Question about Acer (ACERMOTHERBOARD)
Hi There My Acer 6350g will only run on the
Hi There My Acer 6350g will only run on the battery when connected to the mains. Without the battery but with mains power it won't boot up, only lights flash once then thats it. Pluggeg into the mains the power status is correct but it still runs off the battery and doesn't use mains power thus draining the battery.
SOURCE: ACER ASPIRE WON'T TURN ON AND RED LIGHT FLASHING
acer aspire 5315 wont turn on, but the battery led lights up when the ac adaptor is connected..pls help.
Posted on Feb 24, 2009
micromend
  • 748 Answers
SOURCE: Need help for Acer Aspire ONE MODEL # ZG5 screen does not work
If you are sure the computer is running then connect an external monitor to the laptop. You will have to select the external using your Function keys FN + F7 or F8. If you can now see your machine on the external monitor then you know it's the screen portion of your laptop that is faulty. If this does not work then the sounds you are hereing are probably just the fan and the hard drive spinning. These are not an indication that the computer is working. All in all, I would say that the laptop needs to see a pro.
Posted on Mar 26, 2009
tbirdfan1
  • 3051 Answers
SOURCE: My Acer Aspire 5720 laptop won't charge while it's running
Hello there:
try removing the battery from the computer and turning on the computer to see if the power cord works correctly if it does inspect the battery and clean the terminals on the battery and computer and put the battery back in while it is still on now you should see the battery show up on the taskbar if not right click anywhere on the desktop and go to properties and than go to than go to screensaver than look towards the bottom and you will see power click on it and you should see the options for the battery ok sorry this was so long but i needed to explain it in full
please dont forget to rate this
best regards mike
(usn retired)
Posted on Aug 04, 2009
  • 5 Answers
SOURCE: acer gemstone 7520 17" power on problem greenlight flashing
cd-rom-shows no emmulation-how to repair-fix? tks in advance
Posted on Sep 02, 2009
  • 5 Answers
SOURCE: acer aspire one battery light flashes orange.
Finally I got it working again, after a lot of try's (just put the plug in for a few hours) the led was red again for a brief moment, then it starting to flash orange again.
I looked it up on a lot of forums, the problem is that the (old) bios doesn't charge the batery anymore when it is deeply discharged.
So I put the plug in and out for about 10-15 times , and the brief moment it is not flashing it's still charging. Until it is not deeply discharged anymore and then it is charging the batery like it did before.
But I still don't understand why it is not working without the batery inserted ??
Posted on Nov 22, 2009
Will not power up
You may need to replace the CMOS battery in your desktop but first:-
  • Check the power connections.
  • Disconnect power to the desktop.
  • Remove and re-fix the hard disk.
  • Remove the CMOS battery and connect power without it.
  • Now power it up.
  • Your desktop may run without the CMOS battery,[untill you replace] but you will be forced to re-set the date and time everytime you start it.
Hope this helps.Thanks!
Please rate this free answer.
Oct 18, 2011 | Acer Aspire™ T180 PC Desktop
Should i use my new acer 5760 on mains power when possible
It depends upon how much time you run your laptop on battery power, you can keep an eye on the battery charge level when you connect it to mains power. You do not need to keep it on mains power all the time, only when the battery level drops to a low level and needs charging.
The laptop will warn you when it is low on battery power.
Aug 29, 2011 | Acer Travel Mate 7720G-932G50MN Notebook
Hiya i have an acer aspire 5920 which doesnt turn on when you connect the charger the charger light turns off and to get the charger light to turn back on you have to unplug from the wall for 5mins and...
Howdy ,
Sounds like the power pack or the battery is going out.Unplug, remove the main battery and put laptop on flat surface (board on the table)as a precaution.If your laptop runs normally then take it to Office Depot and they will check it for free to see if you need a new battery.I have done this and they just let you know what's wrong.Thank You for choosing FixYa.com. P.S.It won't hurt to run without the battery because they are two separate systems.
Re: Can I run an Acer without a battery? I NEVER have the battery in my 6930G. My laptop cooler then blows cool air in keeping it ultra cool.
A reputable computer magazine recommended that when using the Mains you should REMOVE your battery since one of the biggest killers of batteries is heat.
Jun 06, 2011 | Computers & Internet
Have an Acer Aspire 5920G that is dead. The power supply seems OK with the green light on and ~19 VDC on the DVM when checked. no power light on computer when plugged in, with or without battery.
It is possible that there is a problem with the connection from your power supply going to the main board of your laptop.
This is rather a technical problem and my best recommendation is to bring your laptop to a technician and have them check it.
Hope it helps!
Thanks!
Feb 02, 2011 | Acer Aspire 5920-6727 Notebook
My Acer Aspire 5101ANWLMI laptop stops all of sudden with or without battery. I want circuit too to knowwhere DCV stopped. Satisfy me with reasonable costi would buy second acer product
Hi there, As per your information i sueegst check the Motherboard Power supply connection or its called SMPS. replace the SMPS and i am sure your Laptop will start working again. If you found any sound after pressing the power button then the problem in RAM not in SMPS. Follow the few step below.
1. cjeck power connection in main board.
2. Check the green light in power adeptor its ON or
OFF.
3. check the voltage.
If all is fine then check those i mentioned in top lines. Thanks & waiting for your feedback.
Mar 17, 2010 | Acer Aspire 5101WLMi Notebook
My acer aspire one netbook runs only when
Your notebook battery is faulty you can try with this just remove the battery and shake it and insert it again .see if it is working good otherwise replace the battery.
Nov 06, 2009 | Acer Aspire One PC Notebook
Cahrging problems on Acer Aspire 1642
u shud contact your vendor..and for more info contact http://tinyurl.com/m7ghqz
Jun 16, 2009 | Acer Aspire 1642WLMi Notebook
Acer Aspire 5580 wont power up at all
try to run it without the battery and see how that fares?
May 03, 2008 | Computers & Internet
No power to notebook
It is possible there is a problem with the power pack. Unplug it from the mains, wait for 5 minutes and then try again.
Also try taking the battery out and the power cable and then pressing the power button, as this resets the power management unit in some laptops.
Also with the battery still out, try running just off the mains power.
Failing all of that, take it back under warranty.
Jan 13, 2008 | Acer Aspire 3680 Laptop
Laptop wont run on battery!
ok it looks like your battery has run out of power thats why it would not run when ac is off.If it so happens that the laptop runs when battery is connected to ac then battery seems fine by me just flat. Conenect them to ac and run your pc,go to your control panell and power saving options and set to mimimum usage/power saving mode in this way you charge your battery.Remember bright screen consumes more power
Apr 24, 2007 | Acer Aspire 5670 Notebook
Computers & Internet Logo
187 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
