Question about Nokia 6500 Slide Cellular Phone
When the slides are closed, I can view the msgs and see who is calling, but i have problem when i open the slide to write on the keyboard, the screen is converted to black and i cant see whatt am i writing. Please help me to solve the problem, is it hard ar software problem?
  • 251 Answers
Try to change the flex of your 6500 slider phone. that'll fix the problem.
Posted on Nov 12, 2010
My keyboard is stuck about 3/4 up from the bottom of the screen please help
What device are you on? If it is an Apple device, close the app where your keyboard is stuck by double tapping the home button and flick/slide the screen up (while you are in there, slide all your screens up, this will make your phone run faster). Here is a screen shot of what it looks like when you double tap the home button. You should be able to slide all your screens up except your home screen.
Oct 17, 2017 | The Computers & Internet
My screen is only working on side view. Also no opening or closing sound when slide out or close
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Read the tips on this link for more info about phone screen problems; http://www.fixya.com/support/r6382458-screen_problems_phones
Good luck.....
Mar 18, 2011 | Nokia E75 Cell Phone
When the projector was turned on it started to cycle as when ejecting slides then it stopped and seems to be jammed...the rectangle black screen that opens and closes during the cycle to view slides is...
First of all, remove the tray (use the emergency tray removal in the center hub of the projector). BE CAREFUL not to spill your slides, so before you remove the tray, make sure the tray ring is in position & tight, then when you remove the tray turn it upside down immediately and move the tray plate to the "zero" position. Remove any slides that might be in the gate of the projector. Turn the projector on and cycle the projector 2 or 3 times in Reverse. This should clear a tray/slide jam. Good Luck !!
Jan 24, 2011 | Kodak ABR Ektagraphic 35mm 140 Slides...
If i have the slide opened the screen and image works ok but if i slide to close the keyboard, the screen goes dark with some glitchy images sometimes and then if i open it again and use the direction keys...
There is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
Take care.
Aug 25, 2010 | Nokia N95 Cellular Phone
I changed the screen recently on the htc touch pro t7272 and i notice the screen is only showing sideways and wont turn pright what could be the problem is it soft ware or hardware
Could be both, could be either. Let's hope it is a software issue.
One obvious solution is... well... change it back! Then do a power-cycle. (feel free to remove the battery for a few minutes before powering on)
If it went back to being "upright" when the keyboard is closed, then it is a software issue.
You also have other "sensory"-related apps to activate to better diagnose the failure. For instance:
  • you can activate Keyboard Sliding sounds
Start--> Settings--> Personal--> Keyboard Sliding
Choose a sound (any sound), test it (make sure the phone sounds off with it), then activate it.
Then open the keyboard and close it to activate the sounds. If it sounds off, then it's a software problem.
Software problems are easier to fix:
1) backup your hard-earned data (contacts, calls, sms, mms, etc.)
2) then do a factory/hard-reset
3) Once control is given to you, restore the hard-earned data.
Soft-reset the device. Then enjoy.
Jun 20, 2010 | HTC Touch Pro Smartphone
I have an ipod touch. I can open safari, but the touch screen will not respond to close out open pages, slide b/tn open pages and keyboard will not if I open a new one. Npone of these problems happen with...
try a hard reset. hold down the sleep/hold key and the home key at the same time for 10-12 seconds. dont slide the red slider just keep holding until the apple logo appears. all done!
Jan 10, 2010 | Apple iPod touch
Under desk sliding tray won't slide
It sounds like She closed it with it not quite aligned properly.
First try lift up on it a bit while pulling it out some, if it's jammed it may take quite a bit of force. If you have more than one person 1 might lift and the other pull.
If this is tried with no success, you may have to go underneath the desk with a screwdriver and remove one of the sliderails in order to dislodge it. Once loose seperate the sliderails from the mounts and then reattach the mount to the desk. Then insert the rollers into the mount (Holding tray at a 45 deg angle.) Once the rollers are in tilt the tray down and push the tray in to seat it. It should click into place when it catches. It should now be able to slide as normal.
Hope this helps
Dave
Nov 21, 2008 | Ergotron VERTICAL LIFT SLIDE-OUT KEYBOARD...
How to replace keyboard on Acer Aspire 5570 notebook
remove two screws on the back of the laptop where the screen opens and close. then open the cover and use a flathead screw driver to pick the top portion of the keyboard screen. unscrew two more screws and u can slide the keyboard out.
Sep 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
Nokia 6500 Slide Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
