Question about JVC AV-48WP30 48" Rear Projection Television
What are the pump like boots for on the lamps
  • JVC Master
  • 5,138 Answers
If you are asking about the round looking plastic part that has liquid in them it contains coolant fuild for tubes In this set they are not called Lamps they are Tubes RED/Green/Blue Tubes, picture tubes. You didnt say what problem are you having with TV?
Posted on Nov 12, 2010
No blue light after boot
Yes, I've seen the ballast bad after a lamp shorts out. It takes out a 1K resistor out in ballast. If original lamp blew up this could be your issue
Dec 29, 2013 | Toshiba 72HM195 72" HDTV
Ford ka liftgate light switch
check that it is not in the lock itself
Jun 11, 2013 | Cars & Trucks
1998 camry inner boot light
Check the boot switch, the boot light should have permanent power and the boot switch supplies the negative(earth) when boot is opened.
Regards
Phillip
Aug 30, 2009 | Toyota Camry Cars & Trucks
Acer 5515 backlight not working also bootmanager missing
You need to fix the boot manager problem first by connecting an external monitor to the laptop so you can see and do a system repair.
As for the backlight problem :-
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info
Aug 14, 2009 | Acer Aspire 5610-4648 Notebook
1995 chrysler lebaron
Here's what mine says- for a 95 Chysler LeBaron GTC Convertible. I didn't see anything about a fuel pump, but maybe it's connected to something else? I dunno. Good luck. Here's the info at least.
1 HTR-AC 30A, 2 POWER WINDOWS 30A C/B, 3 PWR SEAT, LKS, TOP 30 A C/B, 4-BLANK, 5 BACK-UP LAMPS 20A, 6 TURN SIGNAL 20A, 7 REAR WIPER 20A, 8 ILLUM LAMPS 5A, 9 INTERIOR LAMPS 10A, 11 CIGAR LIGHTER 20A, 12 RS AMO 20A, 13 INTERIOR LAMPS 10A. 14 BOD COMP MESS CTR 5A, 15 SPEED CONTROL 2A, 16 GAUGES AIRBAGS 5A, 17 STOP LAMPS 18 HEAD LAMP RT-LOW 10A, 19 HEATED MIRRORS 5A, 20 AIRBAGS 5A, 21 STOP LAMOS 20A, 22 HORN 20A, 23 RT-TAIL LAMP-EUR 5A, 24 LT-TAIL LAMP EUR 5A, 25 HEAD LAMP LT-HI 10A, 26 HEAD LAMP RT-HI 10A, 27 RADIO 104, 28 FRONT WIPER 20A
Mar 29, 2009 | 1995 Chrysler LeBaron
How to replace headlight bulb 2000 Tacoma
Open hood. Unplug wiring on back of head lamp. Pull off rubber boot on back of head lamp. Unlock clamp that holds light bulb in. Replace bulb. Clamp bulb down. Replace rubber boot. Plug in bulb.
Mar 22, 2009 | 2000 Toyota Tacoma PreRunner
Christie DS+60 projector turns off spontaneously
Here is a list of error codes for your unit:
12 Software bug. Contact dealer/factory.
13 Flash memory corrupted. Download new software.
14 Engineering only programming is complete. Call Christie, replace TIPM.
15 Attempting to download code without being in boot mode
16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory.
17 Forced boot mode. Keys held down too long.
18 Attempting to program boot mode without jumper
LAMP FAILURES
21 Lamp compartment too hot
25 Lamp 1 not installed
26 Lamp 1 Interlock: door open, lamp not installed
27 Unable to turn lamp 1 ON
28 Lamp 1 shut off unexpectedly
29 Lamp 1 driver overheated
2A Lamp 1 driver operation error (e.g. too hot can’t start)
2C Lamp 1 driver UART communications failure
30 Lamp 2 not installed
31 Lamp 2 door open
32 Unable to turn lamp 2 ON (unknown reason)
33 Lamp 2 shut off unexpectedly
34 Lamp 2 driver overheated
35 Lamp 2 driver reports operation error (e.g. too hot can’t start)
36 Lamp 2 driver UART communications failure
37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
Jan 16, 2009 | Christie DS+60 Multimedia Projector
Plugging after-market fog lamps in firewall of 2007 Sierra 1500
Usually there are some areas that have rubber boots for factory equipment/wiring to pass threw. Cut a small notch in the boot and pass your wire threw.
Dec 25, 2008 | 2007 Scion tC Coupe
Lamp hour reset
I don't thing that because you were not reset the time lamp used now your LCD projector stop function
What was exact the unit did? no power at all or some LED light up or flashing. In any case to reset the lamp time use you must enter when unit is on
As you mentioned you did replaced the new lamp, You should check again if you reinstalled properly the lamp and lamp cover because under the lamp cover it had a safety switch if this SW not active then the unit will be in protection mode
I sugges you to remove again the lamp and reinsert properly and secure the lamp cover and try it again and if it still is not go then let me know what are the status of the 2 LED
Cheers
Dec 24, 2008 | Office Equipment & Supplies
JVC AV-48WP30 48" Rear Projection Television Logo
16 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
