Question about Digital Audio 1500 WATTS CLASS D MONO BLOCK AMPLIFIER DAD1504 Car Audio Amplifier
Hi have audiofonics 1500 watt amp that is on protected mode, how can I get it to work? Please help !! Thank you guys
Where i buy outputs for my amps is audiofonics 2ch 2000 watt
take it to JAYcar or similar electronics shop to see if they have something suitable as a replacement
Jul 07, 2016 | Audiofonics Car Audio & Video
Jbl am in protect mode
if it goes in protect mode means ur amp is turn up to high or it is over heating so it protectn it from fryn ur amp try to adjust it down
Jul 12, 2009 | JBL BP1200.1 Car Audio Amplifier
Audiofonics adf-241 no power all wires connected fuses ok.
Hello pimprascalz,
Many amps will go into protect mode if one of the speaker wires is shorted or grounded, or if the voice coil(s) are defective. Try disconnecting the speaker wires one at a time and see if the amp still goes into protect upon power up. Likewise, some amps will go into protect if one of the inputs is grounding out. Again, to troubleshoot, disconnect them one at a time and try the amp. Next, make sure that the amp itself is not grounding. Most amps need to be mounted to a nonconductive surface. If the case contacts the frame of the vehicle, it can cause a problem. If the problem is not in the speaker wires or the input cables, the amp case is not contacting the vehicle frame, and you have checked your power, ground and turn-on leads, then the amp itself is probably faulty.
Hope this helps.
May 19, 2009 | Audiofonics ADF-241 Car Audio Amplifier
How to change the Red Protect light to Green Power.
If the amp goes into protect mode, it's likely due to shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
If the problems are not with the wiring, follow the link at the bottom of the page to the Amplifier Repair Primer page.
Let me know if you have any other questions.
Sep 21, 2008 | Audiofonics ADF-240 Car Audio Amplifier
Amp Not working!
Sep 20, 2008 | Power Acoustik TS620-2 Synchronized...
My Amp
sounds like the sub that throws it into protect mode is cross wired pull sub out and make sure they are wired right make sure ground from sub goes to ground on box and do same for power wire
Jun 11, 2008 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
HELLO CAN SOME BODY TELL ME HOW TO HOOK UP MY SYSTEM RIGHT I HAVE 2 AUDIOFONICS ADF-272 1200 WATTS AND A MTX 4501 CLASS D MONO BLOCK AND A MTX 801D KIND OF OLD SCHOOL IS LIKE 4 YEARS OLD AND HOW TO series...
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=1&woofer_imp=4
HERE IS HOW YOU HOOK UP 1 SPEAKER TO 1 CHANNELM DO THE SAM E TO THE OTHER CHANNEL. MAKE SURE AMP IS IN MONO MODE,YOU DONT WANT TO PLAY UR SUBS IN STEREO.AS FAR AS THE BOX DEPENDS ON VEHICLE AND HOW MUCN SPACE YOU HAVE .TELL WAT MODEL CAR AND ILL ET BACK TO YOU. I NEED A FIXYA RATING PLEASE
Feb 10, 2008 | Audiofonics ADF-272 Car Speaker
Audiofonics amp
Reconnect one speaker per channel and swap the RCA cables (L > R and R > L) to see if the working channel switches sides. If not, move all switches and controls to see if any are intermittent.
Jan 10, 2008 | Audiofonics ADF-241 Car Audio Amplifier
Car Audio & Video Logo
69 people viewed this question
Top Digital Audio Car Audio & Video Experts
Joe Ankney
Level 1 Expert
Matthew Spark
Matthew Spark
Tom Chichester
Are you a Digital Audio Car Audio and Video Expert? Answer questions, earn points and help others
