The usb is write protected and no other files can be added to the flash drive because it is write protected.
  • 6,826 Answers
A usb drive is just like a hard disk drive, You can go to the control panel and remove the write protection by unchecking a box in the menu, then delete all of the files that you don't want, or format the drive.
Posted on Nov 12, 2010
How to protect pendrive files with password
To protect the files on pen Drives you can use a Free open software
download link
http://www.truecrypt.org/
Thanks enjoy
Mar 19, 2013 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Recently , you purchased a USB flash drive that you plan to use to store work-related files. When you attempt to store a file on the USB flash drive, the computer displays an error message indicating that...
You failed to mention what operating systems are involved. What does the work computer use as an operating system. The file system format of the USB may be say as an example ntfs windows while as a hypothetical the work computer could be apple o/s using a different file system or even maybe a unix system. You may need to reformat the usb stick to be the format file system used by the work computer. Also there could be a policy in place to prevent usb sticks working on work computers to protect intellectual property or to protect against virus transferance.
Sep 25, 2012 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
I CAN NOT COPY OR DELETE THE FILES OF MY USB
Your USB flash drive is either infected with a Virus or your Drive is Write Protected.
Scan your flash drive for Mal-ware and Viruses using an Up to date scanner.
Be sure to check that the drive is not on Write Protect mode.
However under Write Protect mode you should be able to copy file from your USB flash drive.
Also try the drive in another computer just to be sure it's not the drive that faulty.
damnor01 out!
Apr 06, 2011 | Computers & Internet
I have TRANSCEND D33193 when i try to format, I have TRANSCEND D33193 when i try to format, or delete files from it, it shows YOUR DEVICE IS WRITE PROTECTED!
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
Jan 14, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My memory stick is write protected...i cant add/delete files.
CHECK if it is not physically protected, a small button/switch might be on the stick!
THEN, try any other flash drive or memmory stick to locate the target problem (memorry stick, or usb port mulfunction or even security/driver issue).
PLUS, there are some programes that might protect flash drives, check if u have any, and uninstall them, and make sure u have deleted ther HIDDEN system files located on the stick!
gd luck.
Jan 01, 2010 | Electronics - Others
I cannot copy files from computer to my phone memory card
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Mar 15, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
My usb flash drive is write protected how can i remove it
USB flash drives are made of a small amount of flash ram and usualy the size of a persons thumb.
the software that resides on them determins if the "disk volume" is write protected.
if a software program other than the native software that came with the drive has write protected "files" that exist on the drive you will need to find out the name of said program and follow the proceedures for changing the write protection of those files.
Loch Hiam
Sep 13, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Flash drive write protected can't move files
a small lock is presents in side of your flash drive ,u just change the current position of this lock
done,now try to copy or your work
regards prasanna
Mar 06, 2008 | Electronics - Others
k24674
jasbo
jasbo
