1 Package(s) Update 0 Package(s) Remove 0 Package(s) Total download size: 1.2 M Is this ok [y/N]: y Downloading Packages: Running Transaction Test Finished Transaction Test Transaction Test Succeeded Running Transaction Installing: squid ######################### [1/1] Installed: squid.i386 7:2.6.STABLE6-4.el5 Complete! Squid Basic Configuration Squid configuration file located at /etc/squid/squid.conf. Open file using a text editor:
# vi /etc/squid/squid.conf
At least you need to define ACL (access control list) to work with squid. The defaults port is TCP 3128. Following example ACL allowing access from your local networks 192.168.1.0/24 and 192.168.2.0/24. Make sure you adapt to list your internal IP networks from where browsing should be allowed:
acl our_networks src 192.168.1.0/24 192.168.2.0/24
http_access allow our_networks
Save and close the file. Start squid proxy server:
# chkconfig squid on
# /etc/init.d/squid start
Output:
init_cache_dir /var/spool/squid... Starting squid: . [ OK ] Verify port 3128 is open:
# netstat -tulpn | grep 3128
Output:
tcp 0 0 0.0.0.0:3128 0.0.0.0:* LISTEN 20653/(squid) Open TCP port 3128 Finally make sure iptables is allowing to access squid proxy server. Just open /etc/sysconfig/iptables file:
# vi /etc/sysconfig/iptables
Append configuration:
-A RH-Firewall-1-INPUT -m state --state NEW,ESTABLISHED,RELATED -m tcp -p tcp --dport 3128 -j ACCEPT
Restart iptables based firewall:
# /etc/init.d/iptables restart
Output:
Flushing firewall rules: [ OK ] Setting chains to policy ACCEPT: filter [ OK ] Unloading iptables modules: [ OK ] Applying iptables firewall rules: [ OK ] Loading additional iptables modules: ip_conntrack_netbios_n[ OK ] Client configuration Open a webbrowser > Tools > Internet option > Network settings > and setup Squid server IP address and port # 3128.
See also You may find our previous squid tips useful:
Nov 26, 2007 | Computers & Internet
Computers & Internet Logo
245 people viewed this question
David Payne
David Payne
