I got an 86 olds mobile cutlass that when i hook the positive wire 2 the battery the engine trying to start with out the key being in the ignition. and the lights stay on when the doors closed!
    Problem Solver:
  • 9 Answers
You posted this in the wrong section. Please pass go and collect 200 dollars.
Posted on Jun 18, 2008
Is there a circuit breaker or fuse to replace to solve this issue?
When you turn the key on the instrument cluster has no lights come on ? The head lamps don't work ? plug 2 and 5 where not firing and was told to reset computer by disconnecting Battery.If 2 & 5 are the only ones not firing ,disconnecting the battery isn't going to change that . The ignition module has burnt out transistor . If there was B+ voltage before you disconnected the battery you have a bad connection . Check your connections , cables ! Unless you shorted something . Do you know how to do automotive electrical testing using a voltmeter and a electrical power distribution diagrams ? This video on diagnosing coil drivers ( transistors ) is on a saturn 2.2 4 cylinder , doesn't matter testing the transistor is the same for your vehicle .
2004 Saturn Ion 2 2 Misfire Case Study P0300 you look at some other ones . Here watch this one too .
GM Ignition System diagnosis 1988 Olds Cutlass
Voltage Drop Test
May 11, 2017 | 2000 Buick LeSabre
I have a 2002 jeep liberty kj 3.7L and the fuel pump relay clicking slowly but constantly with ignition in off position? Relay already replaced, so not that. Ideas?
Are you sure that it is in fact the fuel pump relay ? With the key off no B+ voltage is supplied to the relay . Pin 86 at the base ,where the relay plugs into . Fuse #15 a 10 amp fuse is hot with ignition switch in the run or start position . Pin 85 is control from the PCM - engine computer . Pin's 30 & 87 are the load side , fuel pump being the load . If your unfamiliar with the pins i'm talking about , pull the relay out an look on the bottom ,you will see these numbers .Pin #30 will show B+ voltage all the time , pin 86 only with the key on or start .
Mar 07, 2017 | 2002 Jeep Liberty
Starter does not engage when key is turned to start
assuming battery fully charged hook test lite between good groud and small starter terminal have somebody to crank if lits chek power and ground to starter and replace starter if no lit go to starter relay terminal 30 and 87 use a piece off wire and momentarily bridge them if starter bumps the engine check terminals 85 86 one is power when cranking the other is ground if starter bumps and test lit hooked to 85 86 lits replace relay if no lite keep tracing ckt to ignition switch
Dec 09, 2013 | 1999 Chevrolet Silverado 1500
My car won't start. It sounds like it wants to turn over, but doesn't. I had a mobile mechanic come out and troubleshoot the problem. He hooked some type of reader to my car. Two codes came up. "P1631...
You might try to reset the computer. Here is the way you do it.
Turn the key to the ON position.
Then press the gas pedal all the way to the floor and let all the way off 3 times.
Then turn the key off. The next time you turn the key on it will have reset the computer. Not too sure if it will reset those codes. But it is free and worth a try!
Hope this helps you!!! If so please check YES! Thanks!
Sep 01, 2010 | 1997 Oldsmobile Cutlass
I have a 1980 honda express 2 moped that i am slowly trying to restore there are some things missing a battery and has broken ignition switch.i turn ignition on by useing a screwdriver,.my problem is i had...
It doesnt need a battery to start and the headlight will only work when the engine runs and the ignition switch is in a second position.
You will probably need to find another ignition for it to all work.
If you try dissconnecting the ignition completely at the plug, it may spark, as the ignition switch has a kill circuit in it, which is to stop the engine. the on position really only completes the circuit for the indicators and horn and brake lights.
They are only 6v, a 12v charger can damage electrics
Jul 12, 2010 | Health & Beauty
1997 olds cutlass supreme The security light is
Open ,and shut the doors,and the hood,and the trunk,then set the anti-theft,leave it set for 5 minutes,then disarm the anti-theft,and then try and start the vehicle.
Jun 28, 2010 | 1997 Oldsmobile Cutlass Supreme
96 Olds Aurora wont start nothing happens when i turn the key,battery is good.
CHECK THE INSTRUMENT CLUSTER FOR POWER TO GAUGES TO SEE IF THEY WORK WHILE IGNITION IS IN THE ON POSITION.IF NO CHECK THE 40 AMP IGNITION FUSE.IF FUSE GOOD IGNITION SWITCH IS BAD OR HAS A LOOSE OR BROKEN WIRE.IF FUSE GOOD ALL GAUGES IS WORKING.I BE LOOKING AT STARTER AND STARTER SOLENOID.REMOVE THEM HAVE AUTO ZONE TEST STARTER.OR YOU CAN GET A REMOTE STARTER SWITCH AND SET OF BATTERY CABLES.HOOK BATTERY CABLES TO A BATTERY.WITH STARTER OUT OF CAR TAKE BATTERY CABLES HOOK NEGATIVE BATTERY TO STARTER BODY FOR GOOD GROUND.TAKE POSITIVE BATTERY CABLE HOOK TO STARTER POSITIVE TERMINAL WHERE POSITIVE BATTERY CABLE GOES.THEN HOOK THE REMOTE SWITCH RED WIRE TO STARTER POSITIVE TERMINAL AND THE OTHER REMOTE SWITCH WIRE TO THE S OR SWITCH TERMINAL ON STARTER SOLENOID.PRESS THE REMOTE SWITCH IS STARTER RUNS GOOD WITH NO FUNNY NOISES ITS GOOD IF STARTER DONT RUN THE STARTER SOLENOID OR STARTER IS BAD. THE PROBLEMS IN YOUR CAR COULD BE A BAD KEY TRY ANOTHER KEY YOUR CAR HAS THE THEFT DETERRENT MODULE SYSTEM BEST TO HAVE CAR SCAN TO CHECK THE THEFT SECURITY MODULE AND THE TRANSMISSION NEUTRAL SAFETY SWITCH IF ITS BAD STARTER WONT WORK.ALSO CHECK THE THEFT DETERRENT MODULE RELAY. BEFORE REMOVING BATTERY CABLES TURN OFF RADIO SO YOU WONT LOSE YOUR RADIO PLAYING CODE.
May 20, 2010 | 1998 Oldsmobile Aurora
1006 olds cutlass supreme won't crank
try taking a power wire from the battery positive and getting it on the starter terminal and seeing if the starter turns over if it does it could be a fusible link that runs between the starter terminal and the relay
Sep 29, 2008 | 1995 Oldsmobile Cutlass Supreme
1996 olds cutlass supreme won't crank
You can jump across the celonoid on the starter. If the engine turns over then your problem is either the celonoid or the starter switch.
Sep 28, 2008 | 1995 Oldsmobile Cutlass Supreme
Olds Cutlass GL 1998
Are the battery cables corroded or otherwise no making a good connection? Clean them with a cable end cleaning tool avail at any auto parts store for around $5.00 and try it again, I bet the that is the issue, also charge the battery and have it tested at Kragen, they do it for free.
Sep 16, 2008 | 1998 Oldsmobile Cutlass
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
